Hi, I can’t figure out what is wrong in my certification process. I already had certifications for my two first domain (even posted about renewal issues : Impossible to renew certifications) and had to reinstall my server. Now it ends on a connexion refused. I set up IPv6, uninstall fail2ban to see if it was blocking the connexion, and nothing work ! my only access to my websites is with the direct ip
My domain is: alisapolischuk.com, raphaelfiquet.pro & iris-paris.fr
I ran this command: certbot --authenticator webroot --installer apache
My web server is (include version): Apache 2.4.25
The operating system my web server runs on is (include version): Debian 9
My hosting provider, if applicable, is: OVH (Vps SSD)
Result :
Failed authorization procedure. raphaelfiquet.pro (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://raphaelfiquet.pro/.well-known/acme-challenge/rLc_59xNtm_f54ddRZdrMJZq8415vpZ2KTbqEdI6iVI: Connection refused, www.raphaelfiquet.pro (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://www.raphaelfiquet.pro/.well-known/acme-challenge/EJvTnN5QyWpm8RmrIQ_j_LzG8Dt6FoHWxP29GtWy-Uo: Connection refused, www.alisapolischuk.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://www.alisapolischuk.com/.well-known/acme-challenge/Mre0_tpWex6JDc0weTyJQvu3ryUm5tP5WMTWr8tvbn0: Connection refused, iris-paris.fr (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://iris-paris.fr/.well-known/acme-challenge/Oc8wPukJPJ1ii6lWAe9EDHS8CHeqh2-0dGJnQkVwykE: Connection refused, alisapolischuk.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://alisapolischuk.com/.well-known/acme-challenge/0NY6NKZL2bS2leM5HakrpcS03_PNE--LEeSrXgBPXcY: Connection refused, www.iris-paris.fr (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://www.iris-paris.fr/.well-known/acme-challenge/6NJuzMZ6W3yevgaO_N4mLn-VllnXcRN2FlcX2V-4wng: Connection refused
Domain: raphaelfiquet.pro
Type: connection
Detail: Fetching
Connection refusedDomain: www.raphaelfiquet.pro
Type: connection
Detail: Fetching
Connection refusedDomain: www.alisapolischuk.com
Type: connection
Detail: Fetching
Connection refusedDomain: iris-paris.fr
Type: connection
Detail: Fetching
Connection refusedDomain: alisapolischuk.com
Type: connection
Detail: Fetching
Connection refusedDomain: www.iris-paris.fr
Type: connection
Detail: Fetching
Connection refusedTo fix these errors, please make sure that your domain name was
