What says
ls -al /etc/apache2/sites-available
What says
here’s what i have in : default-ssl.conf
ServerAdmin webmaster@localhost DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
# SSL Engine Switch:
# Enable/Disable SSL for this virtual host.
SSLEngine on
# A self-signed (snakeoil) certificate can be created by installing
# the ssl-cert package. See
# /usr/share/doc/apache2/README.Debian.gz for more info.
# If both key and certificate are stored in the same file, only the
# SSLCertificateFile directive is needed.
SSLCertificateFile /etc/ssl/certs/ssl-cert-snakeoil.pem
SSLCertificateKeyFile /etc/ssl/private/ssl-cert-snakeoil.key
# Server Certificate Chain:
# Point SSLCertificateChainFile at a file containing the
# concatenation of PEM encoded CA certificates which form the
# certificate chain for the server certificate. Alternatively
1,7 Top
and here’s what i have in : 000-default-le-ssl.conf
<VirtualHost *:443>
# specifies what hostname must appear in the request’s Host: header to
#ServerName www.example.com
# modules, e.g.
RewriteEngine on
ServerName freaks.vip
SSLCertificateFile /etc/letsencrypt/live/freaks.vip/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/freaks.vip/privkey.pem
“000-default-le-ssl.conf” 43L, 1790C
what should i modify or change? i don’t think there’s something you told me to find
i’m not sure if this website pastes what i copied correctly…
Add three ` at the begin of a new row, then a new row, then the content, new row, next three
The character used in è or ò
This is vim 000-default-le-ssl.conf
<VirtualHost *:443>
# specifies what hostname must appear in the request's Host: header to
# modules, e.g.
RewriteEngine on
# Some rewrite rules in this file were disabled on your HTTPS site,
# because they have the potential to create redirection loops.
# RewriteCond %{SERVER_NAME} =freaks.vip
# RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
</IfModule>`
This is default-ssl.conf
<IfModule mod_ssl.c>
<VirtualHost _default_:443>
# modules, e.g.
SSLEngine on
# the referenced file can be the same as SSLCertificateFile
# when the CA certificates are directly appended to the server
# certificate for convinience.
#SSLCertificateChainFile /etc/apache2/ssl.crt/server-ca.crt
# Certificate Authority (CA):
"default-ssl.conf" 134L, 6338C
what should i do? website works but it’s ‘‘Not secure’’ ssl is not installed. please check Freaks.vip
I don't see any redirect https -> http.
Do you use a content management system?
Or something like cPanel or Plesk?
It redirects https -> http. Http is not secure.
Or do you have a .htaccess with this redirect?
I don’t have Cpanel or anything, i use VPS directly through PuTTY software, i log in as root and basically use ubuntu commands to operate. I had FTP but my VPS provider blocked access to FTP i don’t know why and i don’t know how to access my websites var/www/html/.htaccess through PuTTY.
I don’t think my website’s engine’s .httaccess is blocking anything…
Is there ANYTHING at all that i can do sir?
What says
cat /var/www/html/.htaccess
RewriteEngine On
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule ^password-reset/([^\/]+)(\/|)$ index.php?link1=welcome&link2=password_reset&user_id=$1 [NC,QSA]
RewriteRule ^admin-cp$ admincp.php [NC,QSA]
