Problem connecting to server
My domain is: fensoft.co.uk
I ran this command: curl -v https://acme-staging-v02.api.letsencrypt.org/directory
(The curl version is 8.4.0)
  • Trying 172.65.46.172:443...
  • Connected to acme-staging-v02.api.letsencrypt.org (172.65.46.172) port 443
  • ALPN: curl offers http/1.1
  • Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
  • TLSv1.2 (OUT), TLS handshake, Client hello (1):
  • CAfile: none
  • CApath: /etc/ssl/certs
  • TLSv1.2 (IN), TLS handshake, Server hello (2):
  • TLSv1.2 (IN), TLS handshake, Certificate (11):
  • TLSv1.2 (OUT), TLS alert, unknown CA (560):
  • SSL certificate problem: unable to get local issuer certificate
  • Closing connection
  • TLSv1.2 (IN), TLS handshake, Server finished (14):
  • TLSv1.2 (OUT), TLS alert, unexpected_message (522):
  • TLSv1.2 (OUT), TLS alert, close notify (256):
    curl: (60) SSL certificate problem: unable to get local issuer certificate
    More details here: curl - SSL CA Certificates
My web server is (include version): apache 2.4.20
The operating system my web server runs on is (include version): Slackware Linux 14.2
It looks like your system trust store doesn't include ISRG Root X1, the root that all of Let's Encrypt's certificates (including those we issue to ourselves for our own API servers) chain up to.
Slackware 14.2 is from 2016, and ships with both a very old certificate trust store, and an old and unsafe version of openssl. I would advise updating to Slackware 15.0. If you can't do that, it should be safe to install the -current version of the ca-certificates package.
Or some kind of untrusted MachineInTheMiddle is trying to hijack the connection, e.g. anti-virus on the device itself or a firewall doing deep packet inspection on HTTPS somewhere on the premises, ISP or on a government level.
Knowing which certificate is unrecognised by cURL would help to distinguish what's what.
What shows?:
openssl s_client -connect acme-staging-v02.api.letsencrypt.org:443 | head -n 20
