Protocol or cipher suite mismatch
My domain is: abhaysrivastav.net
After generating certificate using certbot, checked the configuration at https://www.ssllabs.com/ssltest/analyze.html?d=abhaysrivastav.net and got Protocol or cipher suite mismatch errors for lot of clients.
Attaching screenshot here.
https://abhaysrivastav.net is being timed out, can someone help please ?
Hi @Abhay07
that's expected.
You have Tls.1.2 and 1.0 enabled. There are no Tls.1.0 Cipher suites, so Tls.1.0 isn't used.
And your Tls.1.2 Ciphers are very limited:
TLS 1.2 (suites in server-preferred order)
TLS_DHE_RSA_WITH_AES_128_GCM_SHA256 ( 0x9e ) DH 2048 bits FS 128
TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 ( 0x9f ) DH 2048 bits FS 256
TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 ( 0x67 ) DH 2048 bits FS WEAK 128
TLS_DHE_RSA_WITH_AES_128_CBC_SHA ( 0x33 ) DH 2048 bits FS WEAK 128
TLS_DHE_RSA_WITH_AES_256_CBC_SHA256 ( 0x6b ) DH 2048 bits FS WEAK 256
TLS_DHE_RSA_WITH_AES_256_CBC_SHA ( 0x39 ) DH 2048 bits FS WEAK 256
TLS_RSA_WITH_AES_128_GCM_SHA256 ( 0x9c ) WEAK 128
TLS_RSA_WITH_AES_256_GCM_SHA384 ( 0x9d ) WEAK 256
TLS_RSA_WITH_AES_128_CBC_SHA256 ( 0x3c ) WEAK 128
TLS_RSA_WITH_AES_256_CBC_SHA256 ( 0x3d ) WEAK 256
TLS_RSA_WITH_AES_128_CBC_SHA ( 0x2f ) WEAK 128
TLS_RSA_WITH_AES_256_CBC_SHA ( 0x35 ) WEAK 256
TLS_RSA is deprecated, same DHE. So most clients aren't able to connect.
Mozilla has a configuration editor.
Hi Juergen,
Thank you for responding. I’m using nginx server, here’s my nginx.conf file, as you can see under ssl protocols it has TLSv1 TLSv1.1 TLSv1.2; values. Should i change these ?
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
        worker_connections 768;
        # multi_accept on;
http {
        # Basic Settings
        sendfile on;
        tcp_nopush on;
        tcp_nodelay on;
        keepalive_timeout 65;
        types_hash_max_size 2048;
        # server_tokens off;
        # SSL Settings
        ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
        ssl_prefer_server_ciphers on;
        # Logging Settings
        # Gzip Settings
        gzip on;
        # gzip_vary on;
        # gzip_proxied any;
        # gzip_comp_level 6;
        # gzip_buffers 16 8k;
        # gzip_http_version 1.1;
        # Virtual Host Configs
        # include /etc/nginx/sites-enabled/*;
#mail {
#       # See sample authentication script at:
#       # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#       # auth_http localhost/auth.php;
#       # pop3_capabilities "TOP" "USER";
#       # imap_capabilities "IMAP4rev1" "UIDPLUS";
#       server {
#               listen     localhost:110;
#               protocol   pop3;
#               proxy      on;
#       server {
#               listen     localhost:143;
#               protocol   imap;
#               proxy      on;
        p
    ssl_ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384;
    ssl_prefer_server_ciphers off;
change where # ssl settings is
Your configuration is completely buggy. There is no real answer.
> openssl s_client -connect abhaysrivastav.net:443 -servername abhaysrivastav.net
> CONNECTED(000001C8)
> write:errno=0
> no peer certificate available
> No client certificate CA names sent
> SSL handshake has read 0 bytes and written 320 bytes
> Verification: OK
> New, (NONE), Cipher is (NONE)
> Secure Renegotiation IS NOT supported
> Compression: NONE
> Expansion: NONE
> No ALPN negotiated
> Early data was not sent
> Verify return code: 0 (ok)
May be these definitions aren’t used or you don’t have a working vHost.
Check
nginx -T
Curious, that Ssllabs has some answers.
PS: /sites-enabled/* isn’t active.
Ok This is my full parsed configuration. See any issues here ? Let me know please.
Yes i’m not using site-enabled configurations, i’m using configuration files from conf.d folder only.
