Problem with renewing SSL
My domain is: shoppotinsurance.com
My web server is (include version): Apache/2.4.27 (Unix)
The operating system my web server runs on is (include version): Bitnami
My hosting provider, if applicable, is: Amazon Lightsail
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Yes
Hello:
I renewed my certificate before the expiration. However, I noticed on the day it was to expire, the website was no longer secure. I’m wondering how to diagnose and fix the problem.
Thank you
Hi @gpia,
Renewal doesn’t change the expiration of the previous certificate. Instead, it means the issuance of a new certificate referring to the same domain names.
You’ve issued several new certificates for your domain name
https://crt.sh/?Identity=%shoppotinsurance.com&iCAID=16418
but none of the new certificates is in use on your web server. You’ll need to install a new certificate in your web server application in order to make use of it.
Maybe try just restarting your apache?
sudo /opt/bitnami/ctlscript.sh restart apache
You should also check the certificate file is updating by checking the time on the files:
sudo ls -al /etc/letsencrypt/live/shoppotinsurance.com/
I’m assuming your using the letsencrypt-auto command
