PHP Application SSL Issue with EKS
My domain is: temp.mevofit.com
I ran this command: Setup SSL with K8s Setup
My web server is (include version): Nginx
The operating system my web server runs on is (include version): AWS EKS
When we are using AWS ACM Certificate, there is no Issue but only if we are using letsencrypt
Hi @Muthiah131998, and welcome to the LE community forum :slight_smile:
Are both certs of the same type [RSA]?
What version of OpenSSL is that?
@rg305 How I can confirm ,Is there any way to check that?
You're trying to connect to secureservice.mevofit.com. That hostname does NOT provide a Let's Encrypt certificate, but is presenting a self-signed "Kubernetes Ingress Controller Fake Certificate" cert. At least, when I used an online tool https://ssltool.com/index.php?action=sslCheckRawCertsOpenSSL. My browser seems to connect just fine. Maybe PHP doesn't support SNI? Does PHP provide more debugging information somehow? Which PHP version are we talking about anyway? Maybe your PHP can't deal with the "long chain"?
Hello @Osiris Thankyou for your Reply..
Actually we tried AWS LB with ACM Certificate , there is no issue from application side, but when we Integrating with LetsEncrypt , getting this Issue
Can you explain more about this? And, why is the ACM cert in ELB not suitable?
Because I see requests to mevofit.com using an Amazon cert (the Load Balancer).
Requests to domain secureservice.mevofit.com are using a Let's Encrypt cert but it is not the wildcard you just showed. It just has that explicit name in it.
Requests to domain test.mevofit.com are using that Let's Encrypt wildcard cert
On the machine you are running that php app, what does this do
curl -v https://secureservice.mevofit.com
Hi @MikeMcQ We tried that approach we dont need LB for this Application so thats why we setup letsencrypt Setup [13:45] Karamjit Singh
when cakephp code try to send any curl request from temp.mevofit.com to secureservice.mevofit.com we got openssl issue
The curl request looks fine. So, is it only the php request that fails? Might need to check how php http requests are configured.
See if any php fopen works even to https://google.com
Hello, Once we Updated Cakephp Code to latest version ,issue was resolved
Thankyou for your Respsone, it was really helpful for this issue
