Same issue An error occured during request "GET https://acme-v02.api.letsencrypt.org/directory"
@arvydasHostinger I moved your post into its own thread. We will need more info from you to be able to help.
You posted in a thread about a communications timeout problem. There are a wide variety of causes of that kind of problem. And, by your description you are having a different problem than they were.
Had you started your own thread you would have been shown the below form. Please answer as much as you can
It seems there was a temporary issue with issuing SSL.
Now everything is back to normal.
We are using the PHP ACME library and we received errors like these for multiple domains:
- An error occured during request "HEAD https://acme-v02.api.letsencrypt.org/acme/new-nonce"
- An error occured during request "GET https://acme-v02.api.letsencrypt.org/directory"
I did not see any message on the status page so I checked forums.
It was between 8:00 am - 3:00 pm on UTC timezone.
Not sure if you have noticed some issues at that time?
I have not heard anything different than what you see.
By my clock it is only 14:29:00 UTC so not quite 3:00pm yet ![]()
There were a couple other reports from Singapore with same temporary problem. These can happen. Were your failed requests all at a particular time? Like always at the zero minute of each hour or similar? Because those are especially busy times and more likely to get fail message.
In the past a wide outage results in far more reports here than we saw.
