I had generated SSL Certificate for the following Domains using letsencrypt DNS Challenge
The domain working with SSL on Browsers Chrome, Firefox, Edge
https://netaxis.aicaller.xyz:4443/main.php
But while Accessing on Curl and PHP it shows error
curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: https://curl.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
Solutions will help us a lot
Thanks in Advance
Hello,
Your apache webserver running on ubuntu is configured to serve only the leaf certificate, not the full chain including the intermediate signing certificate.
tumbleweed:~ # openssl s_client -connect netaxis.aicaller.xyz:4443
CONNECTED(00000003)
depth=0 CN = netaxis.aicaller.xyz
verify error:num=20:unable to get local issuer certificate
verify return:1
verify error:num=21:unable to verify the first certificate
verify return:1
verify return:1
Certificate chain
0 s:CN = netaxis.aicaller.xyz
a:PKEY: rsaEncryption, 2048 (bit); sigalg: RSA-SHA256
v:NotBefore: Feb 6 06:51:27 2024 GMT; NotAfter: May 6 06:51:26 2024 GMT
