Problem with Certification
My domain is: 20b20t.org
┌──(root㉿Gateway)-[/var/www/letsencrypt/.well-known/acme-challenge]
└─# sudo certbot certonly --webroot
-w /var/www/letsencrypt
-d 20b20t.org -d www.20b20t.org
--staging --debug-challenges
--agree-tos --email VincentBusinessMail@web.de --no-eff-email
Challenges loaded. Press continue to submit to CA.
Pass "-v" for more info about challenges.
Press Enter to Continuels -la
Domain: 20b20t.org
Type: dns
Detail: 91.98.225.37: Fetching 20b20t.org DNS problem: networking error looking up A for 20b20t.org; DNS problem: networking error looking up AAAA for 20b20t.org
Domain: www.20b20t.org
Detail: 91.98.225.37: Invalid response from 20b20t.org "\n<html lang="en">\n \n <meta charset="utf-8">\n <!-- Always force latest IE rendering engine or request"
Webserver: Newest NGINX version
Gateway: Newest NGINX version
Cloud and Selfhosted | SSH
Certbot Version:
└─# certbot --version
certbot 4.0.0
My NGINX configs:
Gateway:
┌──(root㉿Gateway)-[/etc/nginx/sites-available]
└─# cat proxy
listen 80 default_server;
location ^~ /.well-known/acme-challenge/ {
    root /var/www/letsencrypt;
    default_type "text/plain";
    proxy_pass http://100.64.0.5:80;
    proxy_set_header Host $host;
listen 80;
listen [::]:80;
server_name 20b20t.org www.20b20t.org *.20b20t.org;
# Certbot / ACME-Challenge direkt auf dem Gateway bedienen
# Alles andere zum internen Webserver
Webserver:
root@Webserver:/etc/nginx/sites-available# cat all-domains
listen 80;
server_name 20b20t.org www.20b20t.org forum.20b20t.org;
root /var/www/20b20t.org;
index index.php index.html;
    try_files $uri $uri/ /index.php?$args;
location ~ \.php$ {
    include snippets/fastcgi-php.conf;
    fastcgi_pass unix:/run/php/php8.4-fpm.sock;
and
root@Webserver:/etc/nginx/sites-available# cat 20b20t.org.conf
listen 80;
server_name 20b20t.org www.20b20t.org;
location ~ \.php$ {
client_max_body_size 100M;
access_log /var/log/nginx/20b20t_access.log;
error_log /var/log/nginx/20b20t_error.log;
This can be closed.
Used the TXT DNS method.
