My domain is: ykkosbasaari.fi
I ran this command: Install SSL via CentOS Web Panel
[Fri Sep 27 11:50:07 EEST 2019] _main_domain='www.ykkosbasaari.fi'
[Fri Sep 27 11:50:07 EEST 2019] _alt_domains='ykkosbasaari.fi'
[Fri Sep 27 11:50:07 EEST 2019] Using config home:/root/.acme.sh
[Fri Sep 27 11:50:07 EEST 2019] ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:07 EEST 2019] DOMAIN_PATH='/root/.acme.sh/cwp_certs/www.ykkosbasaari.fi'
[Fri Sep 27 11:50:07 EEST 2019] Using ACME_DIRECTORY: https://acme-v01.api.letsencrypt.org/directory
[Fri Sep 27 11:50:07 EEST 2019] _init api for server: https://acme-v01.api.letsencrypt.org/directory
[Fri Sep 27 11:50:07 EEST 2019] GET
[Fri Sep 27 11:50:07 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:07 EEST 2019] timeout=
[Fri Sep 27 11:50:07 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:50:08 EEST 2019] ret='0'
[Fri Sep 27 11:50:08 EEST 2019] ACME_KEY_CHANGE='https://acme-v01.api.letsencrypt.org/acme/key-change'
[Fri Sep 27 11:50:08 EEST 2019] ACME_NEW_AUTHZ='https://acme-v01.api.letsencrypt.org/acme/new-authz'
[Fri Sep 27 11:50:08 EEST 2019] ACME_NEW_ORDER='https://acme-v01.api.letsencrypt.org/acme/new-cert'
[Fri Sep 27 11:50:08 EEST 2019] ACME_NEW_ACCOUNT='https://acme-v01.api.letsencrypt.org/acme/new-reg'
[Fri Sep 27 11:50:08 EEST 2019] ACME_REVOKE_CERT='https://acme-v01.api.letsencrypt.org/acme/revoke-cert'
[Fri Sep 27 11:50:08 EEST 2019] ACME_AGREEMENT='https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf'
[Fri Sep 27 11:50:08 EEST 2019] ACME_NEW_NONCE
[Fri Sep 27 11:50:08 EEST 2019] ACME_VERSION
[Fri Sep 27 11:50:08 EEST 2019] _on_before_issue
[Fri Sep 27 11:50:08 EEST 2019] _chk_main_domain='www.ykkosbasaari.fi'
[Fri Sep 27 11:50:08 EEST 2019] _chk_alt_domains='ykkosbasaari.fi'
[Fri Sep 27 11:50:08 EEST 2019] Le_LocalAddress
[Fri Sep 27 11:50:08 EEST 2019] d='www.ykkosbasaari.fi'
[Fri Sep 27 11:50:08 EEST 2019] Check for domain='www.ykkosbasaari.fi'
[Fri Sep 27 11:50:08 EEST 2019] _currentRoot='/usr/local/apache/autossl_tmp/'
[Fri Sep 27 11:50:08 EEST 2019] d='ykkosbasaari.fi'
[Fri Sep 27 11:50:08 EEST 2019] Check for domain='ykkosbasaari.fi'
[Fri Sep 27 11:50:08 EEST 2019] _saved_account_key_hash is not changed, skip register account.
[Fri Sep 27 11:50:08 EEST 2019] Read key length:
[Fri Sep 27 11:50:08 EEST 2019] Creating domain key
[Fri Sep 27 11:50:08 EEST 2019] Use DEFAULT_DOMAIN_KEY_LENGTH=2048
[Fri Sep 27 11:50:08 EEST 2019] Using config home:/root/.acme.sh
[Fri Sep 27 11:50:08 EEST 2019] ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:08 EEST 2019] Use length 2048
[Fri Sep 27 11:50:08 EEST 2019] Using RSA: 2048
[Fri Sep 27 11:50:09 EEST 2019] The domain key is here: /root/.acme.sh/cwp_certs/www.ykkosbasaari.fi/www.ykkosbasaari.fi.key
[Fri Sep 27 11:50:09 EEST 2019] _createcsr
[Fri Sep 27 11:50:09 EEST 2019] Multi domain='DNS:www.ykkosbasaari.fi,DNS:ykkosbasaari.fi'
[Fri Sep 27 11:50:09 EEST 2019] Getting domain auth token for each domain
[Fri Sep 27 11:50:09 EEST 2019] d='www.ykkosbasaari.fi'
[Fri Sep 27 11:50:09 EEST 2019] Getting webroot for domain='www.ykkosbasaari.fi'
[Fri Sep 27 11:50:09 EEST 2019] _w='/usr/local/apache/autossl_tmp/'
[Fri Sep 27 11:50:09 EEST 2019] _currentRoot='/usr/local/apache/autossl_tmp/'
[Fri Sep 27 11:50:09 EEST 2019] Getting new-authz for domain='www.ykkosbasaari.fi'
[Fri Sep 27 11:50:09 EEST 2019] _init api for server: https://acme-v01.api.letsencrypt.org/directory
[Fri Sep 27 11:50:09 EEST 2019] Try new-authz for the 0 time.
