Acme.sh - Can not renew certificate. Could not get nonce
My domain is: eel.limtel.com,avatar.limtel.com,pubsub.limtel.com,eel-elastic.limtel.com
I ran this command: /root/.acme.sh/acme.sh --cron --home "/root/.acme.sh" --debug 2
[Fri Jan 15 12:57:48 UTC 2021] Lets find script dir.
[Fri Jan 15 12:57:48 UTC 2021] _SCRIPT_='/root/.acme.sh/acme.sh'
[Fri Jan 15 12:57:48 UTC 2021] _script='/root/.acme.sh/acme.sh'
[Fri Jan 15 12:57:48 UTC 2021] _script_home='/root/.acme.sh'
[Fri Jan 15 12:57:48 UTC 2021] Using config home:/root/.acme.sh
[Fri Jan 15 12:57:48 UTC 2021] LE_WORKING_DIR='/root/.acme.sh'
https://github.com/acmesh-official/acme.sh
v2.8.9
[Fri Jan 15 12:57:48 UTC 2021] Running cmd: cron
[Fri Jan 15 12:57:48 UTC 2021] default_acme_server
[Fri Jan 15 12:57:48 UTC 2021] ACME_DIRECTORY='https://acme-v02.api.letsencrypt.org/directory'
[Fri Jan 15 12:57:48 UTC 2021] _ACME_SERVER_HOST='acme-v02.api.letsencrypt.org'
[Fri Jan 15 12:57:48 UTC 2021] ===Starting cron===
[Fri Jan 15 12:57:48 UTC 2021] _stopRenewOnError
[Fri Jan 15 12:57:48 UTC 2021] _set_level='2'
[Fri Jan 15 12:57:48 UTC 2021] di='/root/.acme.sh/cloud.limdesk.com/'
[Fri Jan 15 12:57:48 UTC 2021] d='cloud.limdesk.com'
[Fri Jan 15 12:57:48 UTC 2021] DOMAIN_PATH='/root/.acme.sh/cloud.limdesk.com'
[Fri Jan 15 12:57:48 UTC 2021] Renew: 'cloud.limdesk.com'
[Fri Jan 15 12:57:48 UTC 2021] Le_API='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:57:48 UTC 2021] ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:57:48 UTC 2021] _ACME_SERVER_HOST='acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:57:48 UTC 2021] Skip, Next renewal time is: Mon Jan 25 05:11:10 UTC 2021
[Fri Jan 15 12:57:48 UTC 2021] Add '--force' to force to renew.
[Fri Jan 15 12:57:48 UTC 2021] Return code: 2
[Fri Jan 15 12:57:48 UTC 2021] Skipped cloud.limdesk.com
[Fri Jan 15 12:57:48 UTC 2021] di='/root/.acme.sh/eel.limtel.com/'
[Fri Jan 15 12:57:48 UTC 2021] d='eel.limtel.com'
[Fri Jan 15 12:57:48 UTC 2021] DOMAIN_PATH='/root/.acme.sh/eel.limtel.com'
[Fri Jan 15 12:57:48 UTC 2021] Renew: 'eel.limtel.com'
[Fri Jan 15 12:57:48 UTC 2021] _main_domain='eel.limtel.com'
[Fri Jan 15 12:57:48 UTC 2021] _alt_domains='avatar.limtel.com,pubsub.limtel.com,eel-elastic.limtel.com'
[Fri Jan 15 12:57:48 UTC 2021] 'dns_r53' does not contain 'dns'
[Fri Jan 15 12:57:48 UTC 2021] Using ACME_DIRECTORY: https://acme-v01.api.letsencrypt.org
[Fri Jan 15 12:57:48 UTC 2021] _init api for server: https://acme-v01.api.letsencrypt.org
[Fri Jan 15 12:57:48 UTC 2021] GET
[Fri Jan 15 12:57:48 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:57:48 UTC 2021] timeout=
[Fri Jan 15 12:57:48 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.D7VptlKIWJ  -g '
[Fri Jan 15 12:57:49 UTC 2021] ret='0'
[Fri Jan 15 12:57:49 UTC 2021] response='<!DOCTYPE html>
<html lang="en">
<head>
  <meta charset="utf-8">
  <meta http-equiv="X-UA-Compatible" content="IE=edge">
  <meta name="viewport" content=
  "width=device-width, initial-scale=1">
  <title>Boulder: The Let's Encrypt CA</title>
  <link href=
  "//maxcdn.bootstrapcdn.com/bootstrap/3.2.0/css/bootstrap.min.css"
  rel="stylesheet" type="text/css">
  <link href=
  "//maxcdn.bootstrapcdn.com/font-awesome/4.2.0/css/font-awesome.min.css"
</head>
<body>
  <div class="container-fluid">
    <div class="row">
      <div class="col-xs-6 text-right">
        <p style="font-size: 90px;">
        <i class="fa fa-barcode"></i></p>
      </div>
      <div class="col-xs-6 text-left">
        <h1>Boulder<br>
        <small>The Let's Encrypt CA</small></h1>
      </div>
    </div>
    <div class="row">
      <div class="col-xs-8 col-xs-offset-2 text-center">
        <h3>This is an <a href="https://github.com/letsencrypt/acme-spec/">ACME</a> Certificate Authority running <a href="https://github.com/letsencrypt/boulder">Boulder</a>.</h3>
        <p>This is a <em>programmatic</em> endpoint, an API for a computer to talk to. You should probably be using a specialized client to utilize the service, and not your web browser. See <a href="https://letsencrypt.org/"><tt>https://letsencrypt.org/</tt></a> for help.</p>
