Certificate installation issues
Hi there,
Please I need your help!!!
I am trying to install LetsEncrypt certificate on my zimbra server (8.7.0) which is installed on ubuntu 14.04. My domain name is uam.edu.ne. I have been strugling on this for several weeks now but in vain.
After downloading the certificate I cd to Letsencript directory and typed the command below:
./letsencrypt-auto certonly --standalone
When the command executed it returned the following output:
Failed authorization procedure. uam.edu.ne (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: SERVFAIL looking up A for uam.edu.ne
    Domain: uam.edu.ne
    Type: connection
    Detail: DNS problem: SERVFAIL looking up A for uam.edu.ne
Please help me.
thank you in advance
There's your problem--the Let's Encrypt servers couldn't find any DNS record for your hostname, because they couldn't connect to the authoritative nameserver for your hostname. I note that you have only one nameserver record, which is generally a bad idea, and that you're running it yourself (indeed, on the same machine), which is also often a bad idea. But with that said, I'm now able to connect to your nameserver, and it does respond to queries for your hostname--what happens if you try again?
I think the problem is possibly:
uam.edu.ne has IPv6 address ::1
In IPv6 this refers to localhost. So it’s not really the correct IPv6 address under which other people can reach the site.
While this wouldn’t normally cause a SERVFAIL error in particular, it’s still a serious DNS problem because the Let’s Encrypt CA now does support, and perform, validations over IPv6. So if you give ::1 as your IPv6 address instead of a correct publicly-reachable IPv6 address, I imagine that would cause problems too.
I just tried to issue a (staging) certificate for that site, and the DNS worked. Of course validation failed because i don’t control your website, but the DNS part functioned correctly.
http://dnsviz.net/d/uam.edu.ne/dnssec/
The DNS servers for the .ne TLD look buggy and/or unreliable. Which may partly or entirely be because of the distance between Africa and US services.
What happens if you try again? It may have just been a temporary issue that will work if you give it a couple tries.
You should still remove that ::1 AAAA record so it doesn’t cause problems for your site’s visitors, though.
Hi mnordhoff,
Thank you very much for your prompt response.
As you suggested we have removed the ::1 AAAA record and gave it several tries but unfortunately we continue having the same error message as follows:
Domain: uam.edu.ne
Domain: uam.edu.ne
Type: connection
Hi mnordhoff,
Thank you very much for your prompt response.As you suggested we have removed the ::1 AAAA record and gave it several tries but unfortunately we got another error message as follows:
Failed authorization procedure. uam.edu.ne (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Failed to connect to 41.138.51.99:443 for TLS-SNI-01 challenge
    Domain: uam.edu.ne
    Type: connection
    Detail: Failed to connect to 41.138.51.99:443 for TLS-SNI-01
    challenge
Best regards!!!
The TLS-SNI-01 connection failure shows that it got further than before! That’s a new problem!