[Fri Sep 27 11:50:09 EEST 2019] url='https://acme-v01.api.letsencrypt.org/acme/new-authz'
[Fri Sep 27 11:50:09 EEST 2019] payload='{"resource": "new-authz", "identifier": {"type": "dns", "value": "www.ykkosbasaari.fi"}}'
[Fri Sep 27 11:50:09 EEST 2019] RSA key
[Fri Sep 27 11:50:09 EEST 2019] GET
[Fri Sep 27 11:50:09 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:09 EEST 2019] timeout=
[Fri Sep 27 11:50:09 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:50:10 EEST 2019] ret='0'
[Fri Sep 27 11:50:10 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:50:12 EEST 2019] GET
[Fri Sep 27 11:50:12 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:12 EEST 2019] timeout=
[Fri Sep 27 11:50:12 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:50:13 EEST 2019] ret='0'
[Fri Sep 27 11:50:13 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:50:15 EEST 2019] GET
[Fri Sep 27 11:50:15 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:15 EEST 2019] timeout=
[Fri Sep 27 11:50:15 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:50:16 EEST 2019] ret='0'
[Fri Sep 27 11:50:16 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:50:18 EEST 2019] GET
[Fri Sep 27 11:50:18 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:18 EEST 2019] timeout=
[Fri Sep 27 11:50:18 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:50:19 EEST 2019] ret='0'
[Fri Sep 27 11:50:19 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:50:21 EEST 2019] GET
[Fri Sep 27 11:50:21 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:21 EEST 2019] timeout=
[Fri Sep 27 11:50:21 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:50:22 EEST 2019] ret='0'
[Fri Sep 27 11:50:22 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:50:24 EEST 2019] GET
[Fri Sep 27 11:50:24 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:24 EEST 2019] timeout=
[Fri Sep 27 11:50:24 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:50:25 EEST 2019] ret='0'
[Fri Sep 27 11:50:25 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:50:27 EEST 2019] GET
[Fri Sep 27 11:50:27 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:27 EEST 2019] timeout=
[Fri Sep 27 11:50:27 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:50:28 EEST 2019] ret='0'
[Fri Sep 27 11:50:28 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:50:30 EEST 2019] GET
[Fri Sep 27 11:50:30 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:30 EEST 2019] timeout=
[Fri Sep 27 11:50:30 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:50:31 EEST 2019] ret='0'
[Fri Sep 27 11:50:31 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:50:33 EEST 2019] GET
[Fri Sep 27 11:50:33 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:33 EEST 2019] timeout=
[Fri Sep 27 11:50:33 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:50:34 EEST 2019] ret='0'
[Fri Sep 27 11:50:34 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:50:36 EEST 2019] GET
[Fri Sep 27 11:50:36 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:36 EEST 2019] timeout=
[Fri Sep 27 11:50:36 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:50:37 EEST 2019] ret='0'
[Fri Sep 27 11:50:37 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:50:39 EEST 2019] GET
[Fri Sep 27 11:50:39 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:39 EEST 2019] timeout=
[Fri Sep 27 11:50:39 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:50:40 EEST 2019] ret='0'
[Fri Sep 27 11:50:40 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:50:42 EEST 2019] GET
[Fri Sep 27 11:50:42 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:42 EEST 2019] timeout=
[Fri Sep 27 11:50:42 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:50:43 EEST 2019] ret='0'
[Fri Sep 27 11:50:43 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:50:45 EEST 2019] GET
[Fri Sep 27 11:50:45 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:45 EEST 2019] timeout=
[Fri Sep 27 11:50:45 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:50:46 EEST 2019] ret='0'
[Fri Sep 27 11:50:46 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:50:48 EEST 2019] GET
[Fri Sep 27 11:50:48 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:48 EEST 2019] timeout=
[Fri Sep 27 11:50:48 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:50:49 EEST 2019] ret='0'
