Policy forbids issuing for name dcloud.delta.hu
I tried to issue a certificate for our site (dcloud.delta.hu) and I get the error “Policy forbids issuing for name”. Is this domain blocked? Is it possible to unblock it?
Here are the details of the problem :
the full domain name of your site : dcloud.delta.hu
the command line you ran : sudo certbot certonly --debug --webroot -w /var/www/html/ -d dcloud.delta.hu
the output of that command : Error: urn:acme:error:rejectedIdentifier :: Error creating new authz :: Policy forbids issuing for name
name and version of your operating system and your web server : Ubuntu 14.04.5 LTS; Apache/2.4.7 (Ubuntu)
Thanks,
Hi @qcsera,
I will start the process to unblock this domain for issuance. As a head’s up this typically takes ~6-12 days. I’ll update this thread when the process is completed in production. Thanks for your patience!
Hi @qcsera,
The change has been made in production. You should now be able to issue for delta.hu subdomains. Please let me know if you still encounter the policy error.
Hi @cpu,
I apologize for the late reply.
I have successfully created my certificate.
Thanks for the help!
