HI,
I installed openmediavault letsencrypt plugin. Everything worked fine until I generated the cert.
Here’s the error message I received :
Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org
http-01 challenge for kaufranitz.net
Using the webroot path /var/www/openmediavault for all unmatched domains.
Waiting for verification…
Failed authorization procedure. kaufranitz.net (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to kaufranitz.net
** - If you lose your account credentials, you can recover through**
** e-mails sent to camaalot@gmail.com.**
** - The following errors were reported by the server:**
** Domain: kaufranitz.net**
** Type: connection**
** Detail: Could not connect to kaufranitz.net**
** To fix these errors, please make sure that your domain name was**
** entered correctly and the DNS A record(s) for that domain**
** contain(s) the right IP address. Additionally, please check that**
** your computer has a publicly routable IP address and that no**
** firewalls are preventing the server from communicating with the**
** client. If you’re using the webroot plugin, you should also verify**
** that you are serving files from the webroot path you provided.**
** - Your account credentials have been saved in your Certbot**
** configuration directory at /etc/letsencrypt. You should make a**
** secure backup of this folder now. This configuration directory will**
** also contain certificates and private keys obtained by Certbot so**
** making regular backups of this folder is ideal.**
Done…
- the DNS A is correctly propagated.
- The IP address is OK
- All ports on firewall are open : 192.168.1.98:80 and 443
Can you help me with this problem, please !
Camaalot
