Please Help! Limit renew out and now my cert is expired
"removed"
Debian 11.8 - Apache2 ip 35.210.98.9
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.12.0
What does that mean?
Currently there's not much information to work with. Can you please elaborate more about your setup, situation, errors, et cetera et cetera?
You say you're working with Certbot, so I'm sure you can fill out the command & output questions, right?
Thank you for your help Osiris!!!
Unfortunately my web server is closed on http and https to certain public ips.
This caused certbot's auto-check to exceed the renewal limit for mysite.com.
I deleted the certificate and tried to recreate it again but I receive the following message:
An unexpected error occurred:
There were too many requests of a given type :: Error creating new order :: too many failed authorizations recently: see Failed Validation Limit - Let's Encrypt
Yes, I can use certbot command
I tried now, opening all restrictions and it's work!
So, one question, I need to insert in my firewall restriction Let'S Encrypt ip for the next renew.
Have you this ip?
No, the IP addresses from where LE validates are not listed somewhere. There are multiple validation servers used around the world and the addresses can change at any time.
Ok, for the future I'll opned the restrictions and then I'l renew the certificate!
Thank you very much for your help!
can I to modify /usr/lib/systemd/system/certbot.timer?
Have you any suggestion?
I would like to disable and use when it is necessary.
I have no experience with systemd (OpenRC here), so no clue how to disable a systemd timer. I would also recommend against it.
Why would you do this?
If it is to open / close a firewall you should instead try to use --pre-hook and --post-hook
Or, configure your firewall to allow any IP if the request contains /.well-known/acme-challenge
Let's Encrypt certs should be renewed every 60 days (as currently recommended). Automating this is a key to success.
