Hi
i have problem and dont know what to do.
or certbot-auto --version
if you're using Certbot):
Further more, port 80 needs to be open for the entire internet. Looks like you're partly blocking some IP ranges.
Hi @dpawlak, and welcome to the LE community forum
Please answer the questions posted above.
The more information you provide the better/faster we can help you.
That said, "During secondary validation" implies the primary validation was successful.
Add "Timeout during connect (likely firewall problem)" and it looks like you might have some sort of GeoLocation blocking going on.
As far as I can tell
And it seems the HTTP-01 Challenge is wrongly redirected.
Supplemental information:
$ curl -Ii http://domowe-abc.pl/.well-known/acme-challenge/sometestfile
Date: Wed, 01 Mar 2023 22:11:58 GMT
Server: Apache
Connection: close
$ curl -Ii https://domowe-abc.pl/404.shtml
HTTP/1.1 404 Not Found
Date: Wed, 01 Mar 2023 22:12:24 GMT
Server: Apache
X-Powered-By: PHP/7.3.6
Expires: Wed, 11 Jan 1984 05:00:00 GMT
Cache-Control: no-cache, must-revalidate, max-age=0
Link: <https://domowe-abc.pl/wp-json/>; rel="https://api.w.org/"
Vary: Accept-Encoding,User-Agent
Connection: close
