titchen
August 16, 2019, 12:57pm
#1
My domain is: titchen.co
sudo nano /opt/bitnami/letsencrypt/scripts/renew-certificate.sh
I cannot save the file to set the auto renewal. My certificate is about to expire.
I try to follow step 5 of this guide https://docs.bitnami.com/aws/how-to/generate-install-lets-encrypt-ssl/ as I am using Bitnami
Please help!!!
Hi @titchen
run the nano as root / sudo.
And you must replace the mail address and the domains with your own values. Not "DOMAIN", that's not your domain name.
Hi @JuergenAuer ,
thanks!
I ran
When trying to save the script, it is still the same:
Please read your error output. And create the required directories. Or use another directory.
@JuergenAuer
Thanks. Would you be able to provide instructions on how to create the directory? I already have the certificate installed, I thought the directory was created.
Any way I can check and/or create?
Thanks!
Tina
system
closed
September 15, 2019, 2:30pm
#6