        <p>If you're trying to use this service, note that the starting point, <em>the directory</em>, is available at this URL: <a href="https://acme-v02.api.letsencrypt.org/directory"><tt>https://acme-v02.api.letsencrypt.org/directory</a></tt>.</p>
      </div>
    </div>
    <div class="row">
      <div class="col-xs-4 col-xs-offset-2 text-center">
        <p><a href="https://letsencrypt.status.io" title="Twitter">
          <i class="fa fa-area-chart"></i>
          Service Status (letsencrypt.status.io)
        </a></p>
      </div>
      <div class="col-xs-4 text-center">
        <p><a href="https://twitter.com/letsencrypt" title="Twitter">
          <i class="fa fa-twitter"></i>
          Check with us on Twitter
        </a></p>
      </div>
    </div> <!-- row -->
  </div>
</body>
</html>'
[Fri Jan 15 12:57:49 UTC 2021] ACME_KEY_CHANGE
[Fri Jan 15 12:57:49 UTC 2021] ACME_NEW_AUTHZ
[Fri Jan 15 12:57:49 UTC 2021] ACME_NEW_ORDER
[Fri Jan 15 12:57:49 UTC 2021] ACME_NEW_ACCOUNT
[Fri Jan 15 12:57:49 UTC 2021] ACME_REVOKE_CERT
[Fri Jan 15 12:57:49 UTC 2021] ACME_AGREEMENT
[Fri Jan 15 12:57:49 UTC 2021] ACME_NEW_NONCE
[Fri Jan 15 12:57:49 UTC 2021] ACME_VERSION
[Fri Jan 15 12:57:49 UTC 2021] Le_NextRenewTime='1609910019'
[Fri Jan 15 12:57:49 UTC 2021] Using CA: https://acme-v01.api.letsencrypt.org
[Fri Jan 15 12:57:49 UTC 2021] _on_before_issue
[Fri Jan 15 12:57:49 UTC 2021] _chk_main_domain='eel.limtel.com'
[Fri Jan 15 12:57:49 UTC 2021] _chk_alt_domains='avatar.limtel.com,pubsub.limtel.com,eel-elastic.limtel.com'
[Fri Jan 15 12:57:49 UTC 2021] 'dns_r53' does not contain 'no'
[Fri Jan 15 12:57:49 UTC 2021] Le_LocalAddress
[Fri Jan 15 12:57:49 UTC 2021] d='eel.limtel.com'
[Fri Jan 15 12:57:49 UTC 2021] Check for domain='eel.limtel.com'
[Fri Jan 15 12:57:49 UTC 2021] _currentRoot='dns_r53'
[Fri Jan 15 12:57:49 UTC 2021] d='avatar.limtel.com'
[Fri Jan 15 12:57:49 UTC 2021] Check for domain='avatar.limtel.com'
[Fri Jan 15 12:57:49 UTC 2021] d='pubsub.limtel.com'
[Fri Jan 15 12:57:49 UTC 2021] Check for domain='pubsub.limtel.com'
[Fri Jan 15 12:57:49 UTC 2021] d='eel-elastic.limtel.com'
[Fri Jan 15 12:57:49 UTC 2021] Check for domain='eel-elastic.limtel.com'
[Fri Jan 15 12:57:49 UTC 2021] 'dns_r53' does not contain 'apache'
[Fri Jan 15 12:57:49 UTC 2021] _saved_account_key_hash='kv1mYs4K9+h9ZJgNvKM0VbO2K6PPOwNJHX204R7pA38='
[Fri Jan 15 12:57:49 UTC 2021] Using config home:/root/.acme.sh
[Fri Jan 15 12:57:49 UTC 2021] ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:57:49 UTC 2021] _ACME_SERVER_HOST='acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:57:49 UTC 2021] _init api for server: https://acme-v01.api.letsencrypt.org
[Fri Jan 15 12:57:49 UTC 2021] GET
[Fri Jan 15 12:57:49 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:57:49 UTC 2021] timeout=
[Fri Jan 15 12:57:49 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.nYk3vptTXb  -g '
[Fri Jan 15 12:57:50 UTC 2021] ret='0'
[Fri Jan 15 12:57:50 UTC 2021] response='<!DOCTYPE html>
<html lang="en">
<head>
  <link href=
  <link href=
</head>
<body>
    <div class="row">
      </div>
        <h1>Boulder<br>
      </div>
    </div>
    <div class="row">
      </div>
    </div>
    <div class="row">
        </a></p>
      </div>
        </a></p>
      </div>
    </div> <!-- row -->
  </div>
</body>
</html>'
[Fri Jan 15 12:57:50 UTC 2021] ACME_KEY_CHANGE
[Fri Jan 15 12:57:50 UTC 2021] ACME_NEW_AUTHZ
[Fri Jan 15 12:57:50 UTC 2021] ACME_NEW_ORDER
[Fri Jan 15 12:57:50 UTC 2021] ACME_NEW_ACCOUNT
[Fri Jan 15 12:57:50 UTC 2021] ACME_REVOKE_CERT
[Fri Jan 15 12:57:50 UTC 2021] ACME_AGREEMENT
[Fri Jan 15 12:57:50 UTC 2021] ACME_NEW_NONCE
[Fri Jan 15 12:57:50 UTC 2021] ACME_VERSION
[Fri Jan 15 12:57:50 UTC 2021] RSA key
[Fri Jan 15 12:57:50 UTC 2021] Registering account: https://acme-v01.api.letsencrypt.org
[Fri Jan 15 12:57:50 UTC 2021] url
