Problem binding to port 80: [WinError 10013]
hi, i am using apache tomcat 9 on windows server. When I run the cerbot certonly --standalone command, I get the following error. I have searched the previous threads but could not reach the conclusion.
netstat -oan | When I check with the find "80" command, I see that the system is using port 80. I can't stop it. Is there any other way?
certbot.errors.StandaloneBindError: Problem binding to port 80: [WinError 10013] An attempt was made to access a socket that is not allowed by access permissions
2022-11-14 10:44:57,437:ERROR:certbot._internal.log:Problem binding to port 80: [WinError 10013] An attempt was made to access a socket that is not allowed by access permissions
My domain is:online.bulanik.bel.tr
I ran this command:certbot certonly --standalone
It produced this output:certbot.errors.StandaloneBindError: Problem binding to port 80: [WinError 10013] Erişim izinlerince izin verilmeyen bir şekilde bir yuvaya erişilmeye çalışıldı
2022-11-14 10:44:57,437:ERROR:certbot._internal.log:Problem binding to port 80: [WinError 10013] Erişim izinlerince izin verilmeyen bir şekilde bir yuvaya erişilmeye çalışıldı
My web server is (include version): Apache Tomcat 9.0.41
The operating system my web server runs on is (include version): Windows Server 2012 R2
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): Certbot 1.32.0
Presumably Apache [Tomcat] is already using port 80, so you'd need to stop that to run the certbot "standalone" mode, which is also a basic port 80 web server.
thank you for answer
netstat -oan | find "80" i checked with command There are no ports used by apache. I stopped the service. It seems to be using System (NT Kernel § System) port 80 at the moment. i checked
Ok, do you have IIS installed? If so it may have a default website running.
I presume you are running certbot as Administrator under a CMD that has "Run as Administrator" enabled. Non-admin (and non-elevated) accounts can't bind to port 80 on Windows.
thanks for the answer
80 port iis was also working, I stopped it, I passed this step, but after entering the domain and mail information, I encountered an error like this. I am doing this for the first time.
domain is on a different server, but we forwarded the domain I want to receive ssl to the server wan ip address.
Detail: The key authorization file from the server did not match this challenge "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" != "404 File Not Found\nThe requested URL was not found on this server"
2022-11-16 15:59:54,796:DEBUG:certbot._internal.error_handler:Encountered exception:
File "C:\Program Files\Certbot\pkgs\certbot_internal\auth_handler.py", line 106, in handle_authorizations
File "C:\Program Files\Certbot\pkgs\certbot_internal\auth_handler.py", line 206, in _poll_authorizations
2022-11-16 15:59:54,796:DEBUG:certbot._internal.error_handler:Calling registered functions
2022-11-16 15:59:54,797:INFO:certbot._internal.auth_handler:Cleaning up challenges
2022-11-16 15:59:54,798:DEBUG:certbot._internal.plugins.standalone:Stopping server at :::80...
2022-11-16 15:59:54,798:DEBUG:certbot._internal.plugins.standalone:Stopping server at 0.0.0.0:80...
2022-11-16 15:59:54,833:DEBUG:certbot._internal.log:Exiting abnormally:
File "runpy.py", line 197, in _run_module_as_main
File "runpy.py", line 87, in run_code
File "C:\Program Files\Certbot\bin\certbot.exe_main
.py", line 29, in
sys.exit(main())
File "C:\Program Files\Certbot\pkgs\certbot\main.py", line 19, in main
File "C:\Program Files\Certbot\pkgs\certbot_internal\main.py", line 1744, in main
File "C:\Program Files\Certbot\pkgs\certbot_internal\main.py", line 1591, in certonly
lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
File "C:\Program Files\Certbot\pkgs\certbot_internal\main.py", line 141, in _get_and_save_cert
File "C:\Program Files\Certbot\pkgs\certbot_internal\client.py", line 530, in obtain_and_enroll_certificate
File "C:\Program Files\Certbot\pkgs\certbot_internal\client.py", line 442, in obtain_certificate
File "C:\Program Files\Certbot\pkgs\certbot_internal\client.py", line 510, in _get_order_and_authorizations
2022-11-16 15:59:54,838:ERROR:certbot._internal.log:Some challenges have failed.
You might get further faster by using IIS to validate the challenge request.
