Problem with downloading SSL
My domain is: sisregmed.tech
I ran this command: sudo certbot certonly --webroot -w /var/www/html -d sisregmed.tech -d www.sisregmed.tech
Requesting a certificate for sisregmed.tech and www.sisregmed.tech
Domain: sisregmed.tech
Detail: 2a02:4780:b:1341:0:2924:a0ab:2: Invalid response from http://sisregmed.tech/.well-known/acme-challenge/SEwmLbD7GWaxN-SF0OBMghs7tcvp4J2NByG8-bkPgHM: 404
Domain: www.sisregmed.tech
Detail: 2a02:4780:b:1341:0:2924:a0ab:2: Invalid response from http://www.sisregmed.tech/.well-known/acme-challenge/Dfj_NKWcGkIbuwP1l5pqqPeBrjDHYJnnGZ6OmWJlD0g: 404
My web server is (include version): Ubuntu 24.04.
The operating system my web server runs on is (include version): Ubuntu 24.04.
Guys, I´m total newbie deploying APPS. But, I try, so I HOPE some one can help me.
The IP in that error message is a Hostinger IPv6 address. Are they your hosting service?
You have both an IPv4 A record and an IPv6 AAAA record in your DNS. It looks to me like these are pointing to a Hostinger service and are not the public IP for your server. Hostinger creates these DNS records automatically for new setups.
More info from the questions would be helpful. Like what kind of server you are running. Ubuntu is the operating system not a server.
You may find this article helpful: How to manage AAAA records | Hostinger Help Center
Hi.
I have a VPS in Hostinger, so, the IA give me those steps in order to download / install the SSL. And for some reasson it´s not working, so, the IA give the same steps and don´t change. In order words: "I´m cycling with the IA, trying to fix this issue with the same result".
Regards!
I would not want to interfere with that process. When you are finished with them then please answer the questions from the form and that I asked about. We don't have enough info to give advice. The more you provide the more likely we can help.
It will get confusing if you get advice from someone here and also advice from that IA. So, wait until finished with them.
