Apologies if this has already been asked elsewhere, but my search for answers is still unsuccessful.
In our use case, we have an Ubuntu haproxy server which hosts multiple vhosts, for example, jenkins.projectdev.com, gitlab.projectdev.com, nagios.projectdev.com. That is, one external IP address, with multiple DNS A-RECORDS for the multiple vhosts which point towards that same haproxy server. That haproxy server listens on 80 and 443, but automatically redirects all HTTP to HTTPS. All pretty simple.
Ideally, I’d like to install and renew certificates (through automation) without having to bring haproxy offline temporarily. I have configured the frontend and backends as follows:
` global
chroot /var/lib/haproxy
group haproxy
log 127.0.0.1 local0 err
log 127.0.0.1 local2 notice
log 127.0.0.1 local3
maxconn 4000
pidfile /var/run/haproxy.pid
stats socket /var/lib/haproxy/stats level admin
user haproxy
defaults
log global
maxconn 4000
retries 3
timeout http-request 10s
timeout queue 1m
timeout connect 10s
timeout client 1m
timeout server 1m
timeout check 10s
frontend frontend00
bind *:443 ssl crt /etc/haproxy/frontend00.local.pem
bind *:80
mode http
acl destination_jenkins-backend00 hdr_beg(host) -i jenkins
acl destination_gitlab-backend00 hdr_beg(host) -i gitlab
acl destination_nagios-backend00 hdr_beg(host) -i nagios
acl destination_letsencrypt-backend00 path_beg /.well-known/acme-challenge/
http-response replace-value Location http://(.*) https://\1
option httplog
redirect scheme https code 301 if !{ ssl_fc }
use_backend jenkins-backend00 if destination_jenkins-backend00
use_backend gitlab-backend00 if destination_gitlab-backend00
use_backend nagios-backend00 if destination_gitlab-backend00
use_backend letsencrypt-backend00 if destination_letsencrypt-backend00
listen server-stats-listen00
bind *:8888
mode http
stats enable
stats uri /
mode http
option forwardfor
option httplog
stats enable
server gitlab gitlab:80 check inter 12s
mode http
option forwardfor
option httplog
stats enable
server jenkins jenkins:8080 check inter 12s
mode http
option forwardfor
option httplog
stats enable
server nagios nagios:8080 check inter 12s
mode http
option forwardfor
option httplog
stats enable
server localserverletsencrypt 127.0.0.1:6443 check inter 5s`
So, I then try to run:
sudo ./letsencrypt/letsencrypt-auto certonly -d gitlab.projectdev.com -d jenkins.projectdev.com -d nagios.projectdev.com --renew-by-default --standalone-supported-challenges tls-sni-01 --agree-tos --tls-sni-01-port=6443
Multiple problems here:
- haproxy does not detect that letsencrypt-auto backend service comes up in time for the request coming in from the letsencrypt-auto server - haproxy returns a 503. I can get around this by running netcat in listen mode on the same port for 10 seconds prior to running letsencrypt, tricking haproxy into detecting the backend as alive.
- I then had to recreate the existing haproxy self-signed certificate to include the multiple SANs (using instructions here http://stackoverflow.com/questions/21488845/how-can-i-generate-a-self-signed-certificate-with-subjectaltname-using-openssl) however letsencrypt does not accept the multiple SANs as valid.
I could probably resolve #2 by putting an HTTP->HTTPS exception in place for the ‘path_beg /.well-known/acme-challenge/’, however I’m not sure what other security implications this may have, so I’d prefer not to. The only way I can think of solving #1 is by stopping haproxy, letting lets-encrypt take its port directly, then restarting it after a successful certificate installation - however this will interrupt service…
How have other people solved these challenges?
