My domain is: fiber.gozubuyukoglu.com
I ran this command: Sophos UTM (renew)
But tried with 3 different UTM s , when I use first ISP IP1:46.196.136.250 or ISP1 IP2:46.196.136.46 everything is fine. I can succesfully create/renew certificates.
However when I use ISP2 IP1:31.223.32.179 , while using this ISP2 I couldnt create or renew any certificates.
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: D Renew certificate: Processing fiber.gozubuyukoglu.com
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: D Renew certificate: + Checking domain name(s) of existing cert... unchanged.
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: D Renew certificate: + Checking expire date of existing cert...
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: D Renew certificate: + Valid till Jan 1 00:00:01 2038 GMT (Longer than 30 days). Ignoring because renew was forced!
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: D Renew certificate: + Signing domains...
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: D Renew certificate: + Generating signing request...
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: D Renew certificate: + Requesting new certificate order from CA...
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: D Renew certificate: + Received 1 authorizations URLs from the CA
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: D Renew certificate: + Handling authorization for fiber.gozubuyukoglu.com
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: D Renew certificate: + 1 pending challenge(s)
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: D Renew certificate: + Deploying challenge tokens...
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: D Renew certificate: + Responding to challenge for fiber.gozubuyukoglu.com authorization...
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: D Renew certificate: + Cleaning challenge tokens...
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: D Renew certificate: + Challenge validation has failed ![]()
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: I Renew certificate: command completed with exit code 256
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: E Renew certificate: COMMAND_FAILED: ERROR: Challenge is invalid! (returned: invalid) (result: ["type"] "http-01"
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: E Renew certificate: COMMAND_FAILED: ["status"] "invalid"
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: E Renew certificate: COMMAND_FAILED: ["error","type"] "urn:ietf:params:acme:error:connection"
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: E Renew certificate: COMMAND_FAILED: ["error","detail"] "31.223.32.179: Fetching http://fiber.gozubuyukoglu.com/.well-known/acme-challenge/TxeM-3Xm-irzgl3jf-7eb_JSiDeB3ZuXmi3dUFY2r58: Timeout during connect (likely firewall problem)"
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: E Renew certificate: COMMAND_FAILED: ["error","status"] 400
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: E Renew certificate: COMMAND_FAILED: ["error"] {"type":"urn:ietf:params:acme:error:connection","detail":"31.223.32.179: Fetching http://fiber.gozubuyukoglu.com/.well-known/acme-challenge/TxeM-3Xm-irzgl3jf-7eb_JSiDeB3ZuXmi3dUFY2r58: Timeout during connect (likely firewall problem)","status":400}
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: E Renew certificate: COMMAND_FAILED: ["url"] "https://acme-v02.api.letsencrypt.org/acme/chall-v3/355221697062/oX97XA"
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: E Renew certificate: COMMAND_FAILED: ["token"] "TxeM-3Xm-irzgl3jf-7eb_JSiDeB3ZuXmi3dUFY2r58"
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: E Renew certificate: COMMAND_FAILED: ["validationRecord",0,"url"] "http://fiber.gozubuyukoglu.com/.well-known/acme-challenge/TxeM-3Xm-irzgl3jf-7eb_JSiDeB3ZuXmi3dUFY2r58"
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: E Renew certificate: COMMAND_FAILED: ["validationRecord",0,"hostname"] "fiber.gozubuyukoglu.com"
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: E Renew certificate: COMMAND_FAILED: ["validationRecord",0,"port"] "80"
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: E Renew certificate: COMMAND_FAILED: ["validationRecord",0,"addressesResolved",0] "31.223.32.179"
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: E Renew certificate: COMMAND_FAILED: ["validationRecord",0,"addressesResolved"] ["31.223.32.179"]
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: E Renew certificate: COMMAND_FAILED: ["validationRecord",0,"addressUsed"] "31.223.32.179"
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: E Renew certificate: COMMAND_FAILED: ["validationRecord",0] {"url":"http://fiber.gozubuyukoglu.com/.well-known/acme-challenge/TxeM-3Xm-irzgl3jf-7eb_JSiDeB3ZuXmi3dUFY2r58","hostname":"fiber.gozubuyukoglu.com","port":"80","addressesResolved":["31.223.32.179"],"addressUsed":"31.223.32.179"}
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: E Renew certificate: COMMAND_FAILED: ["validationRecord"] [{"url":"http://fiber.gozubuyukoglu.com/.well-known/acme-challenge/TxeM-3Xm-irzgl3jf-7eb_JSiDeB3ZuXmi3dUFY2r58","hostname":"fiber.gozubuyukoglu.com","port":"80","addressesResolved":["31.223.32.179"],"addressUsed":"31.223.32.179"}]
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: E Renew certificate: COMMAND_FAILED: ["validated"] "2024-05-25T09:56:12Z")
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: I Renew certificate: sending notification WARN-603
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: [WARN-603] Let's Encrypt certificate renewal failed accessing Let's Encrypt service
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: D Renew certificate: disconnected from Confd
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: D Renew certificate: execution lock removed
2024:05:25-12:56:24 ag-vutm letsencrypt[15140]: I Renew certificate: execution completed (CSRs renewed: 0, failed: 1)
My web server is (include version): Sophos UTM 9.719-3
The operating system my web server runs on is (include version): Sophos UTM 9.719-3
My hosting provider, if applicable, is: KABLONET & TURK.NET
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): yes, webadmin of Sophos UTM 9.719-3
Possible "dehydrated"