    user www-data;
pid /run/nginx.pid;
events {
	# multi_accept on;
http {
	# Basic Settings
	sendfile on;
	tcp_nopush on;
	tcp_nodelay on;
	# SSL Settings
	ssl_protocols TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
	# Logging Settings
	# Gzip Settings
	gzip on;
	# gzip_vary on;
	# gzip_proxied any;
#mail {
#	server {
#		protocol   pop3;
#		proxy      on;
#	server {
#		protocol   imap;
#		proxy      on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip.conf:
load_module modules/ngx_http_geoip_module.so;
types {
    text/html                             html htm shtml;
    text/css                              css;
    text/xml                              xml;
    image/gif                             gif;
    image/jpeg                            jpeg jpg;
    application/javascript                js;
    application/atom+xml                  atom;
    application/rss+xml                   rss;
    text/mathml                           mml;
    text/plain                            txt;
    text/vnd.sun.j2me.app-descriptor      jad;
    text/vnd.wap.wml                      wml;
    text/x-component                      htc;
    image/png                             png;
    image/tiff                            tif tiff;
    image/vnd.wap.wbmp                    wbmp;
    image/x-icon                          ico;
    image/x-jng                           jng;
    image/x-ms-bmp                        bmp;
    image/svg+xml                         svg svgz;
    image/webp                            webp;
    application/font-woff                 woff;
    application/java-archive              jar war ear;
    application/json                      json;
    application/mac-binhex40              hqx;
    application/msword                    doc;
    application/pdf                       pdf;
    application/postscript                ps eps ai;
    application/rtf                       rtf;
    application/vnd.apple.mpegurl         m3u8;
    application/vnd.ms-excel              xls;
    application/vnd.ms-fontobject         eot;
    application/vnd.ms-powerpoint         ppt;
    application/vnd.wap.wmlc              wmlc;
    application/vnd.google-earth.kml+xml  kml;
    application/vnd.google-earth.kmz      kmz;
    application/x-7z-compressed           7z;
    application/x-cocoa                   cco;
    application/x-java-archive-diff       jardiff;
    application/x-java-jnlp-file          jnlp;
    application/x-makeself                run;
    application/x-perl                    pl pm;
    application/x-pilot                   prc pdb;
    application/x-rar-compressed          rar;
    application/x-redhat-package-manager  rpm;
    application/x-sea                     sea;
    application/x-shockwave-flash         swf;
    application/x-stuffit                 sit;
    application/x-tcl                     tcl tk;
    application/x-x509-ca-cert            der pem crt;
    application/x-xpinstall               xpi;
    application/xhtml+xml                 xhtml;
    application/xspf+xml                  xspf;
    application/zip                       zip;
    application/octet-stream              bin exe dll;
    application/octet-stream              deb;
    application/octet-stream              dmg;
    application/octet-stream              iso img;
    application/octet-stream              msi msp msm;
    application/vnd.openxmlformats-officedocument.wordprocessingml.document    docx;
    application/vnd.openxmlformats-officedocument.spreadsheetml.sheet          xlsx;
    application/vnd.openxmlformats-officedocument.presentationml.presentation  pptx;
    audio/midi                            mid midi kar;
    audio/mpeg                            mp3;
    audio/ogg                             ogg;
    audio/x-m4a                           m4a;
    audio/x-realaudio                     ra;
    video/3gpp                            3gpp 3gp;
    video/mp2t                            ts;
    video/mp4                             mp4;
    video/mpeg                            mpeg mpg;
    video/quicktime                       mov;
    video/webm                            webm;
    video/x-flv                           flv;
    video/x-m4v                           m4v;
    video/x-mng                           mng;
    video/x-ms-asf                        asx asf;
    video/x-ms-wmv                        wmv;
    video/x-msvideo                       avi;
# configuration file /etc/nginx/conf.d/server.conf:
    server_name  abhaysrivastav.net www.abhaysrivastav.net;
    root /home/ubuntu/Website/;
    index index.html;
    access_log /var/log/nginx/access_log combined;
        try_files $uri $uri/ =404;
    listen 80;
    ssl_certificate /etc/letsencrypt/live/abhaysrivastav.net-0001/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/abhaysrivastav.net-0001/privkey.pem; # managed by Certbot
        server_name  youtubecut.com www.youtubecut.com;
        root /home/ubuntu/youtubecut-frontend/dist/;
        index index.html;
        location /api/ {
                proxy_pass        http://127.0.0.1:8082/;
                proxy_read_timeout 300s;
    listen 80;
Thank you for responding. So there are two places for ssl setting one is in http block of nginx.conf file and another is in /etc/letsencrypt/options-ssl-nginx.conf Should i change only in nginx.conf or both the places ? Below is the warning with letsencrypt conf file.
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file.
Never mix two ports in one server block. Create two different server blocks, one with port 80, one with port 443.
Thank you for suggesting that. i have separated port 443 block and port 80 block. Below is the new parsed nginx configuration. But still getting time outs for https requests.
user www-data;
pid /run/nginx.pid;
events {
	# multi_accept on;
http {
	# Basic Settings
	sendfile on;
	tcp_nopush on;
	tcp_nodelay on;
	# SSL Settings
	# Logging Settings
	# Gzip Settings
	gzip on;
	# gzip_vary on;
	# gzip_proxied any;
#mail {
#	server {
#		protocol   pop3;
#		proxy      on;
#	server {
#		protocol   imap;
#		proxy      on;
types {
    text/css                              css;
    text/xml                              xml;
    image/gif                             gif;
    text/mathml                           mml;
    text/plain                            txt;
    image/png                             png;
    image/x-icon                          ico;
    image/x-jng                           jng;
    image/x-ms-bmp                        bmp;
    image/webp                            webp;
    audio/mpeg                            mp3;
    audio/ogg                             ogg;
    audio/x-m4a                           m4a;
    video/mp2t                            ts;
    video/mp4                             mp4;
    video/webm                            webm;
    video/x-flv                           flv;
    video/x-m4v                           m4v;
    video/x-mng                           mng;
    video/x-ms-wmv                        wmv;
    index index.html;
        index index.html;
        location /api/ {
 	listen 80;
    index index.html;
		listen 80;
        index index.html;
        location /api/ {
problem keeps same… how about reinstall nginx?
sudo apt reinstall nginx-common?
