Problem with unkownHost after several hours
tallifnatt.catears.se
sudo certbot --authenticator webroot --webroot-path /var/www --installer apache
Plugins selected: Authenticator webroot, Installer apache
1: tallifnatt.catears.se
blank to select all options shown (Enter ‘c’ to cancel): 1
http-01 challenge for tallifnatt.catears.se
Using the webroot path /var/www for all unmatched domains.
Waiting for verification…
Failed authorization procedure. tallifnatt.catears.se (http-01): urn:acme:error:unknownHost :: The server could not resolve a domain name :: No valid IP addresses found for tallifnatt.catears.se
    Domain: tallifnatt.catears.se
    Type: unknownHost
    Detail: No valid IP addresses found for tallifnatt.catears.se
Server version: Apache/2.4.18 (Ubuntu)
Ubuntu 16.04
no
I have tried to create a certificate with the help of letsencrypts and certbot. It has worked previously on other servers that I own but did not for this one. I got the message I pasted above which suggests that letsencrypt cannot find my server, however when I use my browser and when I use dig (dig tallifnatt.catears.se or dig @8.8.8.8 tallifnatt.catears.se) it gives me the right IP-address. I am not an expert with these things so I would really like some help figuring out why this isn’t working…
tallifnatt.catears.se.  (signed)  3515  A  100.64.43.225
That isn’t a public IP address. It’s a private, shared IP address reserved for Carrier-Grade NAT, similar to how 192.168.x.y addresses are for local networks.
You need a public IP address, IPv4 or IPv6, for Let’s Encrypt HTTP validation.
You can use DNS validation instead, but if you want to run a public website, you would still have a problem…
