PLEASE HELP! Can't reach site after installing SSL
I installed SSL and when i go to my site it says:
This page isn’t working
freaks.vip redirected you too many times.
I run Ubuntu 18
Apache 2
Skill level: complete NOOB
Hi @freaks
checking your site via freaks.vip - Make your website better - DNS, redirects, mixed content, certificates - there are unusual redirects:
https://www.freaks.vip/ -14 10.033 •
Timeout - The operation has timed out
http://freaks.vip 301 https://freaks.vip/ 0.016 •
http://freaks.vip/ 301 https://freaks.vip/ 0.127 •
http://www.freaks.vip/ 302 http://www.freaks.vip/ 0.390 •
https://freaks.vip/ 302 http://freaks.vip 0.093 •
The second and the third are good. But the next two are bad. Self - redirect http + www -> http + www and a redirect https -> http, both are wrong.
So check your Port 80 / www - definition to find the self redirect.
And your https should never redirect to http.
Thank you so much sir! but i really don’t understand what to do…
I’m a complete noob, what should i change or where?
Please help me, i’m losing my visitors… :frowning: or at least how can i get my site back to http:// if it’s not possible to fix ssl
How did you create your certificate? Do you use a tool like cPanel? Or Certbot?
Do you have ssh access?
Using Certbot. Yes i have access through PuTTy
I installed SSL as the guide showed: https://certbot.eff.org/lets-encrypt/ubuntubionic-apache
My website is : freaks.vip and now it says ‘‘ERR_CONNECTION_REFUSED’’ when i’m trying to access my website through google chrome, please help.
Can you share your apache configuration file? The file
https://httpd.apache.org/docs/2.4/configuring.html
httpd.conf.
This file may include other files. Search something like
<VirtualHost *:80>
ServerName www.domain.tld
ServerAlias domain.tld *.domain.tld
DocumentRoot /www/domain
</VirtualHost>
Ubuntu doesn’t use httpd.conf as far as i know and ubuntu uses /etc/apache2/apache2. and here’s what it has:
Please copy the text, it’s impossible to read that.
sorry i found different one that might be better:
root@localhost:/# vim /etc/apache2/sites-enabled/000-default.conf
<VirtualHost *:80>
# specifies what hostname must appear in the request’s Host: header to
#ServerName www.example.com
    DocumentRoot /var/www/html
    # error, crit, alert, emerg.
    # modules, e.g.
    #LogLevel info ssl:warn
RewriteEngine on
RewriteCond %{SERVER_NAME} =freaks.vip
vim: syntax=apache ts=4 sw=4 sts=4 sr noet
First step (not the solution): Add # before these two rows, so the redirect http -> https is removed
Then search the ssl - configuration, there must be a redirect https -> http, this is wrong.
I will! thanks!
Here’s full code:
<VirtualHost *:80>
    # modules, e.g.
RewriteEngine on
I added # as you told me, unfortunately nothing changed :frowning:
Could you please help me out? I can give you access to my VPS root user.
I promise i’ll pay you withing next 5 days, i must fix it asap cuz i’m losing my visitors, i don’t have many but i don’t wanna lose those few.
Did you reload your webserver? It won't know about the changes you made until you do that. I believe you'll want to run the command systemctl reload apache2 for your changes to take effect
OMG! you saved my life!
It worked but website doesn’t have SSL certificate, it still says ‘‘Not secure’’ what’s the issue sir?
Now the redirect http -> https is removed. So there is no longer a loop.
So now find the second redirect https -> http. Find something like
Listen 443
<VirtualHost *:443>
    SSLEngine on
    SSLCertificateFile "/path/to/www.example.com.cert"
    SSLCertificateKeyFile "/path/to/www.example.com.key"
</VirtualHost>
With a redirect https -> http.
I don’t know where to find it sir, i installed ssl the way it says on Certbot site…
Where would it be that Virtualhost *: 443?
I apologize for being such a noob, but i don’t know where else to seek help
There may be a file like
/etc/apache2/sites-available/ssl.conf
or ssl-default etc.
/etc/apache2/sites-available/ssl.conf - is empty sir.
how can i display all the folder names in /etc/apache2/ ?
That way i’ll be able to find files and folders if i could see them
Use the ls - list - command
ls -al
I did my best sir but i couldn’t find it, would it be possible for you to have a look at it if i give you the access? or do you know someone who would to that? of course if it takes a minute or two.