RewriteRule ^admin-cp/(.*)$ admincp.php?page=$1 [NC,QSA]
RewriteRule ^admincp$ admincp.php [NC,QSA]
RewriteRule ^admincp/(.*)$ admincp.php?page=$1 [NC,QSA]
RewriteRule ^adminPages/(.*)$ admin-panel/$1 [L]
RewriteRule ^start-up$ index.php?link1=start-up [NC,QSA]
RewriteRule ^saved-posts/(.*)$ index.php?link1=saved-posts [NC,QSA]
RewriteRule ^unusual-login$ index.php?link1=unusual-login [NC,QSA]
RewriteRule ^activated/(.*)$ index.php?link1=activate&link2=$1 [NC,QSA]
RewriteRule ^search$ index.php?link1=search [NC,QSA]
RewriteRule ^ads-create$ index.php?link1=ads-create [NC,QSA]
RewriteRule ^search/([^\/]+)(\/|)$ index.php?link1=search&query=$1 [NC,QSA]
RewriteRule ^app/([^\/]+)(\/|)$ index.php?link1=app&app_id=$1 [NC,QSA]
RewriteRule ^messages/([^\/]+)(\/|)$ index.php?link1=messages&user=$1 [QSA]
RewriteRule ^terms/([^\/]+)(\/|)$ index.php?link1=terms&type=$1 [QSA]
RewriteRule ^video-call/([^\/]+)(\/|)$ index.php?link1=video-call&call_id=$1 [QSA]
RewriteRule ^video-call-api/([^\/]+)(\/|)$ index.php?link1=video-call-api&call_id=$1 [QSA]
RewriteRule ^post/([^\/]+)(\/|)$ index.php?link1=post&id=$1 [NC,QSA]
RewriteRule ^game/([^\/]+)(\/|)$ index.php?link1=game&id=$1 [NC,QSA]
RewriteRule ^upgraded$ index.php?link1=upgraded [NC,QSA]
RewriteRule ^get_news_feed$ index.php?link1=get_news_feed [NC,QSA]
RewriteRule ^games$ index.php?link1=games [NC,QSA]
RewriteRule ^new-game$ index.php?link1=new-game [NC,QSA]
RewriteRule ^go-pro$ index.php?link1=go-pro [NC,QSA]
RewriteRule ^oops$ index.php?link1=oops [NC,QSA]
RewriteRule ^user-activation$ index.php?link1=user-activation [NC,QSA]
RewriteRule ^hashtag/([^\/]+)(\/|)$ index.php?link1=hashtag&hash=$1 [NC,QSA]
RewriteRule ^follow-requests/(.*)$ index.php?link1=follow-requests[NC,QSA]
RewriteRule ^p/([^\/]+)(\/|)$ index.php?link1=page&p=$1 [NC,QSA]
RewriteRule ^g/([^\/]+)(\/|)$ index.php?link1=group&g=$1 [NC,QSA]
RewriteRule ^home$ index.php?link1=home [QSA]
RewriteRule ^404$ index.php?link1=404 [QSA]
RewriteRule ^welcome(.*)$ index.php?link1=welcome [QSA,L]
RewriteRule ^register(/?|)$ index.php?link1=register [QSA,L]
RewriteRule ^confirm-sms(/?|)$ index.php?link1=confirm-sms [QSA,L]
RewriteRule ^confirm-sms-password(/?|)$ index.php?link1=confirm-sms-password [QSA,L]
RewriteRule ^forgot-password(/?|)$ index.php?link1=forgot-password [QSA,L]
RewriteRule ^activate(/?|)$ index.php?link1=activate [QSA]
RewriteRule ^pages(/?|)$ index.php?link1=pages [QSA]
RewriteRule ^suggested-pages(/?|)$ index.php?link1=suggested-pages [QSA]
RewriteRule ^groups(/?|)$ index.php?link1=groups [QSA]
RewriteRule ^suggested-groups(/?|)$ index.php?link1=suggested-groups [QSA]
RewriteRule ^create-group(/?|)$ index.php?link1=create-group [QSA]
RewriteRule ^create-page(/?|)$ index.php?link1=create-page [QSA]
RewriteRule ^logout(/?|)$ index.php?link1=logout [QSA]
RewriteRule ^contact-us(/?|)$ index.php?link1=contact-us [QSA]
RewriteRule ^setting$ index.php?link1=setting [QSA]
RewriteRule ^messages(/?|)$ index.php?link1=messages [QSA]
RewriteRule ^saved-posts$ index.php?link1=saved-posts [NC,QSA]
RewriteRule ^albums$ index.php?link1=albums [QSA]
RewriteRule ^albums/([A-Za-z0-9_-]+)$ index.php?link1=albums&user=$1 [QSA]
RewriteRule ^album/([A-Za-z0-9_-]+)$ index.php?link1=album&id=$1 [QSA]
