Problem binding to port 80: Could not bind to IPv4 or IPv6
Hi all totally noob to this field,
My domain is: www.xxx.ie
sudo certbot certonly --standalone -d xxx.ie -d www.xxx.ie
http-01 challenge for xxx.ie
http-01 challenge for www.xxx.ie
Problem binding to port 80: Could not bind to IPv4 or IPv6.
My web server is (include version): apache
The operating system my web server runs on is (include version): linux
My hosting provider, if applicable, is: letshost
I can login to a root shell on my machine (yes or no, or I don’t know): no
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): yes
Is there any other way to gen a cert without having to stop service?
To use --standalone you must stop your apache before you run certbot.
The standalone spins up a temporary web service to enable responses to the challenge request.
This is only used when there is no web service or if the web service is unable to meet the need it can be temporarily turned off and certbot standalone service can then be used.
So, you already have a web service running on port 80 and there is no way to start any other service on that port.
Yes, many.
Start by not using --standalone.
You should read through the many other options in the manual to decide which would be best for you.
