My domain is: sesstim4.timone.univ-amu.fr
I ran this command: sudo certbot -v --apache
Enter email address (used for urgent renewal and security notices)
(Enter 'c' to cancel): jean-charles.dufour@univ-amu.fr
https://letsencrypt.org/documents/LE-SA-v1.3-September-21-2022.pdf. You must
agree in order to register with the ACME server. Do you agree?
(Y)es/(N)o: Y
Would you be willing, once your first certificate is successfully issued, to
share your email address with the Electronic Frontier Foundation, a founding
partner of the Let's Encrypt project and the non-profit organization that
develops Certbot? We'd like to send you email about our work encrypting the web,
EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: Y
Account registered.
1: sesstim4.timone.univ-amu.fr
Requesting a certificate for sesstim4.timone.univ-amu.fr
http-01 challenge for sesstim4.timone.univ-amu.fr
Challenge failed for domain sesstim4.timone.univ-amu.fr
Domain: sesstim4.timone.univ-amu.fr
Type: connection
Detail: 139.124.158.220: Fetching http://sesstim4.timone.univ-amu.fr/.well-known/acme-challenge/IsMkt-drXl9s1dch_25Ca6ESRQJEtOHiCu2wgv4gscI: Connection reset by peer
My web server is (include version): Apache/2.4.52 (Ubuntu) buitl: 2023-05-03T20:02:51
The operating system my web server runs on is (include version): ubuntu server 22.04.3 LTS
My hosting provider, if applicable, is: Aix Marseille Université
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.21.0
I suspect a problem with WSGI because I have Flask applications served by apache. However my virtual-host enabled should handle this. I don't understand what's wrong. Perhaps a legal problem? Because the "acme-challenge" folder is not created after the sudo certbot -v --apache command.
Here are my virtual-host.conf and virtual-host-ssl.conf files (for the moment I'm temporarily using ZeroSSL, but I'd like to switch to certbot/let's encrypt)
<VirtualHost *:80>
ServerName sesstim4.timone.univ-amu.fr
# ServerAlias sesstim4.timone.univ-amu.fr
ServerAdmin jean-charles.dufour@univ-amu.fr
DocumentRoot /var/www/html
# pour application agendaradar
# Utilisation de IfDefine pour gérer le bug de certbot cf. ici https://github.com/certbot/certbot/issues/8373
<IfDefine !wsgi_init>
WSGIDaemonProcess agendaradar python-path=/var/www/jcd_flask_apps/agendaradar:/var/www/jcd_flask_apps/agendaradar/venv/lib/python3.10/site-packages
WSGIProcessGroup agendaradar
WSGIScriptAlias /agendaradar /var/www/jcd_flask_apps/agendaradar/agendaradar.wsgi
Define wsgi_init 1
</IfDefine>
<Directory /var/www/jcd_flask_apps/agendaradar>
Require all granted
</Directory>
# pour application agendareconduction
<IfDefine !wsgi_init_agendareconduction>
WSGIDaemonProcess agendareconduction python-path=/var/www/jcd_flask_apps/agendareconduction:/var/www/jcd_flask_apps/agendareconduction/venv/lib/python3.10/site-packages
WSGIProcessGroup agendareconduction
WSGIScriptAlias /agendareconduction /var/www/jcd_flask_apps/agendareconduction/agendareconduction.wsgi
Define wsgi_init_agendareconduction 1
</IfDefine>
<Directory /var/www/jcd_flask_apps/agendareconduction>
Require all granted
</Directory>
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
#RewriteEngine on
#RewriteCond %{SERVER_NAME} =sesstim4.timone.univ-amu.fr
#RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
<IfModule mod_ssl.c>
<VirtualHost *:443>
# specifies what hostname must appear in the request's Host: header to
SSLEngine on
SSLCertificateFile /etc/ssl/certificate.crt
SSLCertificateKeyFile /etc/ssl/private/private.key
SSLCertificateChainFile /etc/ssl/ca_bundle.crt
#WSGIProcessGroup agendaradar
<Location /agendaradar>
</Location>
Define wsgi_init 1
</IfDefine>
Require all granted
</Directory>
#WSGIProcessGroup agendareconduction
<Location /agendareconduction>
</Location>
</IfDefine>
Require all granted
</Directory>
# modules, e.g.
</VirtualHost>
</IfModule>
Thank you for your help.
