Operation time out running command WACS
I follow this procedure: How to create a "Let's Encrypt" certificate on Windows
at step 2, creating certificate got time out with following:
Hello @Cannafar, welcome to the Let's Encrypt community. :slightly_smiling_face:
When you opened this thread in the Help section, you should have been provided with a questionnaire. Maybe you didn't get it somehow (which is weird), or you've decided to delete it. In any case, all the answers to this questionnaire are required:
Thank you for assisting us in helping YOU!
Maybe related to Stuck at connection/GET-request to Letsencrypt ACME API · Issue #1903 · win-acme/win-acme · GitHub
The developer of win-acme has mostly moved to their new fork of that app, GitHub - simple-acme/simple-acme: A simple cross platform ACME client (for use with Let's Encrypt et al.)
Alternatively you could try https://certifytheweb.com (which I develop) to see if you have a general connectivity problem that's affecting communication with Let's Encrypt.
You should at least open a web browser on the server and try to access https://acme-v02.api.letsencrypt.org/ and if that doesn't work then you know it's a firewall or configuration problem.
