Problem while running letsencrypt script
I’ve used letsencrypt to produce auto ssl on zimbra
I entered a correct domain and webroot path of nginx, but I get an error yet!
    Domain: mail…ir
    Type: connection
    Detail: Fetching
    http://mail…ir/.well-known/acme-challenge/RHx9VMzoGpsZPpCS1s1HAvFreiLdHD2xsZ-G_9l7Dm0:
    Timeout
It’s hard to say.
What’s the real domain?
Is it accessible from the Internet?
If it has IPv6, does it work?
mail.demo.20row.ir
It is accessible from the internet. It doesn’t have IPv6.
It isn’t working here or with any of the countries at https://tools.keycdn.com/ping. Not even from within Iran, according to lg.iranet.ir. :slightly_frowning_face:
I corrected the problem that you have mentioned, now I get below error:
If you create a file /path/to/your/webroot/.well-known/acme-challenge/test.txt does it show up at http://mail.demo.20row.ir/.well-known/acme-challenge/test.txt or do you also get an error?
Do you perhaps have an .htaccess file in the top level of your webroot that may be interfering with allowing your webserver to serve this file?
