Cert not renewing but no errors?
My domain is: portal.jccscpa.com
I ran this command:letsencrypt.exe --renew --baseuri “https://acme-v01.api.letsencrypt.org/
It produced this output:letsencrypt.exe --renew --baseuri "https://acme-v01.api.letsencrypt.org/"
Let’s Encrypt (Simple Windows ACME Client)
Renewal Period: 60
Certificate Store: WebHosting
ACME Server: https://acme-v01.api.letsencrypt.org/
Config Folder: C:\Users\Administrator\AppData\Roaming\letsencrypt-win-simple\httpsacme-v01.api.letsencrypt.org
Certificate Folder: C:\Users\Administrator\AppData\Roaming\letsencrypt-win-simple\httpsacme-v01.api.letsencrypt.org
Loading Signer from C:\Users\Administrator\AppData\Roaming\letsencrypt-win-simple\httpsacme-v01.api.letsencrypt.org\Signer
Getting AcmeServerDirectory
Loading Registration from C:\Users\Administrator\AppData\Roaming\letsencrypt-win-simple\httpsacme-v01.api.letsencrypt.org\Registration
Checking Renewals
Checking IIS Portal.jccscpa.com (E:\Doc-ItWebPortal\Website) Renew After 3/3/2017
My operating system is (include version): Windows server 2008 R2 fully patched
My web server is (include version): IIS 7.5
I can login to a root shell on my machine (yes or no, or I don’t know): Windows but yes
Does IIS have to be reloaded after certificate renewal? I know all *nix based webservers need a reload of the sorts.
I don’t think so but during this testing I have performed an IISReset as well as rebooted the entire server. What’s interesting is that the cert says that it will expire 1/31/2017 but the information returned when I ran letsencrypt.exe says that it should expire in March.
-CM
Hello @CanyonMan,
Seems a bug of your letenscrypt-win-simple client, other people is having issues renewing their certs https://github.com/Lone-Coder/letsencrypt-win-simple/issues/308 so maybe you could get more help posting your issue on github page.
I don’t use Windows so I can’t recommend any alternative to letsencrypt-win-simple but you could check the list of Windows clients, maybe other could fit your needs better than the current one
Cheers,
sahsanu