RewriteRule ^create-album$ index.php?link1=create-album [QSA]
RewriteRule ^create-album/([A-Za-z0-9_-]+)$ index.php?link1=create-album&album=$1 [QSA]
RewriteRule ^$ index.php?link1=home [QSA]
RewriteRule ^setting/([A-Za-z0-9_]+)/([A-Za-z0-9_-]+)$ index.php?link1=setting&user=$1&page=$2 [NC,QSA]
RewriteRule ^page-setting/([^\/]+)(\/|)$ index.php?link1=page-setting&page=$1 [QSA]
RewriteRule ^page-setting/([A-Za-z0-9_]+)/([A-Za-z0-9_-]+)$ index.php?link1=page-setting&page=$1&link3=$2 [QSA]
RewriteRule ^group-setting/([^\/]+)(\/|)$ index.php?link1=group-setting&group=$1 [QSA]
RewriteRule ^group-setting/([A-Za-z0-9_]+)/([A-Za-z0-9_-]+)$ index.php?link1=group-setting&group=$1&link3=$2 [QSA]
RewriteRule ^new-product(/?|)$ index.php?link1=new-product [NC,QSA]
RewriteRule ^edit-product/([A-Za-z0-9_]+)$ index.php?link1=edit-product&id=$1 [NC,QSA]
RewriteRule ^products(/?|)$ index.php?link1=products [NC,QSA]
RewriteRule ^products/([A-Za-z0-9_-]+)$ index.php?link1=products&c_id=$1 [QSA]
RewriteRule ^my-products(/?|)$ index.php?link1=my-products [QSA]
RewriteRule ^site-pages/(.*)$ index.php?link1=site-pages&page_name=$1 [NC,QSA]
RewriteRule ^blogs(/?|)$ index.php?link1=blogs [NC,QSA]
RewriteRule ^sharer(/?|)$ index.php?link1=sharer [NC,QSA]
RewriteRule ^blog-category/(\d+)(/?|)$ index.php?link1=blog-category&id=$1 [NC,QSA]
RewriteRule ^create-blog(/?|)$ index.php?link1=create-blog [NC,QSA]
RewriteRule ^edit-blog/(\d+)(/?|)$ index.php?link1=edit-blog&id=$1 [NC,QSA]
RewriteRule ^my-blogs(/?|)$ index.php?link1=my-blogs [NC,QSA]
RewriteRule ^read-blog/(.*)$ index.php?link1=read-blog&id=$1 [NC,QSA]
RewriteRule ^app_api$ index.php?link1=app_api [NC,QSA]
RewriteRule ^api_request$ index.php?link1=app_api [NC,QSA]
RewriteRule ^authorize$ index.php?link1=authorize [NC,QSA]
RewriteRule ^poke$ index.php?link1=poke [NC,QSA]
RewriteRule ^most_liked$ index.php?link1=most_liked [NC,QSA]
RewriteRule ^wonderful$ index.php?theme=wonderful [NC,QSA]
RewriteRule ^wowonder$ index.php?theme=wowonder [NC,QSA]
# **** FORUM ****
RewriteRule ^forum(/?|)$ index.php?link1=forum [NC,QSA]
RewriteRule ^forum/members(/?|)$ index.php?link1=forum-members [NC,QSA]
RewriteRule ^forum/members/([a-zA-Z]{0,1})(/?|)$ index.php?link1=forum-members-byname&char=$1 [NC,QSA]
RewriteRule ^forum/search(/?|)$ index.php?link1=forum-search [NC,QSA]
RewriteRule ^forum/search-result/(/?|)$ index.php?link1=forum-search-result [NC,QSA]
RewriteRule ^forum/events(/?|)$ index.php?link1=forum-events [NC,QSA]
RewriteRule ^forum/help(/?|)$ index.php?link1=forum-help [NC,QSA]
RewriteRule ^forums/(\d+)(/?|)$ index.php?link1=forums&fid=$1 [NC,QSA]
RewriteRule ^forums/add/(\d+)(/?|)$ index.php?link1=forumaddthred&fid=$1 [NC,QSA]
RewriteRule ^forums/thread/(\d+)(/?|)$ index.php?link1=showthread&tid=$1 [NC,QSA]
RewriteRule ^forums/thread/reply/(\d+)(/?|)$ index.php?link1=threadreply&tid=$1 [NC,QSA]
RewriteRule ^forums/thread/quote/(\d+)(/?|)$ index.php?link1=threadquote&tid=$1 [NC,QSA]
RewriteRule ^forums/thread/edit/(\d+)(/?|)$ index.php?link1=editreply&tid=$1 [NC,QSA]
RewriteRule ^forums/user/threads(/?|)$ index.php?link1=mythreads [NC,QSA]
RewriteRule ^forums/user/threads/edit/(\d+)(/?|)$ index.php?link1=edithread&tid=$1 [NC,QSA]
