Problem installing the certificate
I have been installing the certificate in the domain: www.efforce.xyz but I have had problems with the redirection I have tried to do it more than 5 times and I reached the limit.
How long should I wait to try again?
Indefinitely.
You don't need to try again.
You already have 5 valid certs that you can use.
If your problem is with redirection, why are you reissuing new certs?
[That won't fix the problem.]
You need to focus on the actual problem - redirection.
Do you have root access to the server?
What "guide/instructions" were you following?
Actually on reviewing the site, there is no answer to HTTPS.
So, it may be getting blocked or your config is incomplete.
Please show the output of:
sudo apachectl -S
Hi @freelancer0282
your check-result https://check-your-website.server-daten.de/?q=efforce.xyz#url-checks says: Your port 443 is blocked.
Before you create a redirect, check your firewall.
Works that url internal?
curl https://efforce.xyz/
from that machine? If yes, it's a firewall / routing problem.
As @rg305 wrote: Five identical certificates, nothing to wait, use one of these.
R3 2020-12-13 2021-03-13 efforce.xyz, www.efforce.xyz - 2 entries