I think nginx is working properly. Since i’m able to access http://abhaysrivastav.net, only the https requests are being timed out.
by the way did you change the cipher suites?
Hey no, should i it in change in the letsencrypt conf file or the nginx.conf file ?
Should ssl_prefer_server_ciphers off; this value be off ?
add cipher suits in main nginx.conf and
remove all include /etc/letsencrypt/options-ssl-nginx.conf
I don’t think nginx can see that file, if nginx can read the file it should print what’s in that file in nginx -T
and ssl_prefer_server_cipher: if all ciphers you said you support is secure then yes. if you included ciphers that are not as secure in it because backward compatibility then you set it on to prefer secure cipher.
Ok. So here’s the new fully parsed configuration. Do i have to again generate certificate after changing cypher ?
P.S. I have updated the ssl protocol in /etc/letsencrypt/options-ssl-nginx.conf file
user www-data;
pid /run/nginx.pid;
events {
	# multi_accept on;
http {
	# Basic Settings
	sendfile on;
	tcp_nopush on;
	tcp_nodelay on;
	# SSL Settings
	# Logging Settings
	# Gzip Settings
	gzip on;
	# gzip_vary on;
	# gzip_proxied any;
#mail {
#	server {
#		protocol   pop3;
#		proxy      on;
#	server {
#		protocol   imap;
#		proxy      on;
types {
    text/css                              css;
    text/xml                              xml;
    image/gif                             gif;
    text/mathml                           mml;
    text/plain                            txt;
    image/png                             png;
    image/x-icon                          ico;
    image/x-jng                           jng;
    image/x-ms-bmp                        bmp;
    image/webp                            webp;
    audio/mpeg                            mp3;
    audio/ogg                             ogg;
    audio/x-m4a                           m4a;
    video/mp2t                            ts;
    video/mp4                             mp4;
    video/webm                            webm;
    video/x-flv                           flv;
    video/x-m4v                           m4v;
    video/x-mng                           mng;
    video/x-ms-wmv                        wmv;
    index index.html;
        index index.html;
        location /api/ {
 	listen 80;
    index index.html;
		listen 80;
        index index.html;
        location /api/ {
# this file.
ssl_session_cache shared:le_nginx_SSL:1m;
ssl_session_timeout 1440m;
can you add TLSv1.3 in ssl_protocols in main file? if not server block doesn’t support it even if it said it in server block
and reload nginx :wink:
and I don’t think this installation of nginx have full support of cipher suite: where you get this nginx from?
it honors ciphersuites set by config: but it doesn’t support much in beginning
I recommend you to reinstalling it. while keep config.
https://www.ssllabs.com/ssltest/analyze.html?d=youtubecut.com
new test says it successfully disabled tls 1.0 ( as the config says), and disabled rsa key exchange but doesn’t support new ciphers
Ok. So added the TLSv1.3 in ssl_protocols in main file. Here’s the new configuration. So you are suggesting to reinstall nginx which support TLS1.3 keeping the config intact ?
user www-data;
pid /run/nginx.pid;
events {
	# multi_accept on;
http {
	# Basic Settings
	sendfile on;
	tcp_nopush on;
	tcp_nodelay on;
	# SSL Settings
	ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
	# Logging Settings
	# Gzip Settings
	gzip on;
	# gzip_vary on;
	# gzip_proxied any;
#mail {
#	server {
#		protocol   pop3;
#		proxy      on;
#	server {
#		protocol   imap;
#		proxy      on;
types {
    text/css                              css;
    text/xml                              xml;
    image/gif                             gif;
    text/mathml                           mml;
    text/plain                            txt;
    image/png                             png;
    image/x-icon                          ico;
    image/x-jng                           jng;
    image/x-ms-bmp                        bmp;
    image/webp                            webp;
    audio/mpeg                            mp3;
    audio/ogg                             ogg;
    audio/x-m4a                           m4a;
    video/mp2t                            ts;
    video/mp4                             mp4;
    video/webm                            webm;
    video/x-flv                           flv;
    video/x-m4v                           m4v;
    video/x-mng                           mng;
    video/x-ms-wmv                        wmv;
    index index.html;
        index index.html;
        location /api/ {
 	listen 80;
    index index.html;
		listen 80;
        index index.html;
        location /api/ {
# this file.
it looks like you have really old version of nginx, so update it , yes
Nginx added support for TLS 1.3 in version 1.13. 0.
My version is 1.14.0
On updating nginx, it seems already the latest version is installed.
nginx is already the newest version (1.14.0-0ubuntu1.7).
only thing I know is your nginx isn’t normal it should be support tls 1.3 , but it doesn’t
is this thing behind some kind of proxy?
try openssl s_client -connect youtubecut.com:443 -tls1_3 on your server
does it work?