[Fri Jan 15 12:57:50 UTC 2021] payload='{"resource": "new-account", "terms-of-service-agreed": true, "agreement": ""}'
[Fri Jan 15 12:57:50 UTC 2021] Use cached jwk for file: /root/.acme.sh/ca/acme-v01.api.letsencrypt.org/account.key
[Fri Jan 15 12:57:50 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:57:50 UTC 2021] GET
[Fri Jan 15 12:57:50 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:57:50 UTC 2021] timeout=
[Fri Jan 15 12:57:50 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.XNp8Xhg0f5  -g '
[Fri Jan 15 12:57:51 UTC 2021] ret='0'
[Fri Jan 15 12:57:51 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:55:36 GMT
Content-Type: text/html
Content-Length: 2174
Last-Modified: Mon, 05 Oct 2020 22:28:10 GMT
ETag: "5f7b9dfa-87e"
X-Frame-Options: DENY
[Fri Jan 15 12:57:51 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:57:51 UTC 2021] nonce
[Fri Jan 15 12:57:51 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:57:54 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:57:54 UTC 2021] GET
[Fri Jan 15 12:57:54 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:57:54 UTC 2021] timeout=
[Fri Jan 15 12:57:54 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.nk2KkUXtRe  -g '
[Fri Jan 15 12:57:55 UTC 2021] ret='0'
[Fri Jan 15 12:57:55 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:55:40 GMT
Last-Modified: Mon, 05 Oct 2020 22:27:07 GMT
ETag: "5f7b9dbb-87e"
[Fri Jan 15 12:57:55 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:57:55 UTC 2021] nonce
[Fri Jan 15 12:57:55 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:57:58 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:57:58 UTC 2021] GET
[Fri Jan 15 12:57:58 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:57:58 UTC 2021] timeout=
[Fri Jan 15 12:57:58 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.nmUE6yz4Fx  -g '
[Fri Jan 15 12:57:58 UTC 2021] ret='0'
[Fri Jan 15 12:57:58 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:55:44 GMT
Last-Modified: Wed, 09 Oct 2019 18:16:22 GMT
ETag: "5d9e23f6-87e"
[Fri Jan 15 12:57:58 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:57:58 UTC 2021] nonce
[Fri Jan 15 12:57:58 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:58:01 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:01 UTC 2021] GET
[Fri Jan 15 12:58:01 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:01 UTC 2021] timeout=
[Fri Jan 15 12:58:01 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.jpo8EIJIZp  -g '
[Fri Jan 15 12:58:02 UTC 2021] ret='0'
[Fri Jan 15 12:58:02 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:55:47 GMT
Last-Modified: Mon, 25 Feb 2019 19:57:39 GMT
ETag: "5c7448b3-87e"
[Fri Jan 15 12:58:02 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:58:02 UTC 2021] nonce
[Fri Jan 15 12:58:02 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:58:05 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:05 UTC 2021] GET
[Fri Jan 15 12:58:05 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:05 UTC 2021] timeout=
[Fri Jan 15 12:58:05 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.1ezsnHL5nC  -g '
[Fri Jan 15 12:58:06 UTC 2021] ret='0'
[Fri Jan 15 12:58:06 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:55:51 GMT
[Fri Jan 15 12:58:06 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:58:06 UTC 2021] nonce
[Fri Jan 15 12:58:06 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:58:09 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:09 UTC 2021] GET
[Fri Jan 15 12:58:09 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:09 UTC 2021] timeout=
[Fri Jan 15 12:58:09 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.ZtJEGiw417  -g '
[Fri Jan 15 12:58:09 UTC 2021] ret='0'
[Fri Jan 15 12:58:09 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:55:55 GMT
[Fri Jan 15 12:58:09 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:58:09 UTC 2021] nonce
[Fri Jan 15 12:58:09 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:58:12 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:13 UTC 2021] GET
