There were too many requests of a given type :: Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/. Skipping.
/usr/bin/certbot-auto renew --dry-run --standalone --preferred-challenges tls-sni -
Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA.
Attempting to renew cert (privacyaudit.me) from /etc/letsencrypt/renewal/privacyaudit.me.conf produced an unexpected error: Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA… Skipping.
/etc/letsencrypt/live/privacyaudit.me/fullchain.pem (failure)
http-01 challenge for privacyaudit.me
http-01 challenge for www.privacyaudit.me
Waiting for verification…
Attempting to renew cert (privacyaudit.me) from /etc/letsencrypt/renewal/privacyaudit.me.conf produced an unexpected error: Failed authorization procedure. privacyaudit.me (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://privacyaudit.me/.well-known/acme-challenge/aC7sndlIOXQok9Vy7OGn6XR9GHK6jb28lhre9qYD0s0: Timeout during connect (likely firewall problem), www.privacyaudit.me (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://www.privacyaudit.me/.well-known/acme-challenge/jFOKqVJiPIN2ittxX8xvWvE7MDCz4Lso2mlXFvnmI-E: Timeout during connect (likely firewall problem). Skipping.
It looks like it really is a “firewall”/routing problem.
AWS runs a firewall (must allow port 80 in)
Then your server runs a firewall (must allow port 80 in)
Then your server must forward port 80 to proper docker instance (docker settings).
Yes, now i start docker containers with site, and curl -v to http://privacyaudit.me/ return 302 status (it's ok). So 80 port can be accesseble from Internet.
And no, exact command to get cert i do not remember, sorry
