keith looks fine. What is contents of n8
/etc/apache2/sites-available/n8.conf
this was a test (once), I'll delete that site
is it ok to do a2dissite n8.conf?
Yes, if it is not used that is good idea.
To the next one. What is this
/etc/apache2/sites-available/nietmetmij-le-ssl.conf
that file is empty now (it says 0 bytes, it wasn't empty a couple hours ago) I don't know what I did wrong,
but the site is not working anymore atm, probably because the apache restart I did, just before you said shoudn't restart (yet).
No, the restart should not have done that. Could you have spelled it wrong?
What does this show?
ls -l /etc/apache2/sites-available/n*
no, because I'm using Midnight Commander, I really see the files in the folder (and nietmetmij-le-ssl.conf sais 0 bytes)
Your command says:
-rw-r--r-- 1 root root 1846 mrt 21 2022 /etc/apache2/sites-available/n8.conf
-rw-r--r-- 1 root root 2084 mrt 17 2022 /etc/apache2/sites-available/nietmetmij.conf
-rw-r--r-- 1 root root 0 okt 4 15:14 /etc/apache2/sites-available/nietmetmij-le-ssl.conf
Do you have a backup of that file? Because it was not zero bytes about an hour ago in your post #7. Apache does not update config files it only reads them.
Also, you previously had a file named notariaatnijlen.conf. That now seems missing. Did you do that on purpose?
that notariaatfile is a copy/paste so I didn't paste it in the last post
but, in the meantime I created a nietmetmij-le-ssl.conf
(a mix od nietmetmij.conf and keith-le-ssl.conf )
<IfModule mod_ssl.c>
<VirtualHost *:443>
# specifies what hostname must appear in the request's Host: header to
#ServerName www.example.com
ServerName nietmetmij.be
ServerAlias www.nietmetmij.be
DocumentRoot /var/www/nietmetmij
WSGIScriptAlias / /var/www/nietmetmij/flask/my_flask_app.wsgi
<Directory /var/www/nietmetmij/flask/>
Options FollowSymLinks
AllowOverride None
Require all granted
</Directory>
<Directory /var/www/nietmetmij/cgi-bin>
Options ExecCGI
SetHandler cgi-script
</Directory>
<Directory /var/www/nietmetmij>
Options +ExecCGI
AddHandler cgi-script .py
</Directory>
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
RewriteEngine on
# Some rewrite rules in this file were disabled on your HTTPS site,
# because they have the potential to create redirection loops.
# RewriteCond %{SERVER_NAME} =nietmetmij.be [OR]
# RewriteCond %{SERVER_NAME} =www.nietmetmij.be
# RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
SSLCertificateFile /etc/letsencrypt/live/nietmetmij.be/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/nietmetmij.be/privkey.pem
</VirtualHost>
</IfModule>
OK, good you recovered the file but the cert file names are wrong. If you look back at the certbot certificates output this cert has a "-0001" in the name. So, you need to change these to:
SSLCertificateFile /etc/letsencrypt/live/nietmetmij.be-0001/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/nietmetmij.be-0001/privkey.pem
Something must have gone slightly wrong when creating certs for this domain earlier. I am not worried about that right now. Just want to get your sites running right now. We might come back to that later.
When that is done, please show contents of
/etc/apache2/sites-available/notariaatnijlen.conf
Want to see this even though it has no cert. Want to ensure no interference with others.
I'll
adissite notariaat.conf too
OK for notaria, just the last one and we'll test config
Show:
/etc/apache2/sites-available/vectrex-le-ssl.conf
a2dissite notariaat.conf is done and the
-0001 was added in the nietmetmij-le-ssl.conf
again, vectrex-le-ssl.conf is an empty file !
(it seems my computer knows what was important for me and decided to delete these files, well not delete, but they are empty ..)
OK, well, I guess you need to make that one too. Ouch. I'll wait
<VirtualHost *:443>
ServerName vectrex.be
ServerAlias www.vectrex.be
DocumentRoot /var/www/vectrex
<Directory /var/www/vectrex>
DirectoryIndex index.html
AllowOverride All
Order allow,deny
Allow from all
</Directory>
<Directory /var/www/vectrex/cgi-bin>
Options ExecCGI
</Directory>
Options +ExecCGI
</Directory>
# modules, e.g.
RewriteEngine on
RewriteEngine on
# RewriteCond %{SERVER_NAME} =vectrex.be [OR]
# RewriteCond %{SERVER_NAME} =www.vectrex.be
SSLCertificateFile /etc/letsencrypt/live/vectrex.be/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/vectrex.be/privkey.pem
</VirtualHost>
</IfModule>
Hurray! Looks good. Now let's see if the config is OK. Still, do not restart Apache yet though. Just this test.
sudo apache2ctl -t -D DUMP_VHOSTS
root@h2955757:/etc/apache2/sites-available# sudo apache2ctl -t -D DUMP_VHOSTS
VirtualHost configuration:
*:443 is a NameVirtualHost
default server blijf-in-uw-kot.be (/etc/apache2/sites-enabled/biuk-le-ssl.conf:2)
port 443 namevhost blijf-in-uw-kot.be (/etc/apache2/sites-enabled/biuk-le-ssl.conf:2)
alias www.blijf-in-uw-kot.be
port 443 namevhost keith.be (/etc/apache2/sites-enabled/keith-ssl.conf:2)
alias www.keith.be
port 443 namevhost nietmetmij.be (/etc/apache2/sites-enabled/nietmetmij-le-ssl.conf:2)
alias www.nietmetmij.be
port 443 namevhost vectrex.be (/etc/apache2/sites-enabled/vectrex-le-ssl.conf:2)
alias www.vectrex.be
*:80 is a NameVirtualHost
default server h2955757.stratoserver.net (/etc/apache2/sites-enabled/000-default.conf:1)
port 80 namevhost h2955757.stratoserver.net (/etc/apache2/sites-enabled/000-default.conf:1)
port 80 namevhost blijf-in-uw-kot.be (/etc/apache2/sites-enabled/biuk.conf:1)
port 80 namevhost nietmetmij.be (/etc/apache2/sites-enabled/nietmetmij.conf:1)
port 80 namevhost vectrex.be (/etc/apache2/sites-enabled/vectrex.conf:1)