RewriteRule ^forums/user/messages(/?|)$ index.php?link1=mymessages [NC,QSA]
# **** EVENTS ****
RewriteRule ^events(/?|)$ index.php?link1=events [NC,QSA]
RewriteRule ^events/create-event(/?|)$ index.php?link1=create-event [NC,QSA]
RewriteRule ^events/edit/(\d+)/(/?|)$ index.php?link1=edit-event&eid=$1 [NC,QSA]
RewriteRule ^events/my(/?|)$ index.php?link1=my-events [NC,QSA]
RewriteRule ^events/going(/?|)$ index.php?link1=events-going [NC,QSA]
RewriteRule ^events/invited(/?|)$ index.php?link1=events-invited [NC,QSA]
RewriteRule ^events/interested(/?|)$ index.php?link1=events-interested [NC,QSA]
RewriteRule ^events/past(/?|)$ index.php?link1=events-past [NC,QSA]
RewriteRule ^events/(\d+)(/?|)$ index.php?link1=show-event&eid=$1 [NC,QSA]
# *** MOVIES ***
RewriteRule ^movies(/?|)$ index.php?link1=movies [NC,QSA]
RewriteRule ^movies/genre/([A-Za-z-]+)(/?|)$ index.php?link1=movies-genre&genre=$1 [NC,QSA]
RewriteRule ^movies/country/([A-Za-z-]+)(/?|)$ index.php?link1=movies-country&country=$1 [NC,QSA]
RewriteRule ^movies/watch/(\d+)(/?|)$ index.php?link1=watch-film&film-id=$1 [NC,QSA]
# *** ADS ***
RewriteRule ^ads(/?|)$ index.php?link1=ads [NC,QSA]
RewriteRule ^wallet(/?|)$ index.php?link1=wallet [NC,QSA]
RewriteRule ^send_money(/?|)$ index.php?link1=send_money [NC,QSA]
RewriteRule ^ads/create(/?|)$ index.php?link1=create-ads [NC,QSA]
RewriteRule ^ads/edit/(\d+)(/?|)$ index.php?link1=edit-ads&id=$1 [NC,QSA]
RewriteRule ^ads/chart/(\d+)(/?|)$ index.php?link1=chart-ads&id=$1 [NC,QSA]
RewriteRule ^admin/ads/edit/(\d+)(/?|)$ index.php?link1=manage-ads&id=$1 [NC,QSA]
# *** STATUS ***
RewriteRule ^status/create(/?|)$ index.php?link1=create-status [NC,QSA]
RewriteRule ^more-status(/?|)$ index.php?link1=more-status [NC,QSA]
# *** FIND NEARBY ***
RewriteRule ^friends-nearby(/?|)$ index.php?link1=friends-nearby [NC,QSA]
RewriteRule ^api(/?|)$ api-v2.php [NC,QSA]
RewriteRule ^api/([^\/]+)(\/|)$ api-v2.php?type=$1 [NC,QSA]
RewriteRule ^_$ requests.php [QSA]
RewriteRule ^graph-success$ index.php?link1=graph-success [NC,QSA]
RewriteRule ^developers$ index.php?link1=developers [NC,QSA]
RewriteRule ^apps$ index.php?link1=apps [NC,QSA]
RewriteRule ^create-app$ index.php?link1=create-app [NC,QSA]
RewriteRule ^graph$ index.php?link1=graph [NC,QSA]
RewriteRule ^oauth$ index.php?link1=oauth [NC,QSA]
RewriteRule ^boosted-pages$ index.php?link1=boosted-pages [NC,QSA]
RewriteRule ^boosted-posts$ index.php?link1=boosted-posts [NC,QSA]
RewriteRule ^setting/([A-Za-z0-9_-]+)$ index.php?link1=setting&page=$1 [NC,QSA]
RewriteRule ^@([^\/]+)(\/|)$ index.php?link1=timeline&u=$1 [QSA]
RewriteRule ^([A-Za-z0-9_]+)/([^\/]+)(\/|)$ index.php?link1=timeline&u=$1&type=$2 [QSA]
RewriteRule ^([^\/]+)(\/|)$ index.php?link1=timeline&u=$1 [QSA]
<IfModule mod_deflate.c>
AddOutputFilterByType DEFLATE text/html
AddOutputFilterByType DEFLATE text/css
AddOutputFilterByType DEFLATE text/javascript
AddOutputFilterByType DEFLATE text/xml
AddOutputFilterByType DEFLATE text/plain
AddOutputFilterByType DEFLATE image/x-icon
AddOutputFilterByType DEFLATE image/svg+xml
AddOutputFilterByType DEFLATE application/rss+xml
AddOutputFilterByType DEFLATE application/javascript
AddOutputFilterByType DEFLATE application/x-javascript
AddOutputFilterByType DEFLATE application/xml
