Problem with sign cert for multi domain
I have a problem extending the certificate, I have generated a new one and I need to sign it. The certificate is for: www.klenovka.cz klenovka.cz mail.klenovka.cz
I got an error:
Certificate signature failed. If you have your own CSR make sure the domains on it match what you put on SSLForFree. If there is a limiting error at the end of this paragraph certificates per Domain is currently 5 per 7 days. Try asking Lets Encrypt to increase the limit or wait 7 days. Rate limits should increase in the near future. {“type”: “urn: ietf: params: acme: error: malformed”, “detail”: “IP address fields”, “status”: 400}
Can you help me, please?
Can you please increase the limit to approx. 14 days?
Thank you
Doleček
Hi @dolecekm
please share your CSR. Looks like you have used a wrong domain name.
You have one old Letsencrypt certificate ( https://check-your-website.server-daten.de/?q=klenovka.cz ):
CertSpotter-Id Issuer not before not after Domain names LE-Duplicate next LE
811016898 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-03-14 18:04:28 2019-06-12 18:04:28 klenovka.cz, mail.klenovka.cz, www.klenovka.cz - 3 entries
So you didn't hit any limit - creating 5 identical certificates in the last 7 days.
The message hasn't to do something with your error message.
