My domain is hosted on an AWS EC2 instance and I’ve received the whitelist email for my domain. When I run the letsencrypt-auto client on my server, I got error message of “The server could not connect to the client for DV :: Failed to connect to host for DVSNI challenge”. My question is does letsencrypt-auto script takes care of the case that EC2 instance uses private/public IP address mapping? For example, inside EC2 server ifconfig returns 172.30.0.130, however it has public address 54.88.214.63. More details below.
$ sudo ./letsencrypt-auto --apache --server https://acme-v01.api.letsencrypt.org/directory -d inthingnet.com --agree-dev-preview --verbose
│ Starting new HTTPS connection (1): acme-v01.api.letsencrypt.org │
│ Performing the following challenges: │
│ tls-sni-01 challenge for inthingnet.com │
│ Created an SSL vhost at │
│ /etc/apache2/sites-available/000-default-le-ssl.conf │
│ Waiting for verification... │
│ Reporting to user: The following 'connection' errors were reported │
│ by the server: │
│ Domains: inthingnet.com │
│ Error: The server could not connect to the client for DV │
│ To fix these errors, please make sure that your domain name was │
│ entered correctly and the DNS A record(s) for that domain │
│ contain(s) the right IP address. Additionally, please check that │
│ your computer has a publicly routable IP address and that no │
│ firewalls are preventing the server from communicating with the │
│ client. │
│ Cleaning up challenges