[Fri Jan 15 12:58:13 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:13 UTC 2021] timeout=
[Fri Jan 15 12:58:13 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.vlzQtfV4ZX  -g '
[Fri Jan 15 12:58:13 UTC 2021] ret='0'
[Fri Jan 15 12:58:13 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:55:59 GMT
[Fri Jan 15 12:58:13 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:58:13 UTC 2021] nonce
[Fri Jan 15 12:58:13 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:58:16 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:16 UTC 2021] GET
[Fri Jan 15 12:58:16 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:16 UTC 2021] timeout=
[Fri Jan 15 12:58:16 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.cjEA6ueAZY  -g '
[Fri Jan 15 12:58:17 UTC 2021] ret='0'
[Fri Jan 15 12:58:17 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:56:02 GMT
[Fri Jan 15 12:58:17 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:58:17 UTC 2021] nonce
[Fri Jan 15 12:58:17 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:58:20 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:20 UTC 2021] GET
[Fri Jan 15 12:58:20 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:20 UTC 2021] timeout=
[Fri Jan 15 12:58:20 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.wzfKgFnqac  -g '
[Fri Jan 15 12:58:21 UTC 2021] ret='0'
[Fri Jan 15 12:58:21 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:56:06 GMT
[Fri Jan 15 12:58:21 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:58:21 UTC 2021] nonce
[Fri Jan 15 12:58:21 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:58:24 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:24 UTC 2021] GET
[Fri Jan 15 12:58:24 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:24 UTC 2021] timeout=
[Fri Jan 15 12:58:24 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.YuHeUcOhhF  -g '
[Fri Jan 15 12:58:24 UTC 2021] ret='0'
[Fri Jan 15 12:58:24 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:56:10 GMT
[Fri Jan 15 12:58:24 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:58:24 UTC 2021] nonce
[Fri Jan 15 12:58:24 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:58:27 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:27 UTC 2021] GET
[Fri Jan 15 12:58:27 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:27 UTC 2021] timeout=
[Fri Jan 15 12:58:27 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.F8OyDfGIVD  -g '
[Fri Jan 15 12:58:28 UTC 2021] ret='0'
[Fri Jan 15 12:58:28 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:56:13 GMT
Last-Modified: Mon, 25 Feb 2019 20:15:27 GMT
ETag: "5c744cdf-87e"
[Fri Jan 15 12:58:28 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:58:28 UTC 2021] nonce
[Fri Jan 15 12:58:28 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:58:31 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:31 UTC 2021] GET
[Fri Jan 15 12:58:31 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:31 UTC 2021] timeout=
[Fri Jan 15 12:58:31 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.5cUdNPFJJC  -g '
[Fri Jan 15 12:58:32 UTC 2021] ret='0'
[Fri Jan 15 12:58:32 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:56:17 GMT
[Fri Jan 15 12:58:32 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:58:32 UTC 2021] nonce
[Fri Jan 15 12:58:32 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:58:35 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:35 UTC 2021] GET
[Fri Jan 15 12:58:35 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:35 UTC 2021] timeout=
[Fri Jan 15 12:58:35 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.vSg9MFypef  -g '
[Fri Jan 15 12:58:35 UTC 2021] ret='0'
[Fri Jan 15 12:58:35 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:56:21 GMT
[Fri Jan 15 12:58:35 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:58:35 UTC 2021] nonce
[Fri Jan 15 12:58:35 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:58:38 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:38 UTC 2021] GET
