Hi guys, i’m newer of this forum and i have to ask your help.
I run openmediavault on my raspberry p3+ and i want to secure it by remote access with my domain.
I went from ubuntu where i used openmediavault on vm and i always follow cerbot guide with no problem.
Run debian 9 (openmediavault) i find this problem:
Apache 2 correctly installed
root@raspberrypi:/# sudo certbot --apache
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter ‘c’ to cancel): naszmhome.ddns.net
http-01 challenge for naszmhome.ddns.net
Enabled Apache rewrite module
Waiting for verification…
Failed authorization procedure. naszmhome.ddns.net (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://naszmhome.ddns.net/.well-known/acme-challenge/dAv5_5NqRg5c_R96MOi0i8f2GJOufZHxVSt2TCL3UCE: Error getting validation data
Domain: naszmhome.ddns.net
Type: connection
Detail: Fetching
Error getting validation dataTo fix these errors, please make sure that your domain name was
Can you help me to solve this problem?
thanks a lot
