Problem binding to port 80: Could not bind to IPv4 or IPv6 (no web server)
My domain is: zampaha.duckdns.org
./certbot-auto certonly --standalone --preferred-challenges http-01
–email myemail
-d mydomain.duckdns.org
Requesting to rerun .certbot-auto with root privileges…
Plugin selected: Authenticator standalone, Installer None
http-01 challenge for mydomain.duckdns.org
Problem binding to port 80: Could not bind to IPv4 or IPv6.
My web server is (include version): no web server
The operating system my web server runs on is (include version): raspbian
My hosting provider, if applicable, is: no hosting
Hi everyone,
I just installed HA on my RasPI 3B, port 80 and 443 forwarded, duckdns domain registered.
Everything was good and i could reach http…
Then I installed Let’s Encrypt to enable https, completed the installation but https… was not working.
I scrolled up the log and found a first issue “The standalone specific supported challenges flag is deprecated. Please use the --preferred-challenges flag instead.”
I relaunched the installation process (to renew the certificate) using
–email myemail
instead of --standalone-supported-challenges but got the error:
I read that the problem concerns the port 80 which is already being used by another application and that I should stop the application but I cannot find the way to do it and I’m stuck at this point for a long time.
I do not have a web server.
I’m basically new to these things, can you please tell me what I have to do to solve this issue?
Thank you.
S
Hi @SoL1
if port 80 is used by another program, then you must use the dns-01 - challenge. Use this with --preferred-challenges.
But then you need to create a new txt-entry (in your nameserver settings)
_acme-challenge.zampaha.duckdns.org
with the value.
Thank you J for your suggestion.
I solved definitively by identifying the process (netstat -plten) which kept the port 80 busy (lighttpd): I edited its .conf and modified the server port from 80 to 81 (adding it to nat).
Hope this could help everyone
S
You won’t necessarily need to do this… (You just need to temporarily stop lighthttpd and run renew, then start lighthttpd afterward.)
Thank you
Yep, this is a good solution. The standard ports should not blocked by other programs.
