Problems renewing Let's Encrypt Certificate
My domain is: vectrex.be
(first, I deleted the old certificate, with: sudo certbot delete, then I did:
sudo certbot certonly --manual --agree-tos --preferred-challenges dns -d vectrex.be -d *.vectrex.be
    /etc/letsencrypt/live/vectrex.be/fullchain.pem
    /etc/letsencrypt/live/vectrex.be/privkey.pem
    Your cert will expire on 2023-01-02. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot
    again. To non-interactively renew all of your certificates, run
    "certbot renew"
    Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
    Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation
My web server is (include version): Ubuntu 20.04.3 LTS
The operating system my web server runs on is (include version): Ubuntu 20.04.3 LTS
My hosting provider, if applicable, is:Strato
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 0.40.0
Welcome to the community @erik1
First, there is no reason to delete the old certificate. In fact, this can cause problems because your server is (normally) using it. And, any failure to get a new cert will then have your server failing.
You are successfully getting certs with that command. You got 5 of them today and that is your limit for a whole week. So, please do not delete them any more.
Your server is not using the new cert. Instead it is using an older cert with these two domain names and two others
blijf-in-uw-kot.be
vectrex.be
www.blijf-in-uw-kot.be
www.vectrex.be
The response headers say you are using Apache. Can you show result of this:
sudo apachectl -t -D DUMP_VHOSTS
I really appreciate this.
when I do:
sudo apachectl -t -D DUMP_VHOSTS,
I get an error:
AH00526: Syntax error on line 48 of /etc/apache2/sites-enabled/keith-ssl.conf:
SSLCertificateFile: file '/etc/letsencrypt/live/keith.be-0001/fullchain.pem' does not exist or is empty
Action '-t -D DUMP_VHOSTS' failed.
This is strange, since the keith.be - site works as expected..
It will until you restart Apache. Then Apache will fail. It looks like you have deleted even more cert files that Apache is actively using. What does this show:
sudo certbot certificates
Certificate Name: bierkalender.be
Domains: bierkalender.be *.bierkalender.be
Expiry Date: 2023-01-02 10:21:19+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/bierkalender.be/fullchain.pem
Private Key Path: /etc/letsencrypt/live/bierkalender.be/privkey.pem
Certificate Name: blijf-in-uw-kot.be
Domains: blijf-in-uw-kot.be *.blijf-in-uw-kot.be
Expiry Date: 2023-01-02 11:11:14+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/blijf-in-uw-kot.be/fullchain.pem
Private Key Path: /etc/letsencrypt/live/blijf-in-uw-kot.be/privkey.pem
Certificate Name: keith.be
Domains: keith.be *.keith.be
Expiry Date: 2022-11-12 17:22:39+00:00 (VALID: 39 days)
Certificate Path: /etc/letsencrypt/live/keith.be/fullchain.pem
Private Key Path: /etc/letsencrypt/live/keith.be/privkey.pem
Certificate Name: nietmetmij.be-0001
Domains: nietmetmij.be *.nietmetmij.be
Expiry Date: 2022-11-12 17:40:30+00:00 (VALID: 39 days)
Certificate Path: /etc/letsencrypt/live/nietmetmij.be-0001/fullchain.pem
Private Key Path: /etc/letsencrypt/live/nietmetmij.be-0001/privkey.pem
Certificate Name: vectrex.be
Domains: vectrex.be *.vectrex.be
Expiry Date: 2023-01-02 09:42:12+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/vectrex.be/fullchain.pem
Private Key Path: /etc/letsencrypt/live/vectrex.be/privkey.pem
It looks like you now have individual certs for each domain name. But, before you used some certs with multiple names. I like that you now have individual certs but it requires changes to Apache config. Since your Apache config is faulty we will need to review it piece by piece.
ls -lR /etc/apache2/{sites-available,sites-enabled}
-rw-r--r-- 1 root root 1332 okt 1 2020 000-default.conf
-rw-r--r-- 1 root root 2036 feb 21 2022 bierkalender.conf
-rw-r--r-- 1 root root 2364 feb 16 2022 bierkalender-le-ssl.conf
-rw-r--r-- 1 root root 2047 dec 27 2021 biuk.conf
-rw-r--r-- 1 root root 2053 mrt 18 2022 biuk-le-ssl.conf
-rw-r--r-- 1 root root 6338 okt 1 2020 default-ssl.conf
-rw-r--r-- 1 root root 1720 mrt 20 2022 keith.conf
-rw-r--r-- 1 root root 2067 okt 4 14:41 keith-ssl.conf
-rw-r--r-- 1 root root 1846 mrt 21 2022 n8.conf
-rw-r--r-- 1 root root 2084 mrt 17 2022 nietmetmij.conf
-rw-r--r-- 1 root root 2080 mrt 17 2022 nietmetmij-le-ssl.conf
-rw-r--r-- 1 root root 1938 mrt 21 2022 notariaatnijlen.conf
-rw-r--r-- 1 root root 1997 dec 27 2021 vectrex.conf
-rw-r--r-- 1 root root 2019 mrt 18 2022 vectrex-le-ssl.conf
/etc/apache2/sites-enabled:
total 0
lrwxrwxrwx 1 root root 35 dec 2 2021 000-default.conf -> ../sites-available/000-default.conf
lrwxrwxrwx 1 root root 28 dec 27 2021 biuk.conf -> ../sites-available/biuk.conf
lrwxrwxrwx 1 root root 33 feb 25 2022 keith-ssl.conf -> ../sites-available/keith-ssl.conf
lrwxrwxrwx 1 root root 26 mrt 22 2022 n8.conf -> ../sites-available/n8.conf
lrwxrwxrwx 1 root root 34 mrt 22 2022 nietmetmij.conf -> ../sites-available/nietmetmij.conf
lrwxrwxrwx 1 root root 51 mrt 17 2022 nietmetmij-le-ssl.conf -> /etc/apache2/sites-available/nietmetmij-le-ssl.conf
lrwxrwxrwx 1 root root 39 mrt 21 2022 notariaatnijlen.conf -> ../sites-available/notariaatnijlen.conf
lrwxrwxrwx 1 root root 31 dec 7 2021 vectrex.conf -> ../sites-available/vectrex.conf
lrwxrwxrwx 1 root root 48 dec 27 2021 vectrex-le-ssl.conf -> /etc/apache2/sites-available/vectrex-le-ssl.conf
root@h2955757:/etc/letsencrypt/live/nietmetmij.be-0001#
Let's do them one at a time.
