Problem binding to port 80 winerror 10013
Good morning everyone, I am having issues with certbot, I understand I need to turn off the web services momentarily so that certbot has access to port 80. My issue is that I am not sure what I need to turn off.
I went to IIS and Stopped it there. I also stopped all the Services it was running.
If I can get an idea of what else I need to turn off, I would appreciate it.
berkeleycitizens.org
certbot certonly --standalone
Problem binding to port 80: [WinError 10013] An attempt was made to access a socket in a way
forbidden by its access permissions.
Not sure.
Windows Server 2019 Standard, Version 1809.
N/A
Yes
No, IIS/Wordpress
Certbot 1.24.0
Thank you for your help.
I have no experience with certbot for Windows...
But, have you tried running is as admin?
And do you really need to turn of IIS to get a cert?
[there are other ways, like using --webroot]
If you're using IIS, and particularly if you're trying to get a certificate to use with IIS, you probably want to use one of the Windows-specific clients that's more designed for that use case. Certbot integrates with Apache/Nginx much easier than it integrates with IIS.
Hello Peter, thank you for your suggestion, I used win-acme and it was simple enough to generate it, now I have an issue where it says I have a valid cert but it is still not secure. Do you have any idea what this could be? I don't know if I need to do an extra step after generating the cert.
Thank you,
It looks like your site doesn't automatically redirect from http://berkeleycitizens.org to https://berkeleycitizens.org, so many browsers won't use the secure connection if you just type in the name.
Your site also has "mixed content", where even when your site loads over https:// it has embedded images and scripts and such which still load over http://.
I'm not familiar enough with IIS/win-acme or your site software (is it Wordpress?) to be able to give you specifics on how to fix those, but other people here might be.
Thank you, actually this was very helpful, you gave me an idea on what to do and I got it working.
