Revelli
February 28, 2020, 5:02pm
1
Invalid response from https://acme-v02.api.letsencrypt.org/acme/new-order .
Details:
Type: urn:ietf:params:acme:error:rateLimited
Status: 429
Detail: Error creating new order :: too many certificates already issued for exact set of domains: immobiliaremalmassari.com ,www.immobiliaremalmassari.com : see https://letsencrypt.org/docs/rate-limits/
Osiris
February 28, 2020, 5:20pm
2
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
Revelli
February 28, 2020, 6:08pm
3
Osiris:
My domain is: immobiliaremalmassari.com
I’m using a control panel to manage my site: PLESK
Command with all certificates request: crt.sh | immobiliaremalmassari.com
You have reached your limit for creating certs for that set of domains.
See
crt.sh indicate you have a lot of certificates for that domain? Why can’t you use one that is already issued?
Are you sure ?
After 1 week all the certificates reset
I’ve just tried again to install let’s encrypt certificate on the domain and now there is another error:
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/3112075038 .
Details:
Type: urn:ietf:params:acme:error:dns
Status: 400
Detail: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.immobiliaremalmassari.com - check that a DNS record exists for this domain
But this certificates not run correctly!
Yesterday i’ve tried again to install new certifcate, and Plesk tell me another message error, look here:
Details:
Status: 400
Hi guys, yesterday I’ve tried again to install certificate, and Plesk send me a new errore message:
Details:
Status: 400
That's correct. That's what the article says.
You have set Plesk to do the DNS authorization (required if you are requesting a wildcard) . Your nameservers are as follows:
immobiliaremalmassari.com. 59 IN NS [dns113.ovh.net.]
immobiliaremalmassari.com. 59 IN NS [ns113.ovh.net.]
Plesk should have given you a message with a value to manually put into a TXT record on your DNS Zone because it's not managing your DNS.
Hi, but Plesk put automatically RECORD TXT in DNS ZONE
I’ve seen with my eyes the correct record
So the record is on the Plesk DNS system, but it’s not on your actual DNS host:
# dig _acme-challenge.immobiliaremalmassari.com TXT
; <<>> DiG 9.11.3-1ubuntu1.11-Ubuntu <<>> _acme-challenge.immobiliaremalmassari.com TXT
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 8652
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 65494
;; QUESTION SECTION:
;_acme-challenge.immobiliaremalmassari.com. IN TXT
Wich is the solution, if you know…
Manually create the TXT record on your actual DNS host platform.
I did it, but didn't solve the problem
May be a bug in Let's Encrypt?
Did it where? On your ovh.net control panel? I still don’t see the records:
# dig TXT _acme-challenge.immobiliaremalmassari.com
; <<>> DiG 9.11.3-1ubuntu1.11-Ubuntu <<>> TXT _acme-challenge.immobiliaremalmassari.com
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 33179
# dig TXT immobiliaremalmassari.com
; <<>> DiG 9.11.3-1ubuntu1.11-Ubuntu <<>> TXT immobiliaremalmassari.com
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 60794
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
;immobiliaremalmassari.com. IN TXT
;; ANSWER SECTION:
immobiliaremalmassari.com. 60 IN TXT "v=spf1 include:mx.ovh.com ~all"
immobiliaremalmassari.com. 60 IN TXT "1|www.immobiliaremalmassari.com"
