My domain is: *.mevofit.com
I ran this command: certbot certonly --manual -d *.mevofit.com --agree-tos --no-bootstrap --manual-public-ip-logging-ok --preferred-challenges dns-01 --server https://acme-v02.api.letsencrypt.org/directory
I have generated ssl from this command and upload it to nginx ingress controller with following command:
Hi @karamjitsingh, and welcome to the LE community forum
I know little about kubernetes...
But I would try using the fullchain.pem file instead of the cert.pem file.
If that fails, check if the cert type is as expected [RSA vs ECDSA].
If that fails... we should wait for more expirienced helpers.
I also don't know anything about kubernetes (and I want to keep it that way), but your site mevofit.com is serving an Amazon certificate chained up to the "Starfield Technologies, Inc." root certificate.
