www.iyocard.com
D:\letsencrypt>letsencrypt.exe --accepttos --manualhost www.iyocard.com --webroot D:\YO
Authorizing Identifier www.iyocard.com Using Challenge Type http-01
Writing challenge answer to D:\letsencrypt.well-known/acme-challenge/TITM_QV1q
4ADJ7e1OVinqpVbY0qSyeghQV4SEdMl-Dk
Answer should now be browsable at http://www.iyocard.com/.well-known/acme-chall
enge/TITM_QV1q4ADJ7e1OVinqpVbY0qSyeghQV4SEdMl-Dk
Submitting answer
Authorization Result: valid
Requesting Certificate
Request Status: Created
Saving Certificate to C:\Users\Administrator\AppData\Roaming\letsencrypt-win-si
mple\httpsacme-v01.api.letsencrypt.org\www.iyocard.com-crt.der
System.IO.IOException: ???
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.__Error.WinIOError()
at System.IO.Path.InternalGetTempFileName(Boolean checkHost)
at LetsEncrypt.ACME.Simple.Program.GetIssuerCertificate(CertificateRequest ce
rtificate, CertificateProvider cp)
at LetsEncrypt.ACME.Simple.Program.GetCertificate(Target binding)
at LetsEncrypt.ACME.Simple.Program.Auto(Target binding)
at LetsEncrypt.ACME.Simple.Plugin.Auto(Target target)
at LetsEncrypt.ACME.Simple.ManualPlugin.HandleMenuResponse(String response, L
ist`1 targets)
at LetsEncrypt.ACME.Simple.Program.Main(String args)
Press enter to continue.
iis7
WINDOWS SERVER 2008
aws
My old certificate expired on 10 Dec 18, when I ran the update command today, I got the above error message. Please help me,many thank for you.