[Fri Sep 27 11:50:49 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:50:51 EEST 2019] GET
[Fri Sep 27 11:50:51 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:51 EEST 2019] timeout=
[Fri Sep 27 11:50:51 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:50:52 EEST 2019] ret='0'
[Fri Sep 27 11:50:52 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:50:54 EEST 2019] GET
[Fri Sep 27 11:50:54 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:54 EEST 2019] timeout=
[Fri Sep 27 11:50:54 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:50:55 EEST 2019] ret='0'
[Fri Sep 27 11:50:55 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:50:57 EEST 2019] GET
[Fri Sep 27 11:50:57 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:50:57 EEST 2019] timeout=
[Fri Sep 27 11:50:57 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:50:58 EEST 2019] ret='0'
[Fri Sep 27 11:50:58 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:00 EEST 2019] GET
[Fri Sep 27 11:51:00 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:00 EEST 2019] timeout=
[Fri Sep 27 11:51:00 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:01 EEST 2019] ret='0'
[Fri Sep 27 11:51:01 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:03 EEST 2019] GET
[Fri Sep 27 11:51:03 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:03 EEST 2019] timeout=
[Fri Sep 27 11:51:03 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:04 EEST 2019] ret='0'
[Fri Sep 27 11:51:04 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:06 EEST 2019] GET
[Fri Sep 27 11:51:06 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:06 EEST 2019] timeout=
[Fri Sep 27 11:51:06 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:07 EEST 2019] ret='0'
[Fri Sep 27 11:51:07 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:09 EEST 2019] The new-authz request is ok.
[Fri Sep 27 11:51:09 EEST 2019] entry
[Fri Sep 27 11:51:09 EEST 2019] Error, can not get domain token entry www.ykkosbasaari.fi
[Fri Sep 27 11:51:09 EEST 2019] pid
[Fri Sep 27 11:51:09 EEST 2019] No need to restore nginx, skip.
[Fri Sep 27 11:51:09 EEST 2019] _clearupdns
[Fri Sep 27 11:51:09 EEST 2019] skip dns.
[Fri Sep 27 11:51:09 EEST 2019] _on_issue_err
[Fri Sep 27 11:51:09 EEST 2019] Please check log file for more details: /root/.acme.sh/acme.sh.log
[Fri Sep 27 11:51:09 EEST 2019] _main_domain='ykkosbasaari.fi'
[Fri Sep 27 11:51:09 EEST 2019] _alt_domains='no'
[Fri Sep 27 11:51:09 EEST 2019] Using config home:/root/.acme.sh
[Fri Sep 27 11:51:09 EEST 2019] ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:09 EEST 2019] DOMAIN_PATH='/root/.acme.sh/cwp_certs/ykkosbasaari.fi'
[Fri Sep 27 11:51:09 EEST 2019] Using ACME_DIRECTORY: https://acme-v01.api.letsencrypt.org/directory
[Fri Sep 27 11:51:09 EEST 2019] _init api for server: https://acme-v01.api.letsencrypt.org/directory
[Fri Sep 27 11:51:09 EEST 2019] GET
[Fri Sep 27 11:51:09 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:09 EEST 2019] timeout=
[Fri Sep 27 11:51:09 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:10 EEST 2019] ret='0'
[Fri Sep 27 11:51:10 EEST 2019] ACME_KEY_CHANGE='https://acme-v01.api.letsencrypt.org/acme/key-change'
[Fri Sep 27 11:51:10 EEST 2019] ACME_NEW_AUTHZ='https://acme-v01.api.letsencrypt.org/acme/new-authz'
[Fri Sep 27 11:51:10 EEST 2019] ACME_NEW_ORDER='https://acme-v01.api.letsencrypt.org/acme/new-cert'
[Fri Sep 27 11:51:10 EEST 2019] ACME_NEW_ACCOUNT='https://acme-v01.api.letsencrypt.org/acme/new-reg'
[Fri Sep 27 11:51:10 EEST 2019] ACME_REVOKE_CERT='https://acme-v01.api.letsencrypt.org/acme/revoke-cert'
[Fri Sep 27 11:51:10 EEST 2019] ACME_AGREEMENT='https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf'
[Fri Sep 27 11:51:10 EEST 2019] ACME_NEW_NONCE
[Fri Sep 27 11:51:10 EEST 2019] ACME_VERSION
[Fri Sep 27 11:51:10 EEST 2019] _on_before_issue
[Fri Sep 27 11:51:10 EEST 2019] _chk_main_domain='ykkosbasaari.fi'
[Fri Sep 27 11:51:10 EEST 2019] _chk_alt_domains
[Fri Sep 27 11:51:10 EEST 2019] Le_LocalAddress
[Fri Sep 27 11:51:10 EEST 2019] d='ykkosbasaari.fi'
[Fri Sep 27 11:51:10 EEST 2019] Check for domain='ykkosbasaari.fi'
[Fri Sep 27 11:51:10 EEST 2019] _currentRoot='/usr/local/apache/autossl_tmp/'
[Fri Sep 27 11:51:11 EEST 2019] _saved_account_key_hash is not changed, skip register account.
