Please Help SSL keeps failing
what do I do now?
I would remove that one line.
The line is in neither of the instances
2789 onwards reads as below:
</VirtualHost>
<VirtualHost 5.189.166.189:80>
    SuexecUserGroup "#1079" "#1056"
    ServerName raybuilders.com
    ServerAlias www.raybuilders.com
    ServerAlias mail.raybuilders.com
    ServerAlias webmail.raybuilders.com
    ServerAlias admin.raybuilders.com
    DocumentRoot /home/raybuilders/public_html
    ErrorLog /var/log/virtualmin/raybuilders.com_error_log
    CustomLog /var/log/virtualmin/raybuilders.com_access_log combined
    ScriptAlias /cgi-bin/ /home/raybuilders/cgi-bin/
    DirectoryIndex index.html index.htm index.php index.php4 index.php5
    <Directory /home/raybuilders/public_html>
        Options -Indexes +IncludesNOEXEC +SymLinksIfOwnerMatch +ExecCGI
        allow from all
        AllowOverride All Options=ExecCGI,Includes,IncludesNOEXEC,Indexes,MultiViews,SymLinksIfOwnerMatch
        Require all granted
        AddType application/x-httpd-php .php
        AddHandler fcgid-script .php
        AddHandler fcgid-script .php5
        AddHandler fcgid-script .php7.2
        FCGIWrapper /home/raybuilders/fcgi-bin/php7.2.fcgi .php
        FCGIWrapper /home/raybuilders/fcgi-bin/php5.fcgi .php5
        FCGIWrapper /home/raybuilders/fcgi-bin/php7.2.fcgi .php7.2
    </Directory>
    <Directory /home/raybuilders/cgi-bin>
        allow from all
        Require all granted
    </Directory>
    RewriteEngine on
    RewriteCond %{HTTP_HOST} =webmail.raybuilders.com
    RewriteRule ^(?!/.well-known)(.*) https://raybuilders.com:20000/ [R]
    RewriteCond %{HTTP_HOST} =admin.raybuilders.com
    RewriteRule ^(?!/.well-known)(.*) https://raybuilders.com:10000/ [R]
    RemoveHandler .php
    RemoveHandler .php5
    RemoveHandler .php7.2
    FcgidMaxRequestLen 1073741824
    Alias /dav /home/raybuilders/public_html
    <Location /dav>
        DAV on
        AuthType Basic
        AuthName "raybuilders.com"
        AuthUserFile /home/raybuilders/etc/dav.digest.passwd
        Require valid-user
        ForceType text/plain
        Satisfy All
        RemoveHandler .php
        RemoveHandler .php5
        RewriteEngine off
    </Location>
    RewriteCond %{REQUEST_URI} !^/.well-known/acme-challenge
    RewriteRule ^/(.*) https://%{SERVER_NAME}%{REQUEST_URI} [R=301,L]
and 5149 onwards reads as below:
</VirtualHost>
<VirtualHost 5.189.166.189:443>
        allow from all
        Require all granted
    </Directory>
        allow from all
        Require all granted
    </Directory>
    RewriteEngine on
    RemoveHandler .php
    RemoveHandler .php5
    <Location /dav>
        DAV on
        AuthType Basic
        Require valid-user
        Satisfy All
        RemoveHandler .php
        RemoveHandler .php5
        RewriteEngine off
    </Location>
    SSLEngine on
    SSLCertificateFile /home/raybuilders/ssl.combined
    SSLCertificateKeyFile /home/raybuilders/ssl.key
    SSLCACertificateFile /home/raybuilders/ssl.ca
    SSLProtocol all -SSLv2 -SSLv3 -TLSv1 -TLSv1.1
</VirtualHost>
any ideas what to do now?
That rewrite is also completely unnecessary.
It is sending [already] HTTPS traffic to HTTPS.
I think the FCGI stuff is interfering.
What is the certbot command line you use?
You could also try changing those two lines to these.
<VirtualHost *:80>
<VirtualHost *:443>
I don't think those two VirtualHosts are processing the inbound requests. If I try /dav/ URI I am not rejected like I should be for no authorization. Oddly though there are two redirects to ports 10000 and 20000 but I wonder if those are being done elsewhere too.
I wouldn't be surprised to find that there is something like a .backup file in a folder that loads more than just the .conf files.
I wonder if I just edited the virtualmin server saying don't need the SSL
Then went back and edited it again saying I need the SSL would it start fresh? and so maybe the letsecrypt would do the SSL?
I did that a long time ago with another website and it did work, but not sure if it would work again
This one has certificates already would it delete them? or maybe I delete them? not sure...
Need some help getting this one done
I have another one exactly the same as this as well Grrrrr...
tell me your thoughts
I don't think that would fix it. The VirtualHost for port 80 that you show should respond a certain way. But, it does not. Turning off port 443 and back on won't fix that. Or, I wouldn't think so, Maybe a VirtualMin expert on their forum might know.
Do you have an .htaccess file anywhere? Maybe that is doing some redirects.
Also, right now at 1703 UTC I made a test request to the /dav URI. It should be rejected with a 403 deny by your VirtualHost Location for that.
