I am having problems obtaining a certificate on a fresh raspbian installation using certbot-auto. I keep running into a timeout error (see full output below). Upon checking the debug logs, the only thing that looks out of the ordinary is the following line, which appears as certbot attempts to spin up its standalone server:
DEBUG:acme.standalone:Failed to bind to :80 using IPv4
I’m fairly confident that both DuckDNS and port forwarding have been set up correctly; I spun up a quick “hello world” server in python on port 80 and was able to access it via my duckdns domain (in between attempts, of course).
Port 80 is not otherwise in use, and certbot does not complain of it being in use.
Any ideas?
My domain is: dwelch.duckdns.org
I ran this command: sudo ./certbot-auto certonly --standalone --preferred-challenges http -d dwelch.duckdns.org
saving debug log to /var/log/letsencrypt/letsencrypt.log
http-01 challenge for dwelch.duckdns.org
Failed authorization procedure. dwelch.duckdns.org (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://dwelch.duckdns.org/.well-known/acme-challenge/mdldbzgh0xVaxx6lQDkyDGW3RqWMaA-oIbUmT4TVUCs: Timeout
Domain: dwelch.duckdns.org
Type: connection
Detail: Fetching
Timeout
Debug Log: DEBUG:acme.standalone:Failed to bind to :80 using IPv4
My web server is (include version): standalone
The operating system my web server runs on is (include version): RASPBIAN JESSIE LITE version July 2017, kernel version 4.9