[Fri Jan 15 12:58:38 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:38 UTC 2021] timeout=
[Fri Jan 15 12:58:38 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.99mqqy1RJG  -g '
[Fri Jan 15 12:58:39 UTC 2021] ret='0'
[Fri Jan 15 12:58:39 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:56:25 GMT
[Fri Jan 15 12:58:39 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:58:39 UTC 2021] nonce
[Fri Jan 15 12:58:39 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:58:42 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:42 UTC 2021] GET
[Fri Jan 15 12:58:42 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:42 UTC 2021] timeout=
[Fri Jan 15 12:58:42 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.n9VU4v2BTf  -g '
[Fri Jan 15 12:58:43 UTC 2021] ret='0'
[Fri Jan 15 12:58:43 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:56:28 GMT
[Fri Jan 15 12:58:43 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:58:43 UTC 2021] nonce
[Fri Jan 15 12:58:43 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:58:46 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:46 UTC 2021] GET
[Fri Jan 15 12:58:46 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:46 UTC 2021] timeout=
[Fri Jan 15 12:58:46 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.4qzQ3zOnac  -g '
[Fri Jan 15 12:58:47 UTC 2021] ret='0'
[Fri Jan 15 12:58:47 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:56:32 GMT
[Fri Jan 15 12:58:47 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:58:47 UTC 2021] nonce
[Fri Jan 15 12:58:47 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:58:50 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:50 UTC 2021] GET
[Fri Jan 15 12:58:50 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:50 UTC 2021] timeout=
[Fri Jan 15 12:58:50 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.7fidK3sNaI  -g '
[Fri Jan 15 12:58:50 UTC 2021] ret='0'
[Fri Jan 15 12:58:50 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:56:36 GMT
Last-Modified: Wed, 09 Oct 2019 18:16:23 GMT
ETag: "5d9e23f7-87e"
[Fri Jan 15 12:58:50 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:58:50 UTC 2021] nonce
[Fri Jan 15 12:58:50 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:58:53 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:53 UTC 2021] GET
[Fri Jan 15 12:58:53 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:53 UTC 2021] timeout=
[Fri Jan 15 12:58:53 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.yPAC4AB30D  -g '
[Fri Jan 15 12:58:54 UTC 2021] ret='0'
[Fri Jan 15 12:58:54 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:56:40 GMT
[Fri Jan 15 12:58:54 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:58:54 UTC 2021] nonce
[Fri Jan 15 12:58:54 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:58:57 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:57 UTC 2021] GET
[Fri Jan 15 12:58:57 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:58:57 UTC 2021] timeout=
[Fri Jan 15 12:58:57 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.kC10kNM2IJ  -g '
[Fri Jan 15 12:58:58 UTC 2021] ret='0'
[Fri Jan 15 12:58:58 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:56:43 GMT
[Fri Jan 15 12:58:58 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:58:58 UTC 2021] nonce
[Fri Jan 15 12:58:58 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:59:01 UTC 2021] Get nonce with GET. ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:59:01 UTC 2021] GET
[Fri Jan 15 12:59:01 UTC 2021] url='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:59:01 UTC 2021] timeout=
[Fri Jan 15 12:59:01 UTC 2021] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  --trace-ascii /tmp/tmp.LmT1S4GN0q  -g '
[Fri Jan 15 12:59:01 UTC 2021] ret='0'
[Fri Jan 15 12:59:01 UTC 2021] _headers='HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:56:47 GMT
[Fri Jan 15 12:59:01 UTC 2021] _CACHED_NONCE
[Fri Jan 15 12:59:01 UTC 2021] nonce
[Fri Jan 15 12:59:01 UTC 2021] Could not get nonce, let's try again.