[Fri Sep 27 11:51:11 EEST 2019] Read key length:
[Fri Sep 27 11:51:11 EEST 2019] Creating domain key
[Fri Sep 27 11:51:11 EEST 2019] Use DEFAULT_DOMAIN_KEY_LENGTH=2048
[Fri Sep 27 11:51:11 EEST 2019] Using config home:/root/.acme.sh
[Fri Sep 27 11:51:11 EEST 2019] ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:11 EEST 2019] Use length 2048
[Fri Sep 27 11:51:11 EEST 2019] Using RSA: 2048
[Fri Sep 27 11:51:11 EEST 2019] The domain key is here: /root/.acme.sh/cwp_certs/ykkosbasaari.fi/ykkosbasaari.fi.key
[Fri Sep 27 11:51:11 EEST 2019] _createcsr
[Fri Sep 27 11:51:11 EEST 2019] Single domain='ykkosbasaari.fi'
[Fri Sep 27 11:51:11 EEST 2019] Getting domain auth token for each domain
[Fri Sep 27 11:51:11 EEST 2019] d='ykkosbasaari.fi'
[Fri Sep 27 11:51:11 EEST 2019] Getting webroot for domain='ykkosbasaari.fi'
[Fri Sep 27 11:51:11 EEST 2019] _w='/usr/local/apache/autossl_tmp/'
[Fri Sep 27 11:51:11 EEST 2019] _currentRoot='/usr/local/apache/autossl_tmp/'
[Fri Sep 27 11:51:11 EEST 2019] Getting new-authz for domain='ykkosbasaari.fi'
[Fri Sep 27 11:51:11 EEST 2019] _init api for server: https://acme-v01.api.letsencrypt.org/directory
[Fri Sep 27 11:51:11 EEST 2019] Try new-authz for the 0 time.
[Fri Sep 27 11:51:11 EEST 2019] url='https://acme-v01.api.letsencrypt.org/acme/new-authz'
[Fri Sep 27 11:51:11 EEST 2019] payload='{"resource": "new-authz", "identifier": {"type": "dns", "value": "ykkosbasaari.fi"}}'
[Fri Sep 27 11:51:11 EEST 2019] RSA key
[Fri Sep 27 11:51:11 EEST 2019] GET
[Fri Sep 27 11:51:11 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:11 EEST 2019] timeout=
[Fri Sep 27 11:51:11 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:12 EEST 2019] ret='0'
[Fri Sep 27 11:51:12 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:14 EEST 2019] GET
[Fri Sep 27 11:51:14 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:14 EEST 2019] timeout=
[Fri Sep 27 11:51:14 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:15 EEST 2019] ret='0'
[Fri Sep 27 11:51:15 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:17 EEST 2019] GET
[Fri Sep 27 11:51:17 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:17 EEST 2019] timeout=
[Fri Sep 27 11:51:17 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:18 EEST 2019] ret='0'
[Fri Sep 27 11:51:18 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:20 EEST 2019] GET
[Fri Sep 27 11:51:20 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:20 EEST 2019] timeout=
[Fri Sep 27 11:51:20 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:21 EEST 2019] ret='0'
[Fri Sep 27 11:51:21 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:23 EEST 2019] GET
[Fri Sep 27 11:51:23 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:23 EEST 2019] timeout=
[Fri Sep 27 11:51:23 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:24 EEST 2019] ret='0'
[Fri Sep 27 11:51:24 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:26 EEST 2019] GET
[Fri Sep 27 11:51:26 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:26 EEST 2019] timeout=
[Fri Sep 27 11:51:26 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:27 EEST 2019] ret='0'
[Fri Sep 27 11:51:27 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:29 EEST 2019] GET
[Fri Sep 27 11:51:29 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:29 EEST 2019] timeout=
[Fri Sep 27 11:51:29 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:30 EEST 2019] ret='0'
[Fri Sep 27 11:51:30 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:32 EEST 2019] GET
[Fri Sep 27 11:51:32 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:32 EEST 2019] timeout=
[Fri Sep 27 11:51:32 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:33 EEST 2019] ret='0'
[Fri Sep 27 11:51:33 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:35 EEST 2019] GET
