Problems generating certificates
My domain is: https://www.shitouttaluck.co.uk/
I ran this command: certbot --apache
Error while running apache2ctl graceful.
httpd not running, trying to start
Action 'graceful' failed.
Unable to restart apache using ['apache2ctl', 'graceful']
Encountered exception during recovery: certbot.errors.MisconfigurationError: Error while running apache2ctl graceful.
My web server is (include version): Server version: Apache/2.4.41 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 20.04.5 LTS
My hosting provider, if applicable, is: Fasthosts
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.32.2
Problem
I am trying to generate a new certificate for the above site but I run into the errors shown above.
If I take a look at my virtual servers error logs I see the following
Apache Error log for Virtual Server - tail -30 /var/log/apache2/shitouttaluck.error.log
[Thu Dec 22 23:18:38.285171 2022] [ssl:info] [pid 1378473] AH01914: Configuring server www.shitouttaluck.co.uk:443 for SSL protocol
[Thu Dec 22 23:18:38.285311 2022] [ssl:emerg] [pid 1378473] AH02572: Failed to configure at least one certificate and key for www.shitouttaluck.co.uk:443
[Thu Dec 22 23:18:38.285325 2022] [ssl:emerg] [pid 1378473] SSL Library Error: error:0909006C:PEM routines:get_name:no start line (Expecting: DH PARAMETERS) -- Bad file contents or format - or even just a forgotten SSLCertificateKeyFile?
[Thu Dec 22 23:18:38.285334 2022] [ssl:emerg] [pid 1378473] SSL Library Error: error:0909006C:PEM routines:get_name:no start line (Expecting: EC PARAMETERS) -- Bad file contents or format - or even just a forgotten SSLCertificateKeyFile?
[Thu Dec 22 23:18:38.285347 2022] [ssl:emerg] [pid 1378473] SSL Library Error: error:140A80B1:SSL routines:SSL_CTX_check_private_key:no certificate assigned
I have several other servers running on this box all running LetsEncrypt certificates, but this has just stopped working for me.
** Steps to recreate the problem**
As the root user
  1. Create config file in /etc/apache2/sites-available
  2. apache2 -configtest - This passes with an OK
  3. a2ensite - Enabling site shitouttaluck
  4. Activate new config by running - systemctl reload apache2 This loads fine and returns to prompt
  5. run **certbot --apache"
 certbot --apache
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: <Site removed by issue logger>
2: <Site removed by issue logger>
3: <Site removed by issue logger>
4: www.shitouttaluck.co.uk
5: www.stupid-cunt.co.uk
6: <Site removed by issue logger>
7: <Site removed by issue logger>
blank to select all options shown (Enter 'c' to cancel): 4
This then generates the error from above.
I have left 5 showing as this is a working config (don't be displeased, they let me buy them. i didn't think profanity was allowed in DNS names)
I then have to disable the site that isn't working and restart apache as this error causes Apache to barf and crash out.
Any help gratefully recieved
What shows?:
sudo apachectl -t -D DUMP_VHOSTS
and certbot logs:
/var/log/letsencrypt/letsencrypt.log
VirtualHost configuration:
77.68.94.253:80        is a NameVirtualHost
         default server www.arightoldrant.co.uk (/etc/apache2/sites-enabled/le-redirect-www.arightoldrant.co.uk.conf:1)
         port 80 namevhost www.arightoldrant.co.uk (/etc/apache2/sites-enabled/le-redirect-www.arightoldrant.co.uk.conf:1)
         port 80 namevhost www.arightoldrant.com (/etc/apache2/sites-enabled/le-redirect-www.arightoldrant.com.conf:1)
         port 80 namevhost www.influenceoperations.co.uk (/etc/apache2/sites-enabled/le-redirect-www.influenceoperations.com.conf:1)
         port 80 namevhost www.onyourdesktop.com (/etc/apache2/sites-enabled/le-redirect-www.onyourdesktop.com.conf:1)
77.68.94.253:443       is a NameVirtualHost
         default server www.arightoldrant.co.uk (/etc/apache2/sites-enabled/arightoldrant.co.uk.conf:1)
         port 443 namevhost www.arightoldrant.co.uk (/etc/apache2/sites-enabled/arightoldrant.co.uk.conf:1)
                 alias www.arightoldrant.co.uk
         port 443 namevhost www.arightoldrant.com (/etc/apache2/sites-enabled/arightoldrant.com.conf:1)
                 alias www.arightoldrant.com
         port 443 namevhost www.dirty-thongs.com (/etc/apache2/sites-enabled/dirty-thongs.conf:1)
                 alias www.dirty-thongs.com
         port 443 namevhost www.influenceoperations.co.uk (/etc/apache2/sites-enabled/influenceoperations.co.uk.conf:1)
                 alias www.influenceoperations.co.uk
         port 443 namevhost www.onyourdesktop.com (/etc/apache2/sites-enabled/onyourdesktop.com.conf:1)
                 alias www.onyourdesktop.com
         port 443 namevhost www.stupid-cunt.co.uk (/etc/apache2/sites-enabled/stupid-cunt.conf:1)
                 alias www.stupid-cunt.co.uk
*:80                   www.tiny-thongs.com (/etc/apache2/sites-enabled/000-default.conf:1)
*:443                  www.tiny-thongs.com (/etc/apache2/sites-enabled/default-ssl.conf:2)
Please show the file you disabled.