[Fri Jan 15 12:59:04 UTC 2021] Giving up sending to CA server after 20 retries.
[Fri Jan 15 12:59:04 UTC 2021] Register account Error: <!DOCTYPE html>
<html lang="en">
<head>
  <link href=
  <link href=
</head>
<body>
    <div class="row">
      </div>
        <h1>Boulder<br>
      </div>
    </div>
    <div class="row">
      </div>
    </div>
    <div class="row">
        </a></p>
      </div>
        </a></p>
      </div>
    </div> <!-- row -->
  </div>
</body>
</html>
[Fri Jan 15 12:59:04 UTC 2021] _on_issue_err
[Fri Jan 15 12:59:04 UTC 2021] Please check log file for more details: /root/.acme.sh/acme.sh.log
[Fri Jan 15 12:59:04 UTC 2021] _chk_vlist
[Fri Jan 15 12:59:04 UTC 2021] 'dns_r53' does not contain 'dns'
[Fri Jan 15 12:59:04 UTC 2021] socat doesn't exist.
[Fri Jan 15 12:59:04 UTC 2021] Diagnosis versions:
openssl:openssl
OpenSSL 1.0.1f 6 Jan 2014
apache:
apache doesn't exist.
nginx:
nginx version: nginx/1.4.6 (Ubuntu)
built by gcc 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04.3)
TLS SNI support enabled
configure arguments: --with-cc-opt='-g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2' --with-ld-opt='-Wl,-Bsymbolic-functions -Wl,-z,relro' --prefix=/usr/share/nginx --conf-path=/etc/nginx/nginx.conf --http-log-path=/var/log/nginx/access.log --error-log-path=/var/log/nginx/error.log --lock-path=/var/lock/nginx.lock --pid-path=/run/nginx.pid --http-client-body-temp-path=/var/lib/nginx/body --http-fastcgi-temp-path=/var/lib/nginx/fastcgi --http-proxy-temp-path=/var/lib/nginx/proxy --http-scgi-temp-path=/var/lib/nginx/scgi --http-uwsgi-temp-path=/var/lib/nginx/uwsgi --with-debug --with-pcre-jit --with-ipv6 --with-http_ssl_module --with-http_stub_status_module --with-http_realip_module --with-http_addition_module --with-http_dav_module --with-http_geoip_module --with-http_gzip_static_module --with-http_image_filter_module --with-http_spdy_module --with-http_sub_module --with-http_xslt_module --with-mail --with-mail_ssl_module
socat:
[Fri Jan 15 12:59:04 UTC 2021] Return code: 1
[Fri Jan 15 12:59:04 UTC 2021] Error renew eel.limtel.com.
[Fri Jan 15 12:59:04 UTC 2021] di='/root/.acme.sh/limdesk.limpbx.pl/'
[Fri Jan 15 12:59:04 UTC 2021] d='limdesk.limpbx.pl'
[Fri Jan 15 12:59:05 UTC 2021] Using config home:/root/.acme.sh
[Fri Jan 15 12:59:05 UTC 2021] ACME_DIRECTORY='https://acme-v02.api.letsencrypt.org/directory'
[Fri Jan 15 12:59:05 UTC 2021] _ACME_SERVER_HOST='acme-v02.api.letsencrypt.org'
[Fri Jan 15 12:59:05 UTC 2021] DOMAIN_PATH='/root/.acme.sh/limdesk.limpbx.pl'
[Fri Jan 15 12:59:05 UTC 2021] Renew: 'limdesk.limpbx.pl'
[Fri Jan 15 12:59:05 UTC 2021] Le_API='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:59:05 UTC 2021] ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:59:05 UTC 2021] _ACME_SERVER_HOST='acme-v01.api.letsencrypt.org'
[Fri Jan 15 12:59:05 UTC 2021] Skip, Next renewal time is: Sat Feb  6 05:11:10 UTC 2021
[Fri Jan 15 12:59:05 UTC 2021] Add '--force' to force to renew.