[Fri Sep 27 11:51:35 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:35 EEST 2019] timeout=
[Fri Sep 27 11:51:35 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:36 EEST 2019] ret='0'
[Fri Sep 27 11:51:36 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:38 EEST 2019] GET
[Fri Sep 27 11:51:38 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:38 EEST 2019] timeout=
[Fri Sep 27 11:51:38 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:39 EEST 2019] ret='0'
[Fri Sep 27 11:51:39 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:41 EEST 2019] GET
[Fri Sep 27 11:51:41 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:41 EEST 2019] timeout=
[Fri Sep 27 11:51:41 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:42 EEST 2019] ret='0'
[Fri Sep 27 11:51:42 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:44 EEST 2019] GET
[Fri Sep 27 11:51:44 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:44 EEST 2019] timeout=
[Fri Sep 27 11:51:44 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:45 EEST 2019] ret='0'
[Fri Sep 27 11:51:45 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:47 EEST 2019] GET
[Fri Sep 27 11:51:47 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:47 EEST 2019] timeout=
[Fri Sep 27 11:51:47 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:48 EEST 2019] ret='0'
[Fri Sep 27 11:51:48 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:50 EEST 2019] GET
[Fri Sep 27 11:51:50 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:50 EEST 2019] timeout=
[Fri Sep 27 11:51:50 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:51 EEST 2019] ret='0'
[Fri Sep 27 11:51:51 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:53 EEST 2019] GET
[Fri Sep 27 11:51:53 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:53 EEST 2019] timeout=
[Fri Sep 27 11:51:53 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:54 EEST 2019] ret='0'
[Fri Sep 27 11:51:54 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:56 EEST 2019] GET
[Fri Sep 27 11:51:56 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:56 EEST 2019] timeout=
[Fri Sep 27 11:51:56 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:51:57 EEST 2019] ret='0'
[Fri Sep 27 11:51:57 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:51:59 EEST 2019] GET
[Fri Sep 27 11:51:59 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:51:59 EEST 2019] timeout=
[Fri Sep 27 11:51:59 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:52:00 EEST 2019] ret='0'
[Fri Sep 27 11:52:00 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:52:02 EEST 2019] GET
[Fri Sep 27 11:52:02 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:52:02 EEST 2019] timeout=
[Fri Sep 27 11:52:02 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:52:03 EEST 2019] ret='0'
[Fri Sep 27 11:52:03 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:52:05 EEST 2019] GET
[Fri Sep 27 11:52:05 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:52:05 EEST 2019] timeout=
[Fri Sep 27 11:52:05 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:52:06 EEST 2019] ret='0'
[Fri Sep 27 11:52:06 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:52:08 EEST 2019] GET
[Fri Sep 27 11:52:08 EEST 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Fri Sep 27 11:52:08 EEST 2019] timeout=
[Fri Sep 27 11:52:08 EEST 2019] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header -g '
[Fri Sep 27 11:52:09 EEST 2019] ret='0'
[Fri Sep 27 11:52:09 EEST 2019] Could not get nonce, let's try again.
[Fri Sep 27 11:52:11 EEST 2019] The new-authz request is ok.
[Fri Sep 27 11:52:11 EEST 2019] entry
[Fri Sep 27 11:52:11 EEST 2019] Error, can not get domain token entry ykkosbasaari.fi
[Fri Sep 27 11:52:11 EEST 2019] pid
[Fri Sep 27 11:52:11 EEST 2019] No need to restore nginx, skip.
