No it doesn’t it seems.
ssl protocol TLSv1.2 won’t work ?
Should i revert the ssl protocol and cypher setting changes ?
CONNECTED(00000005)
write:errno=0
no peer certificate available
SSL handshake has read 0 bytes and written 238 bytes
Verification: OK
New, (NONE), Cipher is (NONE)
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
how about openssl s_client -connect youtube.com:443 -tls1_3
(or google.com or this page etc)
does your system support tls 1.3 at all?
maybe your ssl library is mangled up
Yes this is giving all the certificates and CAs unlike for my website.
try installing nginx from upsteam? (use mainline)
https://nginx.org/en/linux_packages.html#Ubuntu
Since the server is using TLSv1.2 so below command should give the output, but it is also being timed out.
openssl s_client -connect youtubecut.com:443 -tls1_2
by the way I noticed you didn’t put ciphers in main nginx.conf. can you add there too?
same config as I sat
ssl_ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384;
ssl_prefer_server_ciphers off;
Ok so here’s the new configuration. Btw thank you for bearing with me . Lets hope we solve this.
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# SSL Settings
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Virtual Host Configs
# include /etc/nginx/sites-enabled/*;
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip.conf:
load_module modules/ngx_http_geoip_module.so;
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/svg+xml svg svgz;
image/webp webp;
application/font-woff woff;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.wap.wmlc wmlc;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
application/vnd.openxmlformats-officedocument.wordprocessingml.document docx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet xlsx;
application/vnd.openxmlformats-officedocument.presentationml.presentation pptx;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file /etc/nginx/conf.d/server.conf:
server_name abhaysrivastav.net www.abhaysrivastav.net;
root /home/ubuntu/Website/;
index index.html;
access_log /var/log/nginx/access_log combined;
try_files $uri $uri/ =404;
ssl_certificate /etc/letsencrypt/live/abhaysrivastav.net-0001/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/abhaysrivastav.net-0001/privkey.pem; # managed by Certbot
server_name youtubecut.com www.youtubecut.com;
root /home/ubuntu/youtubecut-frontend/dist/;
index index.html;
location /api/ {
proxy_pass http://127.0.0.1:8082/;
proxy_read_timeout 300s;
listen 80;
index index.html;
listen 80;
index index.html;
location /api/ {
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file.
ssl_session_cache shared:le_nginx_SSL:1m;
ssl_session_timeout 1440m;
nope it didn’t
I think reinstalling / use upstream vesion is only way to solve this now.
your nginx supports tls 1.2, but only deprecated ciphersuits that remove in morden browsers
so only IE11 can connect to it.
this is why I recommend you to use upsteam nginx so make sure it use newest version.
To give some context, it was working till yesterday. Somehow it started timing out from today suddenly.
I have no idea now other then what I said before, using upsteam nginx
or some wired thing with openssl. you may find better chance on serverfault.com
I think your nginx looking at wrong openssl version, but I don’t know why or how to fix
I tried on serverfault also but no luck.
did you try upstream nginx?
By Upstream you mean upgrading t he nginx version ?
let’s try removeing and reinstalling nginx first
(backup config!)
Apparently if i generated a certificate using https://www.buypass.com/ as CA for my first domain abhaysrivastav.net . It worked. Don’t know whats wrong with Letsencrypt.
I have a custom webroot path and i’m using webroot option also
sudo certbot certonly --webroot -w /home/ubuntu/youtubecut-frontend/dist/ -d www.youtubecut.com -d youtubecut.com
Still the certificate generated is not valid for youtubecut.com
JimPas
July 12, 2020, 6:25pm
40
Try reversing the order and putting youtubecut.com first - that is the main domain name. The “www” is a subdomain. Having the main domain name first may make a difference. Normally one would have the main domain first and foremost, followed by sub-domains. It’s worth a try.
system
Closed
August 11, 2020, 6:25pm
41
