Could not issue an SSL/TLS certificate for
My domain is: plantknowledgemaster.com
I ran this command: plesk -> Extensions -> Secure plesk with a free SSL/TLS certificate
It produced this output: Could not issue an SSL/TLS certificate for plantknowledgemaster.com
Details
Could not issue a Let's Encrypt SSL/TLS certificate for plantknowledgemaster.com.
One of the Let's Encrypt rate limits has been exceeded for plantknowledgemaster.com.
See the related Knowledge Base article for details.
Details
Invalid response from https://acme-v02.api.letsencrypt.org/acme/new-order.
Details:
Type: urn:ietf:params:acme:error:rateLimited
Status: 429
Detail: Error creating new order :: too many failed authorizations recently: see Failed Validation Limit - Let's Encrypt
My hosting provider, if applicable, is: https://www.hosting.kr/
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): not sure
You've tried too often too fast and now this temporary rate limit error is causing the REAL problem being "hidden".
That said, using LetsDebug.net, there seem to be some DNS issues:
(http-01 challenge)
(tls-alpn-01 challenge)
(dns-01 challenge)
I have no clue which challenge Plesk is using, but all tests give hint at a DNS issue. Which is corroborated by
https://unboundtest.com/m/A/plantknowledgemaster.com/LWGMJEWE
and
https://dnsviz.net/d/plantknowledgemaster.com/ZjTefg/dnssec/
Please fix your DNS and try again (after the rate limit has been lifted).
Also:
How can you not be sure while you're clearly using Plesk? :thinking:
@knowledgemaster is your issue solved?
It looks like a certificate was successfully issued crt.sh | 12939773968
        Serial Number:
            03:ce:c0:fe:18:7a:14:26:1c:c2:8c:a6:38:6d:3c:91:bd:af
        Validity
            Not Before: May  3 12:26:12 2024 GMT
            Not After : Aug  1 12:26:11 2024 GMT
And that that certificate is presently being served as shown here https://decoder.link/sslchecker/plantknowledgemaster.com/443
Looking at an updated DNSViz run, their DNS currently seems to be working and thus also certificate issuance.