[Fri Sep 27 11:52:11 EEST 2019] _clearupdns
[Fri Sep 27 11:52:11 EEST 2019] skip dns.
[Fri Sep 27 11:52:11 EEST 2019] _on_issue_err
[Fri Sep 27 11:52:11 EEST 2019] Please check log file for more details: /root/.acme.sh/acme.sh.log
My web server is (include version): Apache/2.4.39
The operating system my web server runs on is (include version): CentOS Linux release 7.6.1810 (Core)
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Yes, CWPpro version: 0.9.8.894
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): acme.sh 2.8.0
Previously I had a problem with Let's Encrypt randomly not succeeding in issuing certificates and renewing them. We found a workaround for that in this thread Can't connect to Let's Encrypt server - #23 by Solsku by changing the IP address of acme-v01.api.letsencrypt.org in hosts-file to a custom one instead of using the one I get from DNS automatically.
Now this workaround doesn't seem applicable anymore, because acme-v01.api.letsencrypt.org always returns the same IP address 172.65.32.248 and I can't search for any alternative ones anymore to try and see which one works.
I managed to get this domain working by using an old IP address I had stored, but lots of old ones had already stopped working, so this solution is coming to its end.
When I did curl -v with the new address I received the following output:
curl -v https://acme-v01.api.letsencrypt.org
- Trying 172.65.32.248...
- TCP_NODELAY set
- Connected to acme-v01.api.letsencrypt.org (172.65.32.248) port 443 (#0)
- Initializing NSS with certpath: sql:/etc/pki/nssdb
- CAfile: none
CApath: none - loaded libnssckbi.so
- ALPN, server accepted to use h2
- SSL connection using TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
- Server certificate:
subject: CN=acme-v01.api.letsencrypt.org -
start date: Sep 13 17:57:16 2019 GMT -
expire date: Dec 12 17:57:16 2019 GMT -
common name: acme-v01.api.letsencrypt.org -
issuer: CN=Let's Encrypt Authority X3,O=Let's Encrypt,C=US - Using HTTP2, server supports multi-use
- Connection state changed (HTTP/2 confirmed)
- Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
- Using Stream ID: 1 (easy handle 0x2015e20)
GET / HTTP/2
Host: acme-v01.api.letsencrypt.org
User-Agent: curl/7.62.0
Accept: /
- Connection state changed (MAX_CONCURRENT_STREAMS == 128)!
< HTTP/2 200
< server: nginx
< date: Fri, 27 Sep 2019 09:14:35 GMT
< content-type: text/html
< content-length: 2174
< last-modified: Mon, 25 Feb 2019 20:15:27 GMT
< etag: "5c744cdf-87e"
< x-frame-options: DENY
< strict-transport-security: max-age=604800
< accept-ranges: bytes
<div class="col-xs-6 text-left">
<h1>Boulder<br>
<small>The Let's Encrypt CA</small></h1>
</div>
</div>
<div class="row">
<div class="col-xs-8 col-xs-offset-2 text-center">
<h3>This is an <a href="https://github.com/letsencrypt/acme-spec/">ACME</a> Certificate Authority running <a href="https://github.com/letsencrypt/boulder">Boulder</a>.</h3>
<p>This is a <em>programmatic</em> endpoint, an API for a computer to talk to. You should probably be using a specialized client to utilize the service, and not your web browser. See <a href="https://letsencrypt.org/"><tt>https://letsencrypt.org/</tt></a> for help.</p>
<p>If you're trying to use this service, note that the starting point, <em>the directory</em>, is available at this URL: <a href="https://acme-v02.api.letsencrypt.org/directory"><tt>https://acme-v02.api.letsencrypt.org/directory</a></tt>.</p>
</div>
</div>
<div class="row">
<div class="col-xs-4 col-xs-offset-2 text-center">
<p><a href="https://letsencrypt.status.io" title="Twitter">
<i class="fa fa-area-chart"></i>
Service Status (letsencrypt.status.io)
</a></p>
</div>
<div class="col-xs-4 text-center">
<p><a href="https://twitter.com/letsencrypt" title="Twitter">
<i class="fa fa-twitter"></i>
Check with us on Twitter
</a></p>
</div>
</div> <!-- row -->
I hope we can find the root cause of this problem. Thank you in advance.
