Marcna1
1
I am using Certbot and I used this command while my TMS XData server is down
certbot certonly --standalone
using command prompt as admin but I get this error (Windows server 2019)
Problem binding to port 80: [WinError 10013] An attempt was made to access a socket in a way forbidden by its access permissions
Please advice
rg305
2
Hi @Marcna1 and welcome to the LE community forum
That means there is already something using port 80.
Please show:
sudo netstat -pant | grep -i listen | grep 80
Marcna1
3
sorry forgot to say it is windows server 2019
rg305
4
Try:
netstat -pant TCP
Then just show the lines with "LISTENING"
Marcna1
5
Proto Local Address Foreign Address State Offload State
TCP 0.0.0.0:80 0.0.0.0:0 LISTENING InHost
TCP 0.0.0.0:135 0.0.0.0:0 LISTENING InHost
TCP 0.0.0.0:443 0.0.0.0:0 LISTENING InHost
TCP 0.0.0.0:445 0.0.0.0:0 LISTENING InHost
TCP 0.0.0.0:3389 0.0.0.0:0 LISTENING InHost
TCP 0.0.0.0:5985 0.0.0.0:0 LISTENING InHost
TCP 0.0.0.0:7070 0.0.0.0:0 LISTENING InHost
TCP 0.0.0.0:47001 0.0.0.0:0 LISTENING InHost
TCP 0.0.0.0:49664 0.0.0.0:0 LISTENING InHost
TCP 0.0.0.0:49665 0.0.0.0:0 LISTENING InHost
TCP 0.0.0.0:49666 0.0.0.0:0 LISTENING InHost
TCP 0.0.0.0:49667 0.0.0.0:0 LISTENING InHost
TCP 0.0.0.0:49668 0.0.0.0:0 LISTENING InHost
TCP 0.0.0.0:49669 0.0.0.0:0 LISTENING InHost
TCP 0.0.0.0:49671 0.0.0.0:0 LISTENING InHost
TCP 0.0.0.0:49672 0.0.0.0:0 LISTENING InHost
TCP 245.125.45.78:50007 0.0.0.0:0 LISTENING InHost
Marcna1
9
I found it is the system process !! I can not stop this . Is there another solution to generate the certificate ?
system
Closed
13