You have a cert for bierkalender.be and a conf for it in /sites-available. But, it is not in /sites-enabled. Do you still want this site to work?
nietmetmij.be is the most important site atm , then bierkalender and vectrex.be
others are less important atm
Ok. Can you show contents of this file. Please put 3 backticks before and after the output like this:
contents of: bierkalender-le-ssl.conf
<IfModule mod_ssl.c>
<VirtualHost *:443>
        # A lot more comment here
        ServerName bierkalender.be
        ServerAlias www.bierkalender.be
        DocumentRoot /var/www/bierkalender
        <Directory /var/www/bierkalender>
            DirectoryIndex index.py
            AllowOverride All
            Order allow,deny
            Allow from all
        </Directory>
        <Directory /var/www/bierkalender/cgi-bin>
            Options ExecCGI
            SetHandler cgi-script
        </Directory>
            Options +ExecCGI
            AddHandler cgi-script .py
        </Directory>
RewriteEngine on
SSLCertificateFile /etc/letsencrypt/live/bierkalender.be-0001/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/bierkalender.be-0001/privkey.pem
</VirtualHost>
</IfModule>
You need to remove the "-0001" from the path in those two file names (like below) and then enable that site in Apache (use a2ensite or whatever method you use). If you have any questions ask first.
We need these two lines to use the path name shown in the certbot certificates command you used earlier.
SSLCertificateFile /etc/letsencrypt/live/bierkalender.be/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/bierkalender.be/privkey.pem
When that's done let me know and we'll do the next one.
done, but the site bierkalender.be still gives a certificate error in the browser (but ok, I didn't get an error when I restarted apache this time, so that's progress)
Please don't restart Apache yet (any more). We should get your config fixed. Then test the config. Then we'll restart Apache.
Your bierkalender.be site is using the cert for keith - that's why it does not work. You should probably a2dissite bierkalender until we get all your config fixed.
Next one is biuk. I don't see a cert for it but what is contents of this:
/etc/apache2/sites-available/biuk.conf
<VirtualHost *:80>
        # More commentlines here
        ServerName blijf-in-uw-kot.be
        ServerAlias www.blijf-in-uw-kot.be
        DocumentRoot /var/www/blijfinuwkot
        <Directory /var/www/blijfinuwkot>
            AllowOverride All
            Order allow,deny
            Allow from all
        </Directory>
        <Directory /var/www/blijfinuwkot/cgi-bin>
            Options ExecCGI
        </Directory>
            Options +ExecCGI
        </Directory>
RewriteEngine on
RewriteCond %{SERVER_NAME} =blijf-in-uw-kot.be [OR]
RewriteCond %{SERVER_NAME} =www.blijf-in-uw-kot.be
</VirtualHost>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
And, contents of this (sorry, should have asked for both right away)
/etc/apache2/sites-available/biuk-le-ssl.conf
<VirtualHost *:443>
        # comment here
            AllowOverride All
            Order allow,deny
            Allow from all
        </Directory>
            Options ExecCGI
        </Directory>
            Options +ExecCGI
        </Directory>
        # Comment here
SSLCertificateFile /etc/letsencrypt/live/blijf-in-uw-kot.be-0001/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/blijf-in-uw-kot.be-0001/privkey.pem
</VirtualHost>
</IfModule>
Change the above two lines. Remove the "-0001" from the path name so they are like:
SSLCertificateFile /etc/letsencrypt/live/blijf-in-uw-kot.be/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/blijf-in-uw-kot.be/privkey.pem
Again, we are using the path name in your Apache config that matches the certbot certificates results earlier.
Once you change these paths run: a2ensite biuk-le-ssl
Do not restart Apache yet
Let me know when that is all done. I will start working on next step.
Next one is keith. What is contents of this:
/etc/apache2/sites-available/keith-ssl.conf
<VirtualHost *:443>
        # Comment here
        ServerName keith.be
        ServerAlias www.keith.be
        WSGIScriptAlias / /var/www/keith/application/join.wsgi
        <Directory /var/www/keith/application>
                options FollowSymLinks
                AllowOverride None
                Require all granted
        </Directory>
        # Comment here
        # Comment here
RewriteEngine on
# Some rewrite rules in this file were disabled on your HTTPS site,
# because they have the potential to create redirection loops.
# RewriteCond %{SERVER_NAME} =keith.be [OR]
# RewriteCond %{SERVER_NAME} =www.keith.be
# RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
SSLCertificateFile /etc/letsencrypt/live/keith.be/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/keith.be/privkey.pem
</VirtualHost>
</IfModule>
