Hi forum,
As the title says, can someone help me understand why this ( it works sometimes but I have to be very persistent and keep trying over and over)
in the following logs I’m replacing my real domain name with domain.com and the real IP with 100.200.150.50…
It would be really great if someone can help with this
I’m trying to automate my script so I dont have to run it manually everytime
- create a new instance
- add the instance IP to the A records (60s TTL) for my domain
- wait 5 minutes for DNS
- run the script in standalone mode
below are my details:
#echo $IPV4
100.200.150.50
#echo $DOMAIN
domain.com
nothing running on port 80 or 443
#netstat -na | grep :80.*LISTEN
#echo $?
1
#netstat -na | grep :443.*LISTEN
#echo $?
1
**making sure my IP exists ( using google NS ) **
#dig $DOMAIN @8.8.8.8 | grep $IPV4
domain.com. 59 IN A 100.200.150.50
sudo git clone github.com/letsencrypt/letsencrypt /opt/letsencrypt
cd /opt/letsencrypt
/root/.local/share/letsencrypt/bin/letsencrypt --no-self-upgrade --agree-tos certonly --renew --text --email email@domain.com --standalone --server https://acme-staging.api.letsencrypt.org/directory --verbose --renew-by-default -d domain.com
2016-02-15 08:40:53,535:INFO:letsencrypt.cli:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2016-02-15 08:40:53,618:INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org
2016-02-15 08:40:53,942:INFO:letsencrypt.cli:Auto-renewal forced with --force-renewal…
2016-02-15 08:40:54,208:INFO:letsencrypt.crypto_util:Generating key (2048 bits): /etc/letsencrypt/keys/0028_key-letsencrypt.pem
2016-02-15 08:40:54,212:INFO:letsencrypt.crypto_util:Creating CSR: /etc/letsencrypt/csr/0028_csr-letsencrypt.pem
2016-02-15 08:40:54,215:INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org
2016-02-15 08:40:54,325:INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org
2016-02-15 08:40:54,451:INFO:letsencrypt.auth_handler:Performing the following challenges:
2016-02-15 08:40:54,451:INFO:letsencrypt.auth_handler:tls-sni-01 challenge for domain.com
2016-02-15 08:40:54,473:INFO:letsencrypt.auth_handler:Waiting for verification…
2016-02-15 08:40:54,481:INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org
2016-02-15 08:40:57,630:INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org
2016-02-15 08:41:00,742:INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org
2016-02-15 08:41:00,850:INFO:letsencrypt.reporter:Reporting to user: The following errors were reported by the server:
Domain: domain.com
Type: connection
Detail: Failed to connect to host for DVSNI challenge
To fix these errors, please make sure that your domain name was entered correctly and the DNS A record(s) for that domain contain(s) the right IP address. Additionally, please check that your computer has a publicly routable IP address and that no firewalls are preventing the server from communicating with the client. If you’re using the webroot plugin, you should also verify that you are serving files from the webroot path you provided.
2016-02-15 08:41:00,851:INFO:letsencrypt.auth_handler:Cleaning up challenges
Failed authorization procedure. domain.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Failed to connect to host for DVSNI challenge
Domain: domain.com
Type: connection
Detail: Failed to connect to host for DVSNI challengeTo fix these errors, please make sure that your domain name was
I appreciate your help in advance
Thank you
