Not able create a proper certificate
My domain is:mahabazaaronline.com
sudo certbot-auto --apache -d mahabazaaronline.com
http-01 challenge for mahabazaaronline.com
Created an SSL vhost at /etc/apache2/sites-available/mahabazaaronline.com-le-ssl.conf
Deploying Certificate to VirtualHost /etc/apache2/sites-available/mahabazaaronline.com-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/mahabazaaronline.com-le-ssl.conf
Redirecting vhost in /etc/apache2/sites-enabled/mahabazaaronline.com.conf to ssl vhost in /etc/apache2/sites-available/mahabazaaronline.com-le-ssl.conf
Congratulations! You have successfully enabled https://mahabazaaronline.com
   /etc/letsencrypt/live/mahabazaaronline.com/fullchain.pem
   /etc/letsencrypt/live/mahabazaaronline.com/privkey.pem
   Your cert will expire on 2021-02-08. To obtain a new or tweaked
   version of this certificate in the future, simply run certbot-auto
   again with the "certonly" option. To non-interactively renew *all*
   of your certificates, run "certbot-auto renew"
   Donating to ISRG / Let's Encrypt:   https://letsencrypt.org/donate
   Donating to EFF:                    https://eff.org/donate-le
My web server is (include version):apache2
The operating system my web server runs on is (include version):2.4.18
My hosting provider, if applicable, is:DO
The version of my client is (e.g. output of `certbot --version` or `certbot-auto --version` if you're using Certbot): 1.9.0
I am tring to move my application from one server to a new server. I created certificate and later for couple of minutes http://mahabazaaronline.com worked, then it started giving error 404 page not found on domain url, but worked for all other links of the web site. However, I also felt that it was not able to access www.mahabazaaronline.com. I uninstaled ths certificate and created one more certicate using
sudo certbot-auto --apache -d www.mahabazaaronline.com -d mahabazaaronline.com
I was not able to create certificate. Error is as below
http-01 challenge for www.mahabazaaronline.com
Challenge failed for domain www.mahabazaaronline.com
   Domain: www.mahabazaaronline.com
   Type:   unauthorized
   Detail: Invalid response from
   https://www.mahabazaaronline.com/.well-known/acme-challenge/dav22-omclrfXnEK78hnWC4DnfNLs0zfvMeQhh2380s
   [34.192.194.170]: "<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0
   Strict//EN\"
   \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd\">\n<!--[if lt
   IE 7]> "
Now, I have redirected url to the old server and currently mhabazaaronline.com does not point to my new server where new application is built
Please let me know what is going wrong
Sorry, Kindly note I meant https://mahabazaaronline.com worked temporily , before giving Page not found error on homepage
Please show the output of:
apachectl -S
For some reason, visiting your website overwrites my entire browsing history for my tab.
BEWARE:
hxxp://roi-traffic[.]icu/get.php?key=57ae14f08ba34083309153a81162b2f3
iniformarsi[.]tk
FYI I've edited the top post to quote instances of the website name so people don't accidentally click on it.
If you are checking the URL, currently the domain name is pointed to our old server. (We have been sensing some malicious activity in that server. But have not able too verify it), However, the above problem with letsencrypt certicate occured in our new server when we were trying to install a new SSL certificate
@sujathaupadhyaaya
Your website is affected by malware.
That's probably the first issue to address. My guess is that you need to update your Magento version. Your PHP version is also very outdated.
You need to disable TLSv1 as well.
I guess so. However, the url points to our current server right now. I guess that is the one that has malicious activity issue /Old version of PHP etc.
I was not able to get a proper certificate in a different server. After pointing the domain to new server that hosts new application with upgraded software, there was some problem with the ssl certificate, So I pointed the domain back to old server
So is it pointing to the old or the new right now?
It would seem that it is pointing to the old server.
Perhaps he could issue a one time cert via DNS to get the new server going.
[and stop the old one from who knows what...]
It is pointing to the old one...
To run diagnostics properly, we need your domain name to be pointing to the new server. Make sure to "disable" your content if you're worried about insecure access via port 80. I realize that this will take your website down temporarily, which IMO is much better than serving an outdated, infected website.
Thank you @jsha. That's very helpful!
It just displays the configuration. At this point of time, I have disabled the respective .conf file. So there's not much information there.When I put it back I will remember to check that
