Issue with certbot and SSL in Raspbian (apache2)
Hi all, I have a local apache server running in Raspbian OS (local server). The HTTP site (with ".ddns.net" domain) can be acessed from internet (port 80 and 443 forwarded). But, running "sudo certbot --apache", show this output:
Enabled Apache rewrite module
Challenge failed for domain pyramide.ddns.net
http-01 challenge for pyramide.ddns.net
Detail: my server running local. Maybe I have to try the "webroot" comm?
Anyone can help me?
Apache version: Apache/2.4.38 (Raspbian)
Raspbian OS Version: "10 (buster)"
Certbot Version: 1.12.0
Thanks!
Hi @nlc
your domain name is required if you want help.
Hi JuergenAuer, I changed the message.
Thanks for the reply.
See your check, ~~2 hours old - https://check-your-website.server-daten.de/?q=pyramide.ddns.net
Only timeouts.
If you want to use http validation, a working port 80 / http is required.
You left out the actual error message / reason for failure.
