kukumo.net
from directAdmin -> install SSL certificate
Requesting new certificate order…
Nonce is empty. Exiting. dig output of acme-v02.api.letsencrypt.org:
api.letsencrypt.org-ng.edgekey.net.
e14990.dscx.akamaiedge.net.
23.77.106.26
Apache (2.4.39)
CentOS (7.2)
VPS with sharedIP
DirectAdmin (1.57.2)
or certbot-auto --version
if you’re using Certbot):
PROBLEM:
i switched my old VPS to a New CentOS7, which supports multicertificates on same IP (190.105.227.167).
I successfully added LetsEncrypt certificate on 3 Domains with this IP (vecinosenred.net, ecampus.net, edupatagonia.com.ar), but im getting this error on my MAIN domain (kukumo.net) with same IP.
thanks in advance!