Also, using IPs in vhost configs can be problematic:
77.68.94.253:80
77.68.94.253:443
<VirtualHost www.shitouttaluck.co.uk:443>
    ServerName www.shitouttaluck.co.uk
    DocumentRoot /var/www/html/shitouttaluck/
    ErrorLog ${APACHE_LOG_DIR}/shitouttaluck.error.log
    CustomLog ${APACHE_LOG_DIR}/shitouttaluck.access.log combined
    SSLEngine on
    SSLProtocol all -SSLv2 -SSLv3 -TLSv1 -TLSv1.1
    SSLCipherSuite HIGH:!aNULL:!MD5
    SSLHonorCipherOrder on
    SSLCompression      off
    SSLSessionTickets   off
    <FilesMatch "\.(cgi|shtml|phtml|php)$">
                   SSLOptions +StdEnvVars
    </FilesMatch>
    <Directory /usr/lib/cgi-bin>
    </Directory>
    # For Wordpress
    <Directory /var/www/html/shitouttaluck/>
    Options +FollowSymlinks
    AllowOverride All
    Require all granted
    </Directory>
    ServerAlias www.shitouttaluck.co.uk
</VirtualHost>
That's even worse!
LOL
And the redirect
<VirtualHost www.shitouttaluck.co.uk:80>
ServerSignature Off
RewriteEngine On
ErrorLog /var/log/apache2/redirect.error.log
LogLevel warn
</VirtualHost>
Are those two separate files?
Have i been doing vhost wrong all these years?
I don't know...
You never even answered the question.
They can be separate files.
Only you mentioned disabling "the site" and a thought one file.
yes, two seperate files
shitouttaluck.conf for SSL
le-redirect-shitouttaluck.conf for HTTP
and I just kept the french bit because I couldn't be bothered changing it
OK, well enough.
Take the name out of the virtualhost lines [throughout all files].
Put the names closer together, and use both names:
    ServerAlias shitouttaluck.co.uk
Put both names in both files.
The HTTP server block seems to lack the base domain.
That's redundant - LOL
Funny, I read that as LE [LetsEncrypt], while you read it in French [the].
LE redirect ...
the redirect ...
Do you you mean like this?
I was under the impression that NamedVirtualHosts were the way HTTP differentiated on a multi tennented IT.
<VirtualHost :443 >
    SSLEngine on
    SSLCompression      off
    </FilesMatch>
    </Directory>
    # For Wordpress
    AllowOverride All
    Require all granted
    </Directory>
</VirtualHost>
No. like:
<VirtualHost *:443 >
And they usually go in the other order [name first, then alias(es)]:
You don't have an SSLCertificateFile and SSLCertificateKeyFile configured in this virtual host.
This isn't valid from Apache's perspective.
You'll have to either comment out this virtual host or put in a snakeoil certificate, before you'll be able to start Apache and use certbot --apache.
Using a name [in virtualhost] as a separator does nothing, when all the names resolve to the same IP anyway.
The covered server names are the separation.
@rg305 Thanks for your help here. All renamed. I have created another issue but it's a rouge domain I don't have appearing somewhere. a bit of prepping will hopefully find it.
Then I will get round to retrying the certbot along with @_az bit about 'snakeoil' cert :slight_smile:
Ok that has now all worked and I am getting certs as I need.
Final question to @_az
I have the following pair showing
7: shitouttaluck.co.uk
8: www.shitouttaluck.co.uk
and the same for all my other vhosts. Should I just get all my vhosts up and running and then just hit Enter? will this generate the same cert for all 16 sites or individual ones p[er site?