AddOutputFilterByType DEFLATE application/xhtml+xml
AddOutputFilterByType DEFLATE application/x-font
AddOutputFilterByType DEFLATE application/x-font-truetype
AddOutputFilterByType DEFLATE application/x-font-ttf
AddOutputFilterByType DEFLATE application/x-font-otf
AddOutputFilterByType DEFLATE application/x-font-opentype
AddOutputFilterByType DEFLATE application/vnd.ms-fontobject
AddOutputFilterByType DEFLATE font/ttf
AddOutputFilterByType DEFLATE font/otf
AddOutputFilterByType DEFLATE font/opentype
BrowserMatch ^Mozilla/4 gzip-only-text/html
BrowserMatch ^Mozilla/4\.0[678] no-gzip
BrowserMatch \bMSIE !no-gzip !gzip-only-text/html
</IfModule>
<IfModule mod_security.c>
SecFilterScanPOST Off
</IfModule>
## EXPIRES CACHING ##
<IfModule mod_expires.c>
ExpiresActive On
ExpiresByType image/jpg "access plus 1 year"
ExpiresByType image/jpeg "access plus 1 year"
ExpiresByType image/gif "access plus 1 year"
ExpiresByType image/png "access plus 1 year"
ExpiresByType text/css "access plus 1 month"
ExpiresByType application/pdf "access plus 1 month"
ExpiresByType text/x-javascript "access plus 1 month"
ExpiresByType application/x-shockwave-flash "access plus 1 month"
ExpiresByType image/x-icon "access plus 1 year"
ExpiresDefault "access plus 2 days"
</IfModule>
## EXPIRES CACHING ##root@localhost:/etc/apache2/sites-available#
Looks like you have a forum. In this .htaccess, there is no redirect.
But has your forum software such an option?
It’s a social network with forum in it, yes.
And No i really doubt that it has redirect.
What exactly should i look for and by what should i replace it? in /etc/apache2/sites-available ?
in /apache2/sites-available i have only these:
-rw-r–r-- 1 root root 1467 Nov 5 15:51 000-default.conf
-rw-r–r-- 1 root root 12288 Nov 5 15:35 .000-default.conf.swo
-rw-r–r-- 1 root root 12288 Nov 5 15:30 .000-default.conf.swp
-rw-r–r-- 1 root root 1790 Nov 5 15:44 000-default-le-ssl.conf
-rw-r–r-- 1 root root 12288 Nov 5 11:20 .000-default-le-ssl.conf.swp
-rw-r–r-- 1 root root 6338 Jun 27 17:05 default-ssl.conf
and -rw-r–r-- 1 root root 1467 Nov 5 15:51 000-default.conf is empty btw
Oh, a lot of files. Please check these files if there is a redirect https -> http.
Sir i found html/config.php that had my website entered as http instead of https. i replaced it and now my website has ssl! It works now.
Should i continue looking for http-? in different directories or is it fixed? could you please check? https://freaks.vip
Thanks a lot for your time sir! i really appreciate that
Yep, now it looks better.
Now you don't have a critical redirect https -> http.
But you have defined a dns-entry www.freaks.vip
, your certificate has only one name freaks.vip
So if you have users who uses the www-version. you should create one certificate with both names
Something like
-d freaks.vip -d www.freaks.vip
as certbot - parameter.
should i just type ''-d freaks.vip -d www.freaks.vip'' in PuTTY?
and everything's done sir?
You helped me a lot, if there's anything i can do for you just let me know, my site would've died without you.
Add your certbot parameters you have used to create 5 certificates.
I don't know which options you had used. Perhaps
sudo certbot --apache -d freaks.vip -d www.freaks.vip