Can you check the access log to see if it arrived to that Apache VirtualHost?
curl http://raybuilders.com/dav/ForumTest1703
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>301 Moved Permanently</title>
</head><body>
<h1>Moved Permanently</h1>
<p>The document has moved <a href="https://raybuilders.com">here</a>.</p>
</body></html>
There's so many files here and the
is empty
which one should I look at?
NAME SIZE OWNER MODE MODIFIED
raybuilders.com_access_log 0 bytes raybuilders:apache 660 2023/10/08 - 03:15:02
raybuilders.com_access_log-20230709.gz 53.11 KiB raybuilders:apache 660 2023/07/09 - 02:53:23
raybuilders.com_access_log-20230716.gz 51.5 KiB raybuilders:apache 660 2023/07/16 - 02:35:04
raybuilders.com_access_log-20230723.gz 47.12 KiB raybuilders:apache 660 2023/07/23 - 03:27:19
raybuilders.com_access_log-20231006.gz 548.32 KiB raybuilders:apache 660 2023/10/06 - 18:21:05
raybuilders.com_access_log-20231008.gz 20 bytes raybuilders:apache 660 2023/10/06 - 18:29:06
raybuilders.com_error_log 0 bytes raybuilders:apache 660 2023/10/08 - 03:15:02
raybuilders.com_error_log-20230709.gz 1.28 KiB raybuilders:apache 660 2023/07/05 - 23:58:41
raybuilders.com_error_log-20230716.gz 1.35 KiB raybuilders:apache 660 2023/07/15 - 23:42:15
raybuilders.com_error_log-20230723.gz 829 bytes raybuilders:apache 660 2023/07/22 - 02:13:23
raybuilders.com_error_log-20231006.gz 10.09 KiB raybuilders:apache 660 2023/10/06 - 14:16:10
raybuilders.com_error_log-20231008.gz 20 bytes raybuilders:apache 660 2023/10/06 - 18:29:06
rkundra.com_access_log 0 bytes rkundra:apache 660 2023/10/08 - 03:15:02
Is it still empty? Because I just made another request to that domain (below) at UTC 11:13 and another at 11:15. Also one at 11:16 but not with /dav/
curl http://raybuilders.com/dav/ForumTest1113
<html><head>
</head><body>
</body></html>
Yes still empty
have a look it says 0 bytes and also when I vie it is empty nothing there
Then that VirtualHost is definitely not seeing the inbound HTTP requests to that domain. Some other Apache is responding or a different VirtualHost in your httpd.conf
Can you show output of this:
grep -Ei "VirtualHost|ServerName" /etc/httpd/conf/httpd.conf
2789 onwards
</VirtualHost>
        allow from all
        Require all granted
    </Directory>
        allow from all
        Require all granted
    </Directory>
    RewriteEngine on
    RemoveHandler .php
    RemoveHandler .php5
    <Location /dav>
        DAV on
        AuthType Basic
        Require valid-user
        Satisfy All
        RemoveHandler .php
        RemoveHandler .php5
        RewriteEngine off
    </Location>
	THEN 5149 ONWARDS
	</VirtualHost>
        allow from all
        Require all granted
    </Directory>
        allow from all
        Require all granted
    </Directory>
    RewriteEngine on
    RemoveHandler .php
    RemoveHandler .php5
    <Location /dav>
        DAV on
        AuthType Basic
        Require valid-user
        Satisfy All
        RemoveHandler .php
        RemoveHandler .php5
        RewriteEngine off
    </Location>
    SSLEngine on
</VirtualHost>
Is there a problem doing this?
# ports, instead of the default. See also the <VirtualHost>
# <VirtualHost> definition.  These values also provide defaults for
# any <VirtualHost> containers you may define later in the file.
# All of these directives may appear inside <VirtualHost> containers,
# ServerName gives the name and port that the server uses to identify itself.
#ServerName www.example.com:80
# If you do not specify an ErrorLog directive within a <VirtualHost>
# logged here.  If you *do* define an error logfile for a <VirtualHost>
    # If you do not define any access logfiles within a <VirtualHost>
    # define per-<VirtualHost> access logfiles, transactions will be
	</VirtualHost>
	and also at the bottom again as below
	</VirtualHost>
</VirtualHost>
Okay. And there is no other output?
Can you try
CHANGED IT AS BELOW SHOULD I TRY NOW?
</VirtualHost>
<VirtualHost *:80>
        allow from all
        Require all granted
    </Directory>
        allow from all
        Require all granted
    </Directory>
    RewriteEngine on
    RemoveHandler .php
    RemoveHandler .php5
    <Location /dav>
        DAV on
        AuthType Basic
        Require valid-user
        Satisfy All
        RemoveHandler .php
        RemoveHandler .php5
        RewriteEngine off
    </Location>
	AND
	</VirtualHost>
<VirtualHost *:443>
        allow from all
        Require all granted
    </Directory>
        allow from all
        Require all granted
    </Directory>
    RewriteEngine on
    RemoveHandler .php
    RemoveHandler .php5
    <Location /dav>
        DAV on
        AuthType Basic
        Require valid-user
        Satisfy All
        RemoveHandler .php
        RemoveHandler .php5
        RewriteEngine off
    </Location>
    SSLEngine on
</VirtualHost>