[Fri Jan 15 12:59:05 UTC 2021] Return code: 2
[Fri Jan 15 12:59:05 UTC 2021] Skipped limdesk.limpbx.pl
[Fri Jan 15 12:59:05 UTC 2021] di='/root/.acme.sh/socket.limdesk.com/'
[Fri Jan 15 12:59:05 UTC 2021] d='socket.limdesk.com'
[Fri Jan 15 12:59:05 UTC 2021] DOMAIN_PATH='/root/.acme.sh/socket.limdesk.com'
[Fri Jan 15 12:59:05 UTC 2021] Renew: 'socket.limdesk.com'
[Fri Jan 15 12:59:05 UTC 2021] Skip, Next renewal time is: Sun Jan 17 05:11:11 UTC 2021
[Fri Jan 15 12:59:05 UTC 2021] Skipped socket.limdesk.com
[Fri Jan 15 12:59:05 UTC 2021] _error_level='1'
[Fri Jan 15 12:59:05 UTC 2021] _set_level='2'
[Fri Jan 15 12:59:05 UTC 2021] The NOTIFY_HOOK is empty, just return.
[Fri Jan 15 12:59:05 UTC 2021] ===End cron===
The operating system my web server runs on is: Ubuntu
I'm using a control panel to manage my site: no
The version of my client is: https://github.com/acmesh-official/acme.sh v2.8.9
Additional commands:
# curl -I https://acme-v01.api.letsencrypt.org/directory
HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:51:33 GMT
Content-Length: 658
Replay-Nonce: ---redacted-by-me---
# curl -I https://acme-v02.api.letsencrypt.org/directory
HTTP/1.1 200 OK
Server: nginx
Date: Fri, 15 Jan 2021 12:52:41 GMT
Content-Length: 658
I use route53 to validate certs.
Welcome to the Let's Encrypt Community :slightly_smiling_face:
Your ACME client has the ACMEv1 webroot as the directory endpoint in some of your renewal configuration files. Change those to the ACMEv2 directory endpoint and you should be fine.
Thanks for response!
At this moment I guess it's latest acme.sh version.
I upgraded it yesterday.
There is any guide how to move old certs in acme.sh to use apiv2?
The more I look at your output, I keep thinking that your acme.sh might just have the ACMEv1 directory endpoint wrong in the renewal configuration files for certain domain names.
@Inteli, pay attention to all @griffin said in his post because acme-v1 api version is being deprecated (it still works or at least it should for renewals) but you should migrate to acme-v2 api now to avoid these and new problems till June 1st when acme-v1 api will turn off completely and you won't be able to renew your certs.
Migrating to acme-v2 with acme.sh should be as easy as replacing in your domains conf (example: /root/.acme.sh/eel.limtel.com/eel.limtel.com.conf)
to
Le_API='https://acme-v02.api.letsencrypt.org/directory'
and then renew your cert: acme.sh --renew -d eel.limtel.com
Before doing anything, please, backup the entire directory /root/.acme.sh just in case.
Cheers,
sahsanu
Thanks and also thanks @griffin
I renewed this cert using apiv2 and force renewed other files with apiv2.
I'll update my config in few another virtual machines.
Thanks a lot!
You're quite welcome! :slightly_smiling_face:
Thanks for bringing this to our attention!
I'm curious, how did you reach that conclusion?
All I'm seeing is a misconfigured client: it's requesting the directory at https://acme-v01.api.letsencrypt.org which should have been https://acme-v01.api.letsencrypt.org/directory. (Well, actually it should have been the ACMEv2 API of course, but even so..)
To me, this doesn't indicate to the brownout. You can check the outputs of both URI's in your browser yourself.
@Osiris
Yeah, I figured that out after some additional checking (hence the last line of my initial post and my later post). I should have just cleaned up the mess (like I just did) rather than augmenting my initial response.
For any other @lestaff that received a notification, this is the correct thread. @griffin tagged us in this post suggesting the ACMEv1 brownout didn't end when we intended it to end.
griffin later edited the post to remove that section, presumably because the issue turned out not to be the ACMEv1 brownout but some odd misconfiguration of the API endpoint for ACMEv1 (note the missing /directory) endpoint.
So, no worries, go about your business. :slight_smile:
@jsha
Sorry for the confusion. :blush:
I should have removed the staff call once I fully realized what was happening.
Ah, I missed both of those :roll_eyes:
That probably wouldn't have retracted the e-mails send out to all the LE staff members :grimacing: :stuck_out_tongue:
Yeah, quite so. :face_with_monocle: jsha made me keenly aware of that. Not one of the finer moments in my response history.
